The 487th overhead console question
Old 01-09-2006, 01:15 AM   #1
Newbe
I done looked at over 60post about this. But most are 2+ years old and most of the links are down.
So here is what I found, I need to know if i'm on track. The car in question is a 2001 grand am. This is going to be my winter project.
1. The long 98+ console has the compass built into it.
2. The short 98+ one needs the bracket for the compass to work.
3. If it has an "off" button it's the simple outside temp and compass. If it has a mode button it has trip miles and what nots.
4. With the simple console all i need is a outside temperature senor.
5. With the other one, I need to run a VSS line right?
anything else I'm missing?
Old 01-09-2006, 01:17 AM   #2
.:|Hustlin4life|:.
dirttysouth's Avatar
Re: The 487th overhead console question
I think you miss counted this is the 477th thread, the next one will be 478
Old 01-09-2006, 01:25 AM   #3
Same Poop,Different Scoop
devilman13xx's Avatar
i have the long one in my blazer and mode button cycles through temp/compass,avg economy, instant econ, range , avg speed, and off so i would guess its tied into the computer in various spots, i THINK the shorter one with the compass/temp only just needs power and maybe the temp sensor
Old 01-09-2006, 01:28 AM   #4
Newbe
from what read the long or short one can have either the "mode" or "off" button
Old 01-09-2006, 01:31 AM   #5
yeah i would guess if it has mode then its the complicated one, if it just has off them prolly just temp one
i can try and find the wiring diagram if ya want lemme know what year and all that
Old 01-09-2006, 01:36 AM   #6
Newbe
One for a 98+ would be good. For both the simple one and the one with the trip.
Old 01-09-2006, 01:44 AM   #7
i think this is it
Old 01-09-2006, 01:46 AM   #8
Newbe
thanks
Old 01-09-2006, 01:49 AM   #9
no prob i can post the rest of that diagram but your nor missing much, just where those wires go to out of the console
Old 01-09-2006, 07:44 AM   #10
Insane Network Engineer
rlith's Avatar
For either the basic disply or the extended one you will need to tap the vss
Old 01-09-2006, 04:53 PM   #11
Newbe
Taping the vss is no problem. My car has the class data 2 system. From my learning the 98+ ones will work with that system right?
right now I'm eyeing a long one out of a 2000 S10 Blazer. It only has temp and compass that is fine with me.
Old 01-09-2006, 08:24 PM   #12
rlith's Avatar
Correct
Old 01-11-2006, 10:35 AM   #13
NAVY
98sonomaGuy's Avatar
how hard would it be to install the small one on a truck that doesn't have it?
This one
http://cgi.ebay.com/ebaymotors/Blaze... QcmdZViewItem
Old 03-17-2007, 02:52 PM   #14
theoriginalbowtie's Avatar
Everbody please participate in this overhead console thread here:
http://www.s10forum.com/forum/f62/ov...t-here-285146/
(plus this may be a good bump...)
