Taurus eFan wiring diagram help please
Old 05-08-2008, 06:38 PM   #1
ZR2 MIKE's Avatar
I looked at many wiring diagrams for the Ford Taurus Dual Speed eFan and really want to do the most cost effective and simple solution with out having to use manual switches or expensive controllers.
I took what I liked from different diagrams and made up my own. I'm not an electrical engineer though, so I need some input from those who know their stuff if my diagram is up to snuff. And if not, what should I do to improve it. Thanks
Old 05-08-2008, 07:47 PM   #2
ZR2 MIKE's Avatar
Re: Taurus eFan wiring diagram help please
Looks like I need to put a Diode on the AC line. Forgot about that.
Old 05-09-2008, 07:30 PM   #3
ZR2 MIKE's Avatar
No one ? ? ?
Old 05-09-2008, 07:31 PM   #4
ZR2 MIKE's Avatar
Here's a revised version . . .
Old 05-09-2008, 08:18 PM   #5
Blazin_Jason's Avatar
Looks like it will work. I will be doing something similar when I finish mine.
Old 05-12-2008, 06:20 PM   #6
ssz28man's Avatar
the way you have it set up, when your manual switch or a/c is on the fan will still only come on when the temp prob tells it to. some where in the 4.3 section is a thread that has a similar diagram but works exactly how you were trying to make this one work, don't remember which thread it was though
Old 05-13-2008, 10:46 AM   #7
ssz28man's Avatar
see what you think of this, I changed your diagram so that when the truck isn't hot enough to turn the fan on the a/c will still turn it on and get enough air flow to work
Old 05-15-2008, 03:03 AM   #8
ZR2 MIKE's Avatar
I see what you are saying. Thanks man!
Old 05-15-2008, 01:58 PM   #9
ZR2 MIKE's Avatar
How's this look? I took your advice with the diagram mods you showed ssz28man. I like what you did. I also made a few other mods as per some suggestions on another forum. I would like to think is my diagram's final version.
I do have the AC wire on the low side on purpose. I want the AC to run the fan on high only when the radiator gets hotter. The low speed should be more than enough to provide air flow through the ac condenser. And when temps climb, the high speed will automatically kick in. I know it involves a 2nd heat probe but I already have 1 so won't be a big deal to pick up a second one. You will notice optional override switches I included specifically for the 4x4 guys hitting the trails.
Old 05-15-2008, 03:07 PM   #10
Mikz86TA's Avatar
Yeah. basically you need the fan on while the AC is on....even if the operating temp is not high enough yet. Air needs to be drawn across the condenser.
I have mine setup a bit differently. I use a relay to the hispeed side which is triggered off of the adjustable temperature probe and also is ignition-based. I use a seperate relay to the lowspeed side which is triggered off of the AC wire. Still used a diode for safety.
Old 05-15-2008, 04:21 PM   #11
ssz28man's Avatar
that looks like it'll work, might want to put an off override switch in too for the 4x4s so they can keep the fan off completely if their going through mud. don't wanna suck the fan into the rad
Old 05-15-2008, 04:40 PM   #12
ZR2 MIKE's Avatar
Thanks. I think it will work good for my needs. And I did include a fan off switch like you suggested, see the right side of the last diagram on the diagram ground circuit, there is a "Optional Override Switch Fan Off" switch . This switch would interrupt the ground circuit for both relays, forcing the power off to the fan's low and high all together. If you follow the current path, it will dead end at 87a on relay 2.
Old 05-15-2008, 04:47 PM   #13
nolowis2low's Avatar
just make it simple and wire regular fans into a relay and manual switch or to run all the time, i have 2 10in and they cool just fine and have no problems with the amp draw.
Old 05-15-2008, 05:30 PM   #14
ZR2 MIKE's Avatar
Thanks, but I have a 5.7 conversion and it runs hot. Thats a completely different situation that what you are running to keep a 2.8 cool. I just installed a Corvette radiator in the forward position (where the ac condenser normally goes) and installed the Ford Taurus fan in the normal puller configuration. Previously I was running dual 12" pushers and they were not cutting it in the summer when the ac was running in traffic. I upgraded to the AD244 HO alternator as well to handle the efan current draw. I don't want manual switches to HAVE to turn the fans on and off, I want it to work automatically as much as possible like it was factory. Running the efans on all the time is kinda crude and is a lot more wear and tear on the fan motors. You don't need fans to run if your thermostat has not opened yet (unless your AC on on). Or when cruising at 75mph on the interstate. I currently have the Taurus efan running on low speed through a temp probe controller and a 30A relay. It is working flawlessly right now. But it isn't summer and AC time yet. On low, the Taurus efan is moving more air than my 12" dual efans ever did. I can put my hand near the grille and feel the air draw nicely.
Old 05-15-2008, 08:20 PM   #15
ssz28man's Avatar
oh ok I didn't see the ground switch, every thing looks good to me then
Old 05-15-2008, 11:23 PM   #16
well that makes a lot of since now that i know this, and the manual switch isnt to bad if its cold enough i jsut wont turn it on untill it gets warm, and i dont use my AC. I also didnt want to spend the extra 60 bucks for the automatic switch. Also good info to know cause i know some one that is wantin my fans to use on a 5.0 swap and i dotn know if they would even be good enough. but them 2 fans are way more than enough for my lil POS 2.8
But other than that i know a lil bit about wiring and it looks good the way you got em drawn up.
Old 05-15-2008, 11:50 PM   #17
ZR2 MIKE's Avatar
Cool. Thanks Man!
I'm very warm blooded and I would melt with my AC. Truth.
For any V8 swap, I'd recommend doing the Taurus eFan/Corvette Radiator mod first. That way you don't have issues later down the road. My experience and 2 cents advice
Old 05-16-2008, 02:10 AM   #18
ZR2 MIKE's Avatar
melt with out my AC (I meant to say)
Old 05-16-2008, 12:33 PM   #19
Registered (Ab) User
Yogi's Avatar
Nice work, Mike!
Old 05-16-2008, 04:45 PM   #20
yea i dont know how much room you have but this guy i know has almost no room to put any kind of fan on the inside, thats why hes wanntin to use mine as pushers.
Old 05-16-2008, 06:05 PM   #21
Yogi's Avatar
Just reverse the polarity and you can use any fan as a pusher. The blade design might be more efficient as a puller, but it will work as a pusher too.
Old 05-17-2008, 08:27 AM   #22
yea we know how to get it to push, iam just wonderin if he is having space issues like we are?
Old 05-17-2008, 01:18 PM   #23
Dr.Fiero's Avatar
Two suggestions:
1) Put some caps across the relay contacts to lower the pitting/burning.
2) Swap the wiring around a touch so you have power to the relays, and your thermal probe grounds (vs. sending power) the relays. It all works the same way in the end, but then you have much shorter runs of live wires laying around. It's a safety thing. I work with high voltage stuff (generators) and look for that kind of thing every day.
Old 05-17-2008, 03:37 PM   #24
Yogi's Avatar
What size caps?
Old 05-18-2008, 02:02 AM   #25
Dr.Fiero's Avatar
Not really critical - anything you've got laying around - maybe a 1uf or so mylar. It's really optional - might just make the relays live a bit longer that's all.
Old 05-18-2008, 12:08 PM   #26
ZR2 MIKE's Avatar
Thanks for the suggestions. I think I'll be alright without the caps but it is a good idea.
I see what you are saying about switching the wiring around. Would be more close grounds and then run one hot wire to a switch in the dash for the "kill switch" and then to a switched 12V source in the cab? Would have to re-route the AC wire. I don't know. Not really complicated the way it is and easy for a layman to follow it. I'll sit down with it and look at it some more. But you're right, it'll work the same the way it is.
Old 05-18-2008, 12:14 PM   #27
ZR2 MIKE's Avatar
Question for you guys -
On another forum a guy suggested I also put diodes in between each temp probe and the relays to prevent AC line voltage and the optional fan high override voltage from blowing fuses. I told him it was not necessary because the current flows from positive to ground, not back into positive (itself). I don't see how that would be an issue with DC current. Just making sure my thinking is not off here now. Not necessary, correct?
Page generated in 0.63499 seconds with 32 queries
[Output: 135.45 Kb. compressed to 124.67 Kb. by saving 10.77 Kb. (7.95%)]
