Tail light issue
Old 08-04-2008, 08:45 PM   #1
Super Saiyan User
Dragonball98312's Avatar
Dragonball98312 is on a distinguished road
Tail light issue
Alrighty my 89 blazer has tail light issues. I would have problems with the pass side brake light, sometimes it would work sometimes it wouldnt. noticed the connector wouldnt hold the bulb very tight and that maybe it would slip in and out while driving, causeing it not to work all the time. Bought a new connector and it holds the bulb very snug like. everything works great, until i turn on my running lights or head lights. Nothing on the pass side tail light works. checked all my wiring, great. put the bulb in the right way it works, flip it then it and the little middle light turns on. i cant figure out whats wrong, has to be an electrical issue. maybe a short or ground issue somewhere?
Old 08-05-2008, 02:42 AM   #2
Super Saiyan User
Re: Tail light issue
i know its only been a couple hours but, bump
Old 08-05-2008, 02:17 PM   #3
Super Saiyan User
does anyone know what wires under the dash i can tap into to make it work? ill run new wires if i have to. its for the pass side tail light
Old 08-09-2008, 01:58 PM   #4
Super Saiyan User
bump
Old 08-09-2008, 02:16 PM   #5
Neglect
mcaravella04's Avatar
mcaravella04 has a little shameless behaviour in the past
Obviously check all your fuses. Then I would check the passenger side frame rail. The taillight wiring harness has 2 grounds on that side.
Old 08-10-2008, 02:52 AM   #6
Super Saiyan User
checked the fuses and they're good, but ill have to check the whole ground thing. if i was gonna put my money on anything id say ground too.
Old 08-10-2008, 04:09 AM   #7
ohio420jb's Avatar
ohio420jb is on a distinguished road
this may be stupid but check to make sure you're not using one way bulbs.
Also there is a connector for the tail lights right under your feet on the drivers side. Pull back the carpet and make sure of the wires isn't loose/disconnected.
Page generated in 0.11349 seconds with 12 queries
