Tail Light and License Plate Light Problem - S-10 Forum
post #1 of 5 Old 05-24-2006, 12:44 PM Thread Starter
former owner
98SS's Avatar
Location: north of Motor City ... formerly near Memphis
User is: 98SS is offline
Send a message via AIM to 98SS
I backed into a shopping cart recently and it wouldn't have been so bad if the curb hadn't have been there so that I would have just pushed the cart. But no, there was a curb and so I sandwiched the cart between the curb and my roll pan (the cart was laying on it's side which is why I didn't see it). So anyway, I'm pissed because it broke the inner mounting flaps of my stepshavers and bent my license plate bracket. Since the incident my driver's side tail light and license plate light haven't worked. The passenger side tail light works, both reverse lights work, and both brake lights work. Immediately I thought it was just a bad bulb, well, yeah, the bulb was bad, but when I put a new one in, it still didn't work. I tried new bulbs everywhere. I tried checking all the grounds and unbolting them and then retightening them. I checked the harnesses and none of the plugs are undone. I went ahead and unplugged and replugged one that I accidentally ripped off while removing the bed once.
A mechanic friend said that the actual socket for the bulb(s) might be bad. I stripped the wiring going in and out of the license plate light and used a multimeter to test for current when the light should have been on. Nothing. So, that told me that the socket may not be bad, but either way the problem is before the socket.
One thing I've been thinking was that the lights may not be in parallel, and if not, then the socket for the tail light could be bad, but it would have to be in series before the license plate light in order for the license plate light to lose power. Does a Chilton have a wiring schematic in it? I have one but haven't looked yet.
Cliffs
Passenger tail light and License plate lights are out.
All other lights (brake, reverse, etc) work fine
Replaced bulbs and checked grounds.
Lights are still out.
Please help troubleshoot.
Thanks.
- Tim -
1998 S10 LS - stock, lemon - gone
1998 S10 SS - bagged, shaved, etc. - gone
2005 Civic
2010 Equinox
98SS is offline
post #2 of 5 Old 05-25-2006, 07:45 PM Thread Starter
former owner
98SS's Avatar
Re: Tail Light and License Plate Light Problem
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #3 of 5 Old 05-26-2006, 07:51 PM
FUCK YOU
Wicked Mayhem's Avatar
check the fuses for everything? for some reason my dash lights decided to stop working.. and it happened to be dark.. haha it was a fuse..
Wicked Mayhem is offline
post #4 of 5 Old 05-27-2006, 04:28 PM Thread Starter
former owner
98SS's Avatar
Is there a fuse for just the driver's side tail light and/or the license plate light?
The only that has made sense to me is what my Dad was talking about how the two lights have a common ground (which is grounded), and they are wired in series. Somewhere on their power wire, there is a short. But I don't know if this is true because I haven't looked at the wiring diagram.
- Tim -
2005 Civic
2010 Equinox
98SS is offline
post #5 of 5 Old 05-27-2006, 06:02 PM
User is: stuvx is offline
Yeah. Under the hood, top of left front fenderwall. Rear right turn fuse 16 (10A) and Right RR park fuse (10A).
stuvx is offline
