swapping out gauge clusters, need help!
Alright, not sure if this is the right forum for this but i have a 93 s10 and i have a lt1 with a wiring harness built from Currentpeformance and i wanted to know if its possible to swap in a syclone/typhoon gauge cluster. I know they fit in the dash b/c they are the same besides the setup of the actual gauges, but i didnt know if the wiring harness i have would be compatible and vis versa the cluster being compatible. I dont want to go and get one if i can and it not work. I want all the lights, gauges and all to be working soi dont have to have a tach strapped to my steering column, a temp gauge mounted to the dash, ect.
I am looking for a clean look. |
getting shit done
Re: swapping out gauge clusters, need help!
Does any of the factory gauges work now? If they do, then it should swap over. When I went to the digital cluster from analog, all I had to do was swap the cluster connector. I know that the tach would be off but the rest of them should work normal.
getting shit done
Well I assume that the cluster you are using now is the factory cluster for a v6 so the sy/ty cluster should still work. I know that a guy on here is using a digital cluster from a v6 on a v8. All the gauges work correctly except the tach. I have read somewhere that you can change the resistor in the cluster so that the tach will read correctly. I don't know which resistor you would need.
You could always make your own cluster with autometer(or whatever manufacturer you prefer) gauges and get a clean look. All you need is some abs plastic. The only thing I worry about for you is the ability and/or cost of the typhoon/cyclone cluster. It's a rare vehicle and would be hard to find a junker and you definately don't want to buy it from gm. Good luck whatever you do.
Yeah I can understand wanting to stay 'stockish' but i wish i had pics of my dads 85 monte carlo ss before he sold it. i did a custom made cluster in his car with a sheet of abs and his desired gauges(and it blew the stock out of the water, plus we got ss imprint in the gauge). Autometer and most other aftermarket gauge manufacturers make warning lights as well that you can wire up to do the same thing as a 'service engine soon' light, that's what we did. Also you can have your speedo read up to 200 mph and if you have an lt1 than runs good and you drag it ocassionaly it will give you better/more info not to mention you can get mini lights and memorize shift points using them. I will see if I can find you some liks of them and you can compare your options as far as the cyclone cluster goes call your local gm parts supplier and request that item and then ask them for the compatability to your vehicle, they'll tell you whether it works or not. Then go from there.
Calico 1st Gen
llorac, no problem. by buddies tbi 350 blazer had the gauges in it. IFFFF your stock gauges will work, you can get the sy/ty gauges to work, just have fun finding them
Local Tech
get a tach calibrator.... the factory sy/ty tach will read crank speed for a v6, which is not the same as a v8... i have one from autoloc from my lt1. 50 and its urs
