Shunt fuse? - S-10 Forum
post #1 of 1 Old 04-28-2012, 04:04 PM Thread Starter
cowboy_tx_2002's Avatar
User is: cowboy_tx_2002 is online now
Shunt fuse?
1991 S10 Tahoe, cigarette lighter plug quit working the other day. Went to check the fuse and found out that the previous owner had rewired it. (Ran a new wire with a spade connector and plugged it into the empty slot on the fuse box for power windows.)Now I no longer get power from that location on the fuse box. So I guess the original wire is broke behind the dash since the correct fuse for it is good. My main concern is that when I checked the fuses I noticed that I have two fuses that are labeled Shunt. One has power and the other one does not. Searched and couldn't find any info on it. Much less a replacement. Any help?
