Rear Tail light/brake light/turn signal issues - S-10 Forum
Old 12-24-2009, 12:49 PM   #1
"The SUPER"
BigHemi353's Avatar
My right rear brake light and turn signal doesnt work. I have replaced all the bulbs in that tail light last night and still had the same outcome. All my other brake lights work and all my other turn signals work(and hazards wont work either on this right rear). The running light is on when I turn on the headlights but the turn signal and brake light will not function. What can be wrong? and what should I do? is it a bad ground or what? Thank you!
Old 12-24-2009, 01:03 PM   #2
Re: Rear Tail light/brake light/turn signal issues
i would check the ground, I removed my bed and ripped the ground wire out one time and my lights did exactly what you are describing
Old 12-27-2009, 07:54 PM   #3
That same thing happened to mine. It was to conector in the wiring harness above the spare tire.
Good Luck!
Old 12-27-2009, 08:06 PM   #4
rolling work in progress
Mr.woodscrewsNbondo's Avatar
get a test light and find out if your getting power and ground
Old 01-30-2012, 11:21 PM   #5
Hillbilly sold the mini
billybob88's Avatar
i kinda have the same problem.my running lights work but not the brake light or blinker.replaced the bulb..still nothing..my question is, where is the ground wire to the taillight, and could it be a fuse?
Old 02-01-2012, 07:40 PM   #6
lowsdime99's Avatar
There is a ground on each side inside the frame, near where the bumper bolts up. The is a black plug looking connected w a green bottom and that plug should have a single ground wire coming off of it
Old 02-01-2012, 07:54 PM   #7
billybob88's Avatar
alrighty thanks
