Project projector... (HID)
Old 08-09-2005, 06:25 PM   #101
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
Re: Project projector... (HID)
Quote: Originally Posted by Ozwald
Thanks for the diagram!
Here's some options that I've found (aside from buying/modifying the OEM mounting covers <link>):
- Encapsulate it in a generic $3 ABS box, easily obtainable from an electronic component store. The bottom can be left open. This will simulate the protection the LVQ-212 gets in an OEM application. It will be water proof from above. Ballast vent has free air passage down the sides of ballast.
- Dip entire ballast with cables connected in Plasti Dip. Use paint tape to cover vent between the 12V power plug and high voltage wire during dipping. It must not be blocked under normal operation. Components inside creates some heat and without a vent a pressure buildup and condensation might occur.
- If you do not have the time for any of examples above, mount ballast vertically with connectors facing down.
http://faqlight.carpassion.info/
-Kevin
i would love to see my HID guys face when i try to return a bad ballast with that plastic shit dripped all over the ballast and connectors......lol
Old 08-09-2005, 11:43 PM   #102
Canyon Carver
s10cyncrvr's Avatar
s10cyncrvr will become famous soon enoughs10cyncrvr will become famous soon enough
I think I have the water issue solved. Took a plastic tray out of one of my parts bins and cut it up to fit around the ballast. About 1/4 of the bottom is open so it should be enough to vent.
Old 08-10-2005, 12:09 AM   #103
Entrepeneur
rordway1's Avatar
rordway1 is on a distinguished road
wow, thats clean...nice work
about time that tray did something useful :-)
Old 08-10-2005, 03:14 AM   #104
graduated!!!!
Mr Bravada's Avatar
Mr Bravada is on a distinguished road
i dig that tray idea it looks pretty clean too..... did you get the covers/mounts from hidplanet? or did you forgo those for a water friendly instal?
Old 08-10-2005, 10:45 AM   #105
FULL THROTTLE
Licht's Avatar
Licht is on a distinguished road
looks awesome.
Old 08-10-2005, 10:54 AM   #106
Canyon Carver
s10cyncrvr's Avatar
The kit I purchased included the black plastic covers. I think combining those with the clear covers should keep them dry.
Old 08-10-2005, 11:50 AM   #107
flat blue and layin frame
BIGGERISBETTER's Avatar
BIGGERISBETTER is on a distinguished road
I hope i have this kind of patience and attention to detail when i start puttin the bags on this winter. I tend to rush myself.... you on the other hand come out w/ a great looking mod every time. Cant wait to see em mounted
Old 08-11-2005, 04:42 PM   #108
I got nothing...
Ozwald
Quote: Originally Posted by s10cyncrvr
Wiring
$ 4.38 - (2) 12VDC Bosch Relays - www.parts-express.com #330-070
$ 3.00 - (2) 12VDC 5-Pin Relay Socket - www.parts-express.com #330-075
$ 5.70 - (6) Pioneer 12 Ga. In-line Fuseholder - www.parts-express.com #079-040
$ 6.75 - (1) 9005 Male Connector (12 Ga. Leads) - www.rallylights.com CP9005CM
$ 6.75 - (1) 9006 Male Connector (12 Ga. Leads) - www.rallylights.com CP9006CM
$ 16.50 - (2) 9005 Replacement Connector (12 Ga. Leads) - www.rallylights.com CP9005CF
$ 0.89 - (1) 1N4005 Diodes - www.radioshack.com #276-1104
$ 0.99 - (1) 2.2K 1/2W Resistors - www.radioshack.com #271-1121
$ 1.99 - (4) Male Splice Connectors - AutoZone
$ 4.99 - (4) Female Splice Connectors - AutoZone
$ 9.99 - (1) Battery Terminal Ring Connector - AutoZone
$ 1.75 - (1) 3/8" 10' Wire Loom - AutoZone
Aight, sorry for the nOOb question but what are the resistors for? I didn't see them on either diagram. Did you use them? If so where do they go?
Thanks,
-Kevin
Old 08-11-2005, 07:00 PM   #109
Canyon Carver
s10cyncrvr's Avatar
Thanks,
-Kevin
I used a resistor to plug into the Automatic Headlamp Sensor in order to disable it. That way the headlights won't come on automatically everytime it is dark. There is a sticky at the top of the electrical forum showing how to do it.
Old 08-12-2005, 10:38 PM   #110
graduated!!!!
Mr Bravada's Avatar
yea it looks like i am going the same route you did, its my winter project.... so i'll be goin from the blue ebay hids to the fo-sho hella bright valeo projectors.... sweeeet!! Great job though, i'll probably copy the ballast holder idea from you.... it gets mad wet up here when the snow thaws.....
Old 08-12-2005, 11:48 PM   #111
Canyon Carver
s10cyncrvr's Avatar
Cool. I'd like to see how other people do these in different styles of headlight buckets.
I got everything put back together yesterday and tried them out last night, and I didn't like it. One of the projectors was a couple of degrees off and the flare from the ECE cut-off shields was too high. I was worried about blinding people to the right of me. So I tore both headlights back apart and rotated the one projector a bit and used some aluminum tape to flatten my cut-off line. I am much happier with the results I got tonight. Onto the pics...
I used my 97 S-10 truck for the "stock lighting" pics since it still has the factory lighting on it. All of the following pics were with the camera on a tripod in the same position. The vehicles were parked in the same position as well.
Stock lighting - Low Beams
HID lighting - Low Beams
Stock lighting - High Beams
HID lighting - High Beams
Overall I am quite happy with the new lighting. Is it worth the money for most people, probably not. But it does offer a huge increase in visibility and a touch of class for trucks that are at the bottom of the price range. I am extremely pleased at the output of the HIR bulbs that I used for the high-beams. These things put out an amazing amount of light in a reflector housing. The only downfall is they still have the yellowish-white color of a halogen bulb.
Old 08-17-2005, 04:53 PM   #112
holy shit thats bright! wow. haha!
Old 08-17-2005, 05:00 PM   #113
I got nothing...
Ozwald
I love the cut-off!
-Kevin
Old 08-17-2005, 05:03 PM   #114
<Insert Title Here>
99ZR2's Avatar
99ZR2
looks good..lots of light!
Old 08-17-2005, 05:59 PM   #115
bristol16's Avatar
bristol16
nice job man. i love the results!
Old 08-25-2005, 11:37 PM   #116
Tucker is mah name
-Tucker-'s Avatar
-Tucker- is on a distinguished road
It kinda looks like the ballast accepts the 9006 plug, is that true?
Old 08-26-2005, 12:02 AM   #117
Canyon Carver
s10cyncrvr's Avatar
Yes, it is a 9006 plug.
Old 08-26-2005, 12:10 AM   #118
Tucker is mah name
-Tucker-'s Avatar
Good Deal. I'm starting up the Wiring harness as soon as I receive the parts I ordered today. I'll have some time between now and HID, so it's good news that I can use the 9006 without having to fab it again later.
Old 08-26-2005, 09:27 AM   #119
looks good..i still have no idea how you keep your wheels so pretty!
Old 08-26-2005, 04:28 PM   #120
Canyon Carver
s10cyncrvr's Avatar
So far this year...
Old 08-26-2005, 04:30 PM   #121
you went tru 4 cans...damn...and you do it all by hand...no wheel right?
Old 08-26-2005, 04:39 PM   #122
Canyon Carver
s10cyncrvr's Avatar
I do the backs of the wheels with the powerball but all front surfaces are done by hand. I try and do them every two weeks during the warm months.
Old 08-27-2005, 12:03 AM   #123
Baby Blue > Joo
DNGRS DME's Avatar
DNGRS DME
Jebus, that's like $50 worth of polish!
The HIDs look awesome!
Did you have any problems aiming them?
Old 08-27-2005, 02:27 AM   #124
Canyon Carver
s10cyncrvr's Avatar
The one headlight housing is still a little crooked(where the bracket meets the housing). Cheap Taiwann parts. I have to re-attach and straighten that out but aiming them was a breeze. As long as the projector is sitting squarely in the housing, they can be adjusted with the factory screws.
The rule of thumb is that from 25 feet away, the top of the cut-off line should be 2" below the height of the projector.
Old 09-02-2005, 02:37 AM   #125
Your mom goes to college!
norcalx's Avatar
norcalx is on a distinguished road
Dude, you've just blown me away with this thread. My hat is off to you sir. What an amazing job you did on this project. I wish I had the time, and the patience to do a fab like this. I also wish someone would market a kit, complete, for our trucks.
In any event, I just wanted to recognize you for this. Great job!
Will
Old 09-02-2005, 04:12 AM   #126
graduated!!!!
Mr Bravada's Avatar
once again looks great man, the cut-off was awesome.... thats what i'll be shooting for when i get back from my cruise in october
Old 09-17-2005, 10:57 AM   #127
Canyon Carver
s10cyncrvr's Avatar
Thanks guys. I just picked up some more parts to do a fog light set-up in my bumper. A Bosch Projector (early-00 BMW's) and 3000K Phillips bulbs. This time around I'll have to make a housing for the projector to sit in so it should be more informative to GMC owners who don't have a projector housing available like the 98-up S-10's.
It'll be a couple of weeks before I start on it but I hooked everything up to make sure it all works. Took a few pics...
Old 09-17-2005, 11:11 AM   #128
yellow??
i love me some yellow fog lights....
looks good man...
Old 09-17-2005, 12:44 PM   #129
2high & 2slow
WTRacing's Avatar
WTRacing is on a distinguished road
SWEEt, cant wait to see how it turns out
Old 09-17-2005, 12:49 PM   #130
2high & 2slow
WTRacing's Avatar
ive got a 97 s-10 wit the blazer (compostie) lights, do that make anything to do it "right" without a projector or do i have to run a projector to make it look right?
