#51 |
Canyon Carver
Re: Project projector... (HID)
I hooked up one of the bulbs to a portable battery pack to try them out. I noticed that the adaptor plate I made earlier was to thick to be sitting between the cut-off shield and the lense. I was getting a large flare from it. So I moved the adaptor plate to the back of the projector and stuck 1 washer on each corner between the lense and the cut-off plate. This gave the cut-off line a bit more color.
![]() ![]() ![]() Here was a finished pick of the halo. I cut the mount off and smoothed the entire area over again to help reduce the light at the top. ![]() |
#52 |
Tucker is mah name
Hey man. Did you buy a complete retro kit from hidplanet, or just piece some things together?
If you got the retro kit, which one did you get? |
#53 |
Canyon Carver
#54 |
Tucker is mah name
ahhh, same one I am eyeing up. What temperature is the bulb rated at? Did they give you a choice also?
#55 |
Canyon Carver
#56 |
Entrepeneur
got them in today, won;t be doing this project for a while, your HL's a worth a little bit more than the ones on ebay now :-), time for some night full on pics
#57 |
flat blue and layin frame
Haha. You've got a ton of patience. Looks really sweet.
#58 |
FULL THROTTLE
Location: Clinton Township/Midland MI User is: OffLine ![]() |
Jeremy you are an awesome fabricator. I love what you have done with your truck and with this project, great work!
#59 |
B&B Customs
Location: Rolling in the Midwest in the Driftwood Metallic S10 User is: OffLine ![]() |
I got a question I already have HIDs and if I was to go puy a set of projectors what all would I need to do this?
#60 |
Canyon Carver
Since you don't have projectors now, you probably have a D2R bulb. The following was taken from HIDPlanet... So now that you know about kelvin and some aspects of the bulbs, you might be wondering why you hear the terms D2R or D2S. Well, to put it very simply to you, D2R is a HID bulb that was designed for HID reflector housings. It has a different base than a D2S and also has a painted portion on the bulb itself. Why is it painted you ask? The paint is there to block certain areas of the bulb that would cause excessive glare in the housing. Does the paint affect bulb performance? Yes. A 4100k D2R has slightly less lumen than a 4100k D2S. Can a D2R be converted to a D2S? Yes. You would have to make a notch in the base of the bulb to match that of a D2S. you would also need to delicatly remove the painted portion of the bulb so that it would be completely visible just like a D2S. So enough about a D2R ehh, lets talk about the D2S for a sec. The D2S was designed soley for a HID projector applications. They are completely clear and give out the most efficiency of the two. Thats pratically all there is in difference between those two bulbs Below are some pics of both. http://img.photobucket.com/albums/v1...s/untitled.gif D2R http://img.photobucket.com/albums/v1...20pics/d2s.gif D2S |
#61 |
FULL THROTTLE
I think I'll be buying a set of Projector Housings...
#62 |
graduated!!!!
thats hot, turned out damn good!! i think i may have to sell my current HIDs to get the cash for the valeo kit, good how-to! def. something that i will have to do in the future... like before winter,
would you be will to avail your services to other forum members? i think that your cut off was dead on, some of the other retros i've seen were off, and rather than chance it i would be happy to pay you to do it for me too, shoot me a PM if you are willing to do a retro for others. Looks great, much props!!! |
#63 |
I'm a huge ass
thats amazing!
my friend you are an S10 god! mad props keep us posted! id love to see it finished! |
#64 |
it's about damn time someone decided to do HIDs the right way. i hate browsing HID thread after HID thread about people who bought some damn crappy 9006 kit off ebay and just tossed them in their stock headlight housings and then think they are the shit cause of it regardless of the fact their light output went down, their nighttime eye fatigue went up, and people comming the other way can't see shit. props to someone finally doing it the right way.
i was looking for a decent set of ECE E46 projectors a few months ago cause i was gonna do an A6 retro into my stock jimmy headlight housings, but i don't have the funds to do it. i wanted those projectors with Hella Gen 4 ballasts and 4100K bulbs for the best light output. the other problem i would have would be the ridges on the inside of the headlight housing, gotta get those sanded down. this was a good thread to read, and definately a nice break from the rest of the HID threads on this site. |
#65 |
<Insert Title Here>
#66 |
#67 |
Canyon Carver
Basically that cut-off line was the way it came. I added one washer thickness between the cut-off shield and the lense to give it a bit more color but other then that it was straight out of the box. It seemed like the more I messed with it, the more out of focus it became. ---------------------------------------- I got most of the items to build the wiring harnesses, just waiting on one package which should come tomorrow. Hopefully I can get them working by the end of the weekend. |
#68 |
Registered Asshole
looks awesome!
#69 |
graduated!!!!
yea i found some for sale on hidplanet and the deal sounds sweet, i am def. in for either you to do a retro if this doesn't pan out for me....but yours does look great though! keep up the work, if i get the ones from hidplanet i have to add some halos though.....which i think shouldn't be too hard
#70 |
there was a writeup i saw a long time ago about some guy and a civic i think that made his own halos. all he did was take flexible plastic tubing, cut little slits into one side. i am not sure if he even cut all the way through or if he just scratched the tubing. but then he put two LEDs into the tubing, one facing each direction, and they came out pretty well. i will go see if i can find a link. i stand corrected, it wasn't flexible tubing...i guess it was a blind adjustment rod. here is a really good how-to though: http://www.crx.lt/content.php?article.13 Last edited by bristol16 : 07-29-2005 at 08:24 PM. |
#71 |
S-series addict
Wow looks really good
#72 |
Entrepeneur
got mine on now, they are no where as bad as everyone said on visibility but if they arnt adjusted right the 'cut off' light wont be even and that kinda looks dumb.
#73 |
graduated!!!!
thanks for the link.... thats soooo easy.... i may try that out depending on what goes down in the next few......
#74 |
Resident A-10 Crewcheif
Location: Springfield,MO and Whiteman AFB,MO User is: OffLine ![]() |
Thats kinda how I made my 2. I accually cant use them anymore cause I messed up one of my headlights. They are red and I will sell them for $35 shipped.
#75 |
Canyon Carver
#76 |
Entrepeneur
just 2 in my album but they are not visibility ones. the only issue I am having is one light isnt super tight on the mounting bracket and when i hit bumps it seems to flutter and its annoying as hell, I need to check all the screws and what not. I just ordered PIAA Superwhites off of Ebay for now. I don't have the cash for the real projectors now. I need SS mirrors and a winter beater.
#77 |
Canyon Carver
Today I disabled the DRL and AHL. This is an easy process and can be found in the stickys at the top of the electrical forum. This is important to do so that your headlights are not being turned off and on everytime you start the truck.
Got the other projector mounted in the other headlight and started making the new wiring harness. I'm still waiting on a couple connectors to finish it. After that I'll be able to temporarily mount everything and align the projectors. Here is a wiring diagram of the new harness. This is for both the high-beams and the low-beams. The 9011 bulbs would've plugged into the stock wiring, but I decided to make a new harness while I was at it. From what I've been told, it'll boost the output of halogens due to the smaller gauge wire and shorter distance. ![]() Here is a parts list of everything needed to do this conversion... Parts $445.00 - Valeo HID Kit(Projectors, Bulbs, Ballasts) - www.hidplanet.com $127.99 - Projector Headlights - www.ebay.com $ 59.98 - (2) 9011 HIR High-beam Bulbs - www.ebay.com Wiring $ 4.38 - (2) 12VDC Bosch Relays - www.parts-express.com #330-070 $ 3.00 - (2) 12VDC 5-Pin Relay Socket - www.parts-express.com #330-075 $ 5.70 - (6) Pioneer 12 Ga. In-line Fuseholder - www.parts-express.com #079-040 $ 6.75 - (1) 9005 Male Connector (12 Ga. Leads) - www.rallylights.com CP9005CM $ 6.75 - (1) 9006 Male Connector (12 Ga. Leads) - www.rallylights.com CP9006CM $ 16.50 - (2) 9005 Replacement Connector (12 Ga. Leads) - www.rallylights.com CP9005CF $ 0.89 - (1) 1N4005 Diodes - www.radioshack.com #276-1104 $ 0.99 - (1) 2.2K 1/2W Resistors - www.radioshack.com #271-1121 $ 1.99 - (4) Male Splice Connectors - AutoZone $ 4.99 - (4) Female Splice Connectors - AutoZone $ 9.99 - (1) Battery Terminal Ring Connector - AutoZone $ 1.75 - (1) 3/8" 10' Wire Loom - AutoZone Hardware $ 1.58 - (8) Machine Screws 10-24 x 2-1/2" - Hardware Store $ 3.95 - (200) Flat washers SAE #10 - Hardware Store $ 3.99 - (1) JB Weld - Hardware Store $ 9.79 - (1) Aluminum Flue Tape - Hardware Store(HVAC Section) $ 19.98 - (2) Plastic Welding Helmet Lenses - Hardware Store Extra $ 3.00 - Tax $ 80.00 - Shipping TOTAL $ 818.94 |
#78 |
<Insert Title Here>
Not a bad price. There was a site that does retrofit headlights and I asked about mine, it's around that same price range. Too rich for my blood though, but if I had the money, I'd do it. It looks so awesome!
Rordway1, dude those angel eyes look awesome. I wish I still had mine...those pictures make me miss them. I'll give you $10 for those. ![]() Last edited by 99ZR2 : 08-02-2005 at 12:34 AM. |
#79 |
rusty bumper member
this looks awesome...and congrats on getting into reader's rides in Truckin!
#80 |
Canyon Carver
Posts: 2,793 Location: Columbia, IL Us |
