Project projector... (HID)
Old 07-19-2005, 02:43 AM   #1
Canyon Carver
s10cyncrvr's Avatar
s10cyncrvr will become famous soon enoughs10cyncrvr will become famous soon enough
I'm finally going to make the jump to true HID lighting. I'm tired of the horrible lighting from the ebay projector housings...
They don't light the road up well enough with halogens and sticking a HID bulb in them will only cause an uneven light pattern and blind oncoming drivers, so I'm going to convert them the right way.
My plans are to...
- Replace the projector housing with a new HID housing and bulb(retro-fit).
- Build a wiring harness to provide the correct power to the new lights.
- Disable the DRL
- Do some customizing on the angel eye to make it look better at night.
I'm going to run a Valeo HID kit for the low-beams and the stock Halogens for the high-beams. The new harness will allow the low-beams to stay on when the high-beams are turned on. The only real way I could have run HID high-beams were to use a Bi-xenon where the cut-off shield(on the low-beams) is motorized out of view when the highs are turned on. I was worried about the reliabilty of this set-up, so I stuck with a more simple route.
Stock projector housing
First I took off the chrome trim piece around the headlight. There are 5 tabs that hold it in place. You have to carefully pry up on the tabs and slowly work it off towards the front of the light.
Next, there are 4 clips that hold the lense and the housing together. Remove these with a small screwdriver.
You're now ready to pry the lense away from the housing. To do this either put the headlight in the oven or use a blowdryer to soften the glue. I used the blowdryer. It took a little longer since I could only do small sections at a time, but I felt it was safer in the long run. I use a couple of puddy knives and slowly worked my way around the housing using the blowdryer to soften the glue. After the lense is off, everything else can be taken apart with a phillips screwdriver.
Here is a shot of the inside of the projector housing...
A lot of this is new to me, so this project might take a while and may have a few curves thrown in, but I've been doing a lot of research and plan on doing a lot more. Basically what I'm saying is, don't follow me just yet.
I ordered my new projectors today, so as soon as I get those I'll be able to get to the major work.
Old 07-19-2005, 02:49 AM   #2
Registered Asshole
Lowsonoma03's Avatar
Lowsonoma03 is on a distinguished road
Re: Project projector... (HID)
this looks like its gonna be an interesting project. I sorta liked my s-10 front end with the halos, but like you said they didnt throw light to the road that well. So needless to say i'll keep tabs on this project. I've always loved your truck. I'm torn between "bag and drag" and speed.
Keep up the good work man!
Old 07-19-2005, 03:10 AM   #3
The Dave
xxosiris9xx's Avatar
xxosiris9xx is on a distinguished road
this should be good
Old 07-19-2005, 03:25 AM   #4
Time to finish
LT250's Avatar
LT250 is on a distinguished road
speed cost money. and tickets cost more money.
Old 07-19-2005, 03:26 AM   #5
Photoshop Junkie
mr. visual's Avatar
mr. visual is on a distinguished road
very cool, i'm anxious to see how this goes.
Old 07-19-2005, 10:14 AM   #6
Ғяeªκin Яicªn's Avatar
Ғяeªκin Яicªn is on a distinguished road
i was about to order some off of ebay too. i emailed them and asked them how bright they are and he said "they are brighter than stock lights and you can jusy change the bulb to something brighter if you want". probably fkn lying. so in your opinion they arent good to get?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7985944299&catego ry=33710
Old 07-19-2005, 10:59 AM   #7
Canyon Carver
s10cyncrvr's Avatar
Those are a different style then mine so I can't really comment about them. The problem with these were that they were too focused. There were 2 very bright "hot spots" on the road, but the other areas of the road had very little light. I tried different bulbs but couldn't get them any better. I could see better with an aftermarket bulb in my stock housings. Just from what I've been reading, it seems a majority of the aftermarket projectors with halogens are like this.
Old 07-19-2005, 11:03 AM   #8
Baby Blue > Joo
DNGRS DME's Avatar
DNGRS DME
Awesome! I'm so glad someone is finally doing this. If i still had my 99 and i had the cash for the Valeos i would've done this too.
Keep the pics coming!
EDIT: You've probably already been there, but the www.hidplanet.com forums are helpful for retro information
Old 07-19-2005, 11:32 AM   #9
un banned
Baggd's Avatar
Baggd is on a distinguished road
hmmmmmmmm....
Old 07-19-2005, 01:02 PM   #10
FULL THROTTLE
Licht's Avatar
Licht is on a distinguished road
Great Project... I love your truck. I want to do the SSBC upgrade next year it looks great, and improves braking.
Old 07-20-2005, 12:25 AM   #11
Canyon Carver
s10cyncrvr's Avatar
Yeah, that place rocks. I have learned a ton from poking around on that forum.
While I'm waiting, I decide to sand off all the lettering and numbering along with the 3 nubs left over from when they cast the lense. I wanted a completly smooth lense. The script was on the inside of the lense so a quick 1000/1500/2000 grit sanding eliminated them. Then a lot of polishing to eliminate the scratches.
Before...
To sand off the casting nubs I first put some tape around them to protect the adjacent areas of the lense. Then took a 40 grit flap-wheel on my grinder and carefully ground them down to about 1/16".
Removed the tape and sanded the remaining highspots with 1000 grit.
Then resanded at 1500 and 2000 grit.
Fianlly a couple of polishings with my Mothers Powerball using Griots Machine Polish 2. Followed up with a coat of wax.
Old 07-20-2005, 02:05 AM   #12
sawzall's are cool
ohsolos10's Avatar
ohsolos10 is on a distinguished road
got to see this i hate my projectors
Old 07-20-2005, 02:11 AM   #13
98pewterdime's Avatar
98pewterdime is on a distinguished road
off the topic a lil but your truck is bad ass dude...
Old 07-20-2005, 02:13 AM   #14
In For Paint
tootsie roll's Avatar
tootsie roll is on a distinguished road
Signed up now!!!
Old 07-20-2005, 02:18 AM   #15
Registered Asshole
i second that!
Old 07-20-2005, 05:57 PM   #16
Tucker is mah name
-Tucker-'s Avatar
-Tucker- is on a distinguished road
Subscribed also. I love what you are doing. During the winter, I plan on doing the same thing to mine.. only I don't currently have projectors...
Old 07-20-2005, 11:06 PM   #17
graduated!!!!
Mr Bravada's Avatar
Mr Bravada is on a distinguished road
thats nice, same project that i will be starting when i can get a hold of an s10 front....
Old 07-20-2005, 11:07 PM   #18
graduated!!!!
Mr Bravada's Avatar
there is a member of blazinlow with that mod done.... he has picks but i like it like this in the how-to layout
"subscribes"
Old 07-20-2005, 11:39 PM   #19
Canyon Carver
s10cyncrvr's Avatar
My new lights shipped today, so hopefully they'll be here soon. In the meantime, more small stuff.
Worked on the changing the halos into angle eyes tonight. I love the way some BMW's look with the section missing out of the halo, so I wanted to try and replicate it. Here is the before picture...
There are 3 small phillips screws and a tie wrap on the wires to hold the halo onto the mount. After taking it off you can see the parallel ridges around the entire length of the halo. These reflect light from the 2 LED's on bottom all the way around the halo. Without the ridges it won't light up.
I marked out the area where I no longer want light, and proceeded to file down the ridges. They are about 1/8" deep. After they were gone, I worked my way up through the grits until it was smooth. Any small scratches in the plastic will still reflect light so its important to get it as clear as possible. Since the picture is a little blurry, the green arrows represent the start and stop points for the smoothed area.
Here is what they currently look like. There is a noticeable darkness where they have been smoothed. There is still a bright spot on the very top where the screw hole is at that I want to work on some more(red arrow in the above picture). I have decide to cut that mount off completly and smooth it over. It should reduce most of the light that is still reflecting. Unfortunetly, there will still be a dot of light where the screw hole is at.
Old 07-20-2005, 11:40 PM   #20
Canyon Carver
s10cyncrvr's Avatar
"subscribes"
Thanks man. I'll have to check that out.
Old 07-21-2005, 12:08 AM   #21
Xtreme Measures
xtrememeasures10's Avatar
xtrememeasures10 is on a distinguished road
Awesome dude. im looking foreward to seeing how the HID goes. im planning on doing this swap with my projectors as soon as i can afford it. My projectors spread the light more evenly than yours though. there arent 2 hot spots. My only problem with doing this swap is i dont have stock 98+ headlights. Soo i would need to borrow some headlights from someone while i do the swap. i could do it w/ my next pay check but i dont want to buy headlights just for the swap.
Old 07-21-2005, 02:40 AM   #22
graduated!!!!
Mr Bravada's Avatar
his s/n is otter
Old 07-21-2005, 02:46 AM   #23
graduated!!!!
Mr Bravada's Avatar
search HIDplanet and there was a retro done to a blazer with the TYC headlights.... its hot looking but i like the way the halo's look in these lights, this is the route i wanna go too
Old 07-21-2005, 02:54 AM   #24
graduated!!!!
Mr Bravada's Avatar
http://hidplanet.com/forums/viewtopic.php?t=8818&highlight=retro+fit+s10+blaze r
Old 07-21-2005, 11:31 AM   #25
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
you have WAY to much time on your hands man...
why do you not want it all lit up?
Old 07-21-2005, 12:00 PM   #26
Canyon Carver
s10cyncrvr's Avatar
I love how agressive looking these are...
Old 07-21-2005, 04:51 PM   #27
Tucker is mah name
-Tucker-'s Avatar
10-4 good buddy. those look kick ass. You moving leds from white to a diff color at all?
Old 07-21-2005, 05:09 PM   #28
Canyon Carver
s10cyncrvr's Avatar
The ones that I have now are blue. They do look white in that picture though. I think I took the picture too close to the light.
Here is an old shot of mine...
Old 07-21-2005, 05:30 PM   #29
S10Blazer98's Avatar
S10Blazer98
That is looking real good so far...... cant wait to see it when it is all finished
Old 07-24-2005, 03:11 AM   #30
cruisin140
cruisin140's Avatar
cruisin140 is on a distinguished road
is the halo ring on the light are they led lights on that
Old 07-24-2005, 12:43 PM   #31
Canyon Carver
s10cyncrvr's Avatar
