Problems with side post battery terminal - S-10 Forum
post #1 of 18 Old 10-15-2009, 02:54 PM Thread Starter
User is: onecrazyfoo4u is offline
So I have a 5 year old side post battery, not sure on brand or specs though. It's in my 84 auto, 2wd, s10 blazer (3.4l engine). I just did the big 3, and now I can't get my + terminal off, it spins, and I can see the bolt or whatever, inside the battery spinning with it. Is there any way to get it off?
It's really loose inside the battery. And it keeps coming unhooked internally. My truck acts dead everytime I try to start it, but once I jiggle the + terminal, it'll fire right up (and I can hear a nice spark when it gets connection again, is that okay?). Any way to fix this?
Also, it's probably about time for a new battery anyways, can I just get a normal top terminal setup battery? What's a good model brand/number, and what specs should I look for, for CCA and so on? I only have a 1200 rms watt amplifier, so I shouldn't need anything like an optima, just generic costco brand would work for me!
post #2 of 18 Old 10-15-2009, 03:16 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
Re: Problems with side post battery terminal
Time for a new battery
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #3 of 18 Old 10-15-2009, 05:08 PM Thread Starter
Is it a common thing for the inner nut to come loose on these side terminals? What are the recommended specs for a good replacement battery?
post #4 of 18 Old 10-15-2009, 08:54 PM Thread Starter
So I was able to jiggle the terminal and get it to start. Drove it home, but it acted weird the whole time. The voltage was fluctuating constantly from 12-15v. I'm assuming that's cause it's running off of just the alternator, and that the battery goes loose?
Is that going to hurt anything driving like that till I can get a new battery? Does that mean my alternator is bad too, since it was fluctuating so much? (I had to have the a/c and lights on to keep it around 14).
post #5 of 18 Old 10-16-2009, 09:05 AM
Been around the block
CatDaddy52's Avatar
User is: CatDaddy52 is offline
You are getting intermittent connection to the battery.....you will ruin your alternator if you keep running it like that. Just get a new battery!!!
post #6 of 18 Old 10-16-2009, 12:48 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
New battery ASAP or you will have other problems.
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #7 of 18 Old 10-16-2009, 01:53 PM
drummerdude89's Avatar
User is: drummerdude89 is offline
The terminals on the battery will come loose if you over-tighten the bolts when you connect it. When you get your new battery you wanna make sure they're snug, but not impossibly tight either
1993 4.3L V6 TBI S10
post #8 of 18 Old 10-17-2009, 03:31 AM Thread Starter
Yeah, I'm getting another battery tomorrow then. Don't want to damage my alternator at all. Is it normal for an alternator to do that and have varying voltage without a battery connection? Or is that the sign of a bad alternator?
The battery I have now is a model # 78, does that sound like the correct one? Can I upgrade to a bigger size, what model # is it?
post #9 of 18 Old 10-17-2009, 09:06 AM
992drjimmy's Avatar
Depends where you get the battery from. A 78 series is typically the biggest you canget in there. If you are getting a parts store battery, The duralast gold 34 series with top and side post is the biggest you can get in there. It will fit but youll need a shoe horn
post #10 of 18 Old 10-17-2009, 11:04 AM Thread Starter
Okay cool, I was going to try a costco one, had really good luck in the past with them. I'll look out for a 34 series though....and what's a shoe horn? Thanks.
post #11 of 18 Old 10-19-2009, 03:32 PM
992drjimmy's Avatar
By shoe horn, I meant you are really going to have to wedge that thing in there. I think its 900 CCA. It will fit but you have to turn it justthe righ angle toget it in and if i remember right, remove theradiator cap.
post #12 of 18 Old 10-19-2009, 06:35 PM
Mine Sweeper!
juddspaintballs's Avatar
User is: juddspaintballs is offline
Send a message via AIM to juddspaintballs
At some point, the terminals either got overtightened or cross-threaded. They don't just come loose. Did you not go with extended posts when you did the Big 3?
The alternator will spike when it suddenly goes from a load to no load. Get the new battery now or you're gonna fry your alternator.
Opinions are like assholes: everyone has one and they all stink.
My Audio Build Thread
Originally Posted by juddspaintballs
radio shack didn't have the pot i need and the guy there didn't know shit
Originally Posted by Sir Toad
i never bought pot at radio shack
post #13 of 18 Old 10-20-2009, 01:23 AM Thread Starter
Thanks guys, just got the new battery tonight...got a Kirkland brand from Costco, #78....800 cca and 1000 ca, that ought to do the job!
I actually do have the side post extenders, just over tightened them I guess. I was real gentle this time!
I measured at voltage of the new battery off and it was 14.5 volts, then when I turned it on, me voltmeter said I was getting 16 volts! I'm hoping that will go down just since it's a new battery (my aftermarket gauge inside still read 14 running). Unless my alternator is already jacked or something...
post #14 of 18 Old 10-20-2009, 10:13 AM
992drjimmy's Avatar
The side posts will strip before you break them off inside. They do rot with age. I used to see this all the time when i managed parts store.
post #15 of 18 Old 10-20-2009, 08:07 PM Thread Starter
Yeah, mine didn't actually strip, I had to pull the side post out with the internal battery nut still attached! It was 5 years old though...
post #16 of 18 Old 10-23-2009, 03:29 PM Thread Starter
So my voltmeter is still fluctuating will driving. It goes from 13-15, never holds steady if I'm just driving steadily down the road. Is that signs of a bad alternator? What's the stock amperage on a 2.8l or 3.4l alternator?
I don't need a huge 200amp or anything, will probably just go up to a 105 amp or something. I only have a 1200 watt rms system, no external lights or anything...
post #17 of 18 Old 10-28-2009, 10:50 PM
User is: nstoolman1 is offline
To answer your question.
Shoehorn
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A metal shoehorn.
A shoehorn, sometimes called shoespoon, is a tool that allows the user to put on a shoe more easily. It does so by keeping the shoe open and by providing a smooth surface for the foot and particularly the heel to move, without crushing the shoe's counter (the vertical portion of the shoe that wraps around the back of the foot), in this way acting as a first class lever.
Originally, shoe horns were made from animal horns and some made from bulls' horns are still available for purchase. Today plastic and metal are now most often used. They were also made of glass and even paper. Expensive shoe horns were made from ivory, silver, shell, animal horn or bone.
post #18 of 18 Old 10-29-2009, 01:34 PM
992drjimmy's Avatar
Get that alternator checked. A bad battery can ruin an alternator.
