power side mirrors not working need help - S-10 Forum
post #1 of 6 Old 05-01-2008, 02:52 PM Thread Starter
User is: MikeInCtown is offline
I have a 2001 GMC and the power mirrors are not working on either side. I can understand one going bad, but neither morror will move in any direction. I have tried to find the fuse but neither box has this labeled. (don't have a manual) I'm going to assume that the switch is bad or it's not getting electricity. I don't know if there is a relay though, so if anyone has any experience please let me know.
post #2 of 6 Old 05-01-2008, 04:31 PM
ssz28man's Avatar
User is: ssz28man is offline
Re: power side mirrors not working need help
it could be the fuse, but more likely the switch, all I can say about the fuse is check all of them, or post back with what kind of truck it is and I can tell you which fuse it is.
ssz28man is offline
post #3 of 6 Old 05-01-2008, 07:03 PM Thread Starter
It's a 2001 GMC Jimmy 4x4. It's not the Envoy but does have the power drivers seat (no leather though) As far as I know the only other thing it doesn't have is the heated seats. The mirrors supposedly are heated as well but I am just getting the vehicle and it hasn't been snowing around here in a month. We pulled quite a few fuses and didn't find anything burnt, so I'm willing to bet that the switch went as well. Will try to find power though before I pull the door panel off and disassemble everything.
post #4 of 6 Old 05-01-2008, 09:26 PM
ssz28man's Avatar
the fuse your looking for if #7 in the dash fuse panel, mir/locks 5 amp. at the switch, orange wire should be power black should be ground. If those are good then it's the switch
ssz28man is offline
post #5 of 6 Old 05-02-2008, 06:57 AM Thread Starter
Thanks. I remember seeing the door lock label on the fuses, but it said nothing about mirrors. That explains it and will check. Thanks.
post #6 of 6 Old 05-03-2008, 02:00 PM
forum idiot
orangesonoma's Avatar
my 98 blazer had the same issue...turned out to be the switch in the door...best way to check is to find someone with the same truck 98+ and will work
and swap the switch...it will take you 5 mins
Brian
orangesonoma is offline
