overhead console wiring help! - S-10 Forum
post #1 of 66 Old 07-21-2009, 08:21 PM Thread Starter
lwrd93's Avatar
User is: lwrd93 is offline
Send a message via AIM to lwrd93
ok so i have talked to a couple of ppl about this and cant get it figured out so im gona make a thread hopping someone knows whats wrong or how to fix it..
i have the short ohc with mode.. has a 8 pin and 4 pini for homelink and dome.
the 8 pins are these colors and whats next to them is where there connected at..
yellow -- behind radio pin 9
black/white -- on the radio ground
green -- vss pin 16
green/black -- temp sensor
gray -- inst panel voltage pin 7
brown -- dimming pin 6
orange -- 12v constant pin 10
purple -- data 2 under dash at the bcm
lwrd93 is offline
post #2 of 66 Old 07-21-2009, 08:45 PM Thread Starter
lwrd93's Avatar
Re: overhead console wiring help!
Oh yah forgot to say it comes on for about 5 secs then goes to C --
lwrd93 is offline
post #3 of 66 Old 07-22-2009, 06:16 PM Thread Starter
lwrd93's Avatar
anyone?
lwrd93 is offline
post #4 of 66 Old 07-22-2009, 09:11 PM
BTE
LS1 powa!
BTE's Avatar
User is: BTE is offline
C means the compass needs to be calibrated. Go drive in circles in a parking lot until it displays the direction.
Is the temp sensor hooked up?
BTE is offline
post #5 of 66 Old 07-22-2009, 09:24 PM Thread Starter
lwrd93's Avatar
yah its hooked up.. but shouldnt the temp still stay on longer than 5 secs if the compass isnt calibarated?
lwrd93 is offline
post #6 of 66 Old 07-22-2009, 09:40 PM
BTE
LS1 powa!
BTE's Avatar
so it all comes on and turns completely off except for the C--?
BTE is offline
post #7 of 66 Old 07-22-2009, 10:18 PM Thread Starter
lwrd93's Avatar
u can still flip threw all the mpg etc but its blank or say 0.. it comes on for 5 secs and u can flip threw it and will say like 1.2 sometimes.. but after 5 secs it all 0 and blank and the temp part says C -- degree F
lwrd93 is offline
post #8 of 66 Old 07-22-2009, 10:19 PM
capspauld's Avatar
User is: capspauld is offline
What year is your truck and what year did the console come out of??
Originally Posted by Dogsofjune View Post
I race slower vehicles, by comparison, my truck seems fast.
Sorta like hanging out with people fatter than you.
post #9 of 66 Old 07-22-2009, 10:19 PM
BTE
LS1 powa!
BTE's Avatar
is the truck running or just in the ON position? try driving around for a little while and see if the values change.
BTE is offline
post #10 of 66 Old 07-22-2009, 10:24 PM Thread Starter
lwrd93's Avatar
i start the truck then hold both buttons down and then says 6 for texas keep holding it says C -- and i drove around..
lwrd93 is offline
post #11 of 66 Old 07-22-2009, 10:27 PM
BTE
LS1 powa!
BTE's Avatar
6 should be the zone you are in for the compass to read properly.
So after you drove around, none of the values change?
BTE is offline
post #12 of 66 Old 07-22-2009, 11:11 PM Thread Starter
lwrd93's Avatar
Its in 6.. I drove it nothing changes but as soon as I start it for 5 secs I can flip threw and it shows where I juat drove.. Then goes back to 0 and C--
lwrd93 is offline
post #13 of 66 Old 07-22-2009, 11:20 PM
User is: Sammytheorangutan is offline
You got about 3 choices. One, you don't have the data connection hooked up right. Two, you just haven't driven it enough to calibrate it. Three, the unit is junk. To calibrate the compass (assuming it works), you have to drive in some fairly small circles a couple of times (large parking lot works well). You may have it hooked up wrong. (I only had to add the data connection as the rest of the wires came straight from my existing 6 pin connector.) I just swapped my temp/compass for the trip computer this past weekend. I'm pretty sure the yellow wire was the data cable. I connected it to the purple wire on the OBD II connector next to the ebrake pedal. (I have an '04 Blazer. Dunno what you have.) If you have the short console, you might have the separate compass module. Look at the top of the display unit. If there is a 4 (or 5?) pin connector next to the 9 pin, you need the separate compass module. The compass won't work without it.
Looking for a perfect dk gray floor shifter center console. (I don't need the shifter assy.)
post #14 of 66 Old 07-22-2009, 11:27 PM Thread Starter
lwrd93's Avatar
Its a 98 sonoma.. I have the purple wire from the console going to the obd 2. It has the separate 4 pin and I connected it to the console.. What's the module? Isn't it built into the bracket?
lwrd93 is offline
post #15 of 66 Old 07-22-2009, 11:29 PM Thread Starter
lwrd93's Avatar
The yellow one on mine is for 12v switched power.. So I can't put it to the obd 2
lwrd93 is offline
post #16 of 66 Old 07-22-2009, 11:45 PM
What did your console come out of? Both of my short ones came out of '00 Bravadas. The compass module I was referring to should have been attached to an extension on the right side of the bracket that holds the short console in place. (The bracket goes under the headliner.) If I have a chance tomorrow, I'll drop my console and see what color wire I have going to the OBD II port. I'm 99% sure it's yellow, but I've been wrong before. It also looks like there is more than one way these were wired up depending (I assume) on the year. Both of my short console/trip computers (again both from '00 Bravadas with sunroofs) are wired the same, but I've seen more than one wiring diagram posted here. It's still possible you have some wires wrong, but I'm not much of a wiring expert. If you know what year/model truck your console came out of, I'd find the wiring diagrams for that just to make sure you have everything in the right places. I don't know if this will help, but the trip computer I have that came out of the Bravada has a sticker on it with this: VA433120U3D. The trip computer I have that came from an unknown source (but without the extra plug for the compass) has a sticker with this: V9123814QFH. I'm going to assume those are part numbers as they also have a bar code on the same sticker and the only other numbers on the displays are patent numbers. Dunno if this info helps or not but if you have the same part number on yours that I have on the one out of the Bravada, it might help if you try to track down a wiring diagram.
post #17 of 66 Old 07-23-2009, 12:13 AM Thread Starter
lwrd93's Avatar
yah my compass module was on the extension.. and i hooked it up to the console.. i dunno why everything works fine for 5 secs then goes to c -- and 0's
the temp should still work even though the compass isnt set right?? if i unpug the compass and try it will it not work either?
lwrd93 is offline
post #18 of 66 Old 07-23-2009, 12:39 AM Thread Starter
lwrd93's Avatar
here is how mine is wired up now.. and when i roll the dimmer the light on the console dims so i know i cant b off on much..
lwrd93 is offline
post #19 of 66 Old 07-23-2009, 01:29 AM
Like I said, I can't help you much on the wiring as I just repinned the 9 pin connector exactly as I had my original 6 pin then simply added the data wire. The 9 pin connector (with the wiring down to the C 209 connector under the dash) still had the original wiring in it too but I took out the wiring (except again for the data wire). Everything works but I don't know what everything (except the data wire) goes to as it's still embedded deep in the dash. Nothing on my setup is tied in to the radio unless it was done from the factory (which I doubt...I'm pretty sure it all goes to C 209). The trucks (except the Crew Cab) don't have the C 209 plug under the dash so you're out of luck with that. When I had the compass module unplugged, my compass wouldn't read anything either. It's still possible that you have a bad unit. BTW, the first 6 pins are all together then pin 7 is empty. Pin 8 is the RAP power (leaves the power on til you open the door which wasn't needed since I already had another one of those wired up for the temp/compass unit OEM. Pin 9 is the data cable that goes to the OBD II. Maybe your wiring is just a different color than mine but in the same locations?
post #20 of 66 Old 07-24-2009, 02:46 PM Thread Starter
lwrd93's Avatar
anymore help??
lwrd93 is offline
post #21 of 66 Old 07-24-2009, 06:30 PM
capspauld's Avatar
Mine is pretty much wired like yours. Here are the differences between ours, not saying its gonna make it work but just letting you know.
Temp Sensor Ground: I drilled a hole in the core support and made a fresh ground for it with a screw and a ring terminal on the end of the ground wire.
Dome light/homelink wiring: I tapped all of my wires into the rearview map lights and dome light including ground and 12v constant.
Class 2 Data on the console: I tapped into pin A1 on the Second BCM plug(Light Blue Plug, Yellow Wire at the first spot)
I also had to tap into the VSS on the BCM because my '03 Does not have a VSS wire, but I dont think that would be a problem for yours.
Also, I think when mine wanted to calibrate, it said Cal on the display not C.
Maybe check the data link wire or try the BCM for the source, but I cannot remember 100% cause I did it last summer.
Hope it gets working for you!
This is all assuming that the console is a 98+ as well though.
post #22 of 66 Old 07-25-2009, 05:00 AM Thread Starter
lwrd93's Avatar
i dont have the homelink or domelights hooked up right now.. and no blue wire for the class 2 mines purple see in the diagram? only thing i can think of is my temp sensor but all the other stuff should work if the temp sensor wasnt grounded right...
lwrd93 is offline
post #23 of 66 Old 07-26-2009, 06:13 PM
capspauld's Avatar
The class 2 I am talking about is a yellow wire on the second plug on the BCM that has light blue conector. Im not sure about the temp sensor though.
post #24 of 66 Old 07-27-2009, 01:16 AM Thread Starter
lwrd93's Avatar
my class 2 is purple from the console and goes to the data link connector.. everything is right, im about to just rip it all out.
lwrd93 is offline
post #25 of 66 Old 07-27-2009, 10:28 PM Thread Starter
lwrd93's Avatar
come on someone out there please help me!
lwrd93 is offline
post #26 of 66 Old 07-27-2009, 10:29 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
check your speed sensor connection....i bet its not wired right. if thats not right then it will cause your problems
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #27 of 66 Old 07-28-2009, 03:08 AM Thread Starter
lwrd93's Avatar
the vss?? dark green,its on pin 16 is that right?
lwrd93 is offline
post #28 of 66 Old 07-30-2009, 03:46 AM Thread Starter
lwrd93's Avatar
someone help me fix this...
lwrd93 is offline
post #29 of 66 Old 08-01-2009, 01:59 AM Thread Starter
lwrd93's Avatar
anyoneee
lwrd93 is offline
post #30 of 66 Old 08-02-2009, 12:03 AM
Raven's Avatar
im checking your wiring in between coats of bed liner im spraying....
1999 S10 4.3L Zr2
Raven is offline
post #31 of 66 Old 08-04-2009, 12:41 AM Thread Starter
lwrd93's Avatar
whats that mean?
lwrd93 is offline
post #32 of 66 Old 08-04-2009, 04:59 AM
I think it means he's double checking your wiring diagrams as he's applying bedliner to his truck.
post #33 of 66 Old 08-04-2009, 10:36 PM Thread Starter
lwrd93's Avatar
ok i moved the vss and the class 2 both to the bcm and still doing the same thing.. what else could it be?
lwrd93 is offline
post #34 of 66 Old 08-04-2009, 11:06 PM
BTE
LS1 powa!
BTE's Avatar
green -- vss pin 16
Ok,
Your diagram says that you attached the purple wire to the class II serial data wire on the ALDL, and that the yellow wire goes to the radio.
Those two wires are the only ones backwards according to my diagrams.
I connected my yellow wire to the class II serial data wire on the diagnostic connector, and the purple/white wire to the radio harness for the LED dimming signal.
Heres a copy of my diagrams pulled from AllData:
Pin -7 - dk grn- RAP fuse supply voltage
Pin -8 - blk/wht- Ground
Pin -9 - dk grn/wht- VSS
Pin -10 - lt grn/blk- Outside air temp sensor signal
Pin -11 - gry- Instrument panel lamp fuse supply voltage
Pin -12 - ppl/wht- LED dimming signal
Pin -13- not used
Pin -14- orn- Batt. positive voltage
Pin -15- yel- Trip computer/Nav class 2 serial data
So I say switch your yellow and purple/white wires and see what happens.
-This is assuming you have the short 98+ console and wiring-
BTE is offline
post #35 of 66 Old 08-04-2009, 11:39 PM Thread Starter
lwrd93's Avatar
When I turn my dimming switch down the console lights dim so I don't think that's wrong.. And if I take the yellow off it doesn't power up that's 12v...
lwrd93 is offline
post #36 of 66 Old 08-05-2009, 01:32 AM Thread Starter
lwrd93's Avatar
well me and BTE just went threw all the wires... everythings right, not sure why its not showing the values after 5 secs. going to try and get another console im thinking that this one is bad.
lwrd93 is offline
post #37 of 66 Old 08-05-2009, 11:59 AM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
Depending on which one you have, I might have an extra for you. This is only the electronic parts not the whole console. Yes, they are exchangeable.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #38 of 66 Old 08-05-2009, 10:06 PM
Raven's Avatar
ok first thing here...
what year is your truck??
what year/model did the OHC come out of?
i need those answered so i can solve your problem
Tad
1999 S10 4.3L Zr2
Raven is offline
post #39 of 66 Old 08-06-2009, 01:56 AM Thread Starter
lwrd93's Avatar
mine is a 98 gmc sonoma.. i dunno what it came out of just a 8 pin harness with homelink all i know and the wire colors are in the diagram.
lwrd93 is offline
post #40 of 66 Old 08-07-2009, 10:03 AM
Raven's Avatar
can you take a pic of the wires so i can check some of the colors
1999 S10 4.3L Zr2
Raven is offline
post #41 of 66 Old 08-07-2009, 07:56 PM Thread Starter
lwrd93's Avatar
the 8 colors are posted above in the diagram.. its not the wiring i have went over it with 2 other member and both of them said its the same.
lwrd93 is offline
post #42 of 66 Old 08-07-2009, 11:51 PM
Raven's Avatar
well ive seen lots of consoles and never seen a brown wire before....thats why im asking. maybe those members are wrong??
1999 S10 4.3L Zr2
Raven is offline
post #43 of 66 Old 08-10-2009, 12:33 AM
BTE
LS1 powa!
BTE's Avatar
Thats what kept confusing me
BTE is offline
post #44 of 66 Old 08-10-2009, 02:46 AM Thread Starter
lwrd93's Avatar
well this wire is brown.. what other color could even be close to it??? and what would it go to if it was to be lighter or darker brown?
lwrd93 is offline
post #45 of 66 Old 08-10-2009, 02:10 PM
orange
post #46 of 66 Old 08-11-2009, 12:13 AM Thread Starter
lwrd93's Avatar
its defiantly brown.. i already have a orange wire not including the orange wire for the lights
lwrd93 is offline
post #47 of 66 Old 11-09-2009, 11:27 PM
User is: novadork is offline
ok, just to add more confusion here, i have a 1994 S 10 Blazer, digital dash,4.3W, 4x4. i bought a overhead compass off ebay, so im not sure what year its from, and it does have the same wires as lwrd93's has, the colors are Yellow, Black/white, Dark Green, Light Green/Black , Gray, Brown, Empty Space, Orange, Purple. Ive seen tons of instructions and diagrams but until we figure out what year and where these wires are supposed to lead it's all just guessing or knowledge from someone who has already researched or installed one of these 9 pin 8 wire harnesses into an odd year S10, if anyone has installed these into a Square Body 1994 S10 w ith OBD1, let me know I dont think mines has the trip computer anyhow, so thats not a problem, if i can get the compass and temp. i'll be happy, im just afraid to guess and blow out my digital dash, thanks Dean
novadork is offline
post #48 of 66 Old 11-10-2009, 01:41 AM
Nevada: Hookers & Poker
S-10_man66's Avatar
User is: S-10_man66 is offline
What are the buttons on the console...if it says on/off will only be temp and compass, if it says "mode" it will be trip, compass and temp
97 GMC SONOMA ZQ8:Totaled.
94 Chevy S-10 Blazer 4x4: Daily.
post #49 of 66 Old 11-10-2009, 03:36 AM
its on/off, compass and temp., just gotta figure out these wires now,
novadork is offline
post #50 of 66 Old 11-10-2009, 11:56 AM
Electrical Mod
deathphoenix99's Avatar
Not to take this thread, but here is a thread just for wiring the console. It should help you out.
http://www.s10forum.com/forum/f62/ov...e-pics-420587/
