OVERHEAD CONSOLE Owners Please Post HERE!!!!!!! - Page 4 - S-10 Forum
 2Likes
post #151 of 258 Old 10-15-2012, 11:56 PM
That Other Guy
User is: RocketFast321 is offline
Re: OVERHEAD CONSOLE Owners Please Post HERE!!!!!!!
Originally Posted by Wicked69ng View Post
I haven't been here in a long time. But i like this. Since the grand am is gone. I will put my overhead in my alero.
Hualer/Project: 1984 Buick Electra Esate Wagon Fresh 3oh7 268h camming. OEM 84 2004r
Baby Sandy: 2001 2.4 Grand Am se 1.5 (auto) 32k-119k : Sept.2002-Aug.2010
Mickey: 2001 Alero GL 2.4 5-speed (Nov. 2010) 109k-???
G/f-Toy Car: 1990 Oldsmobile Calais 2.5
post #152 of 258 Old 10-16-2012, 12:22 AM
B4U Task Force
Rhotpursuit's Avatar
So...where do I find a VSS signal on a 96 S10 p/u?
U.S.C.G. "So others may live"
Apple Red 96 SS
post #153 of 258 Old 10-16-2012, 01:00 AM
badmofo529's Avatar
User is: badmofo529 is offline
radio harness. green and white iirc
post #154 of 258 Old 10-16-2012, 01:16 AM
B4U Task Force
Thanks...just to show my ignorance...what is "iirc"?
Apple Red 96 SS
post #155 of 258 Old 10-16-2012, 01:18 AM
badmofo529's Avatar
if i remember correctly. its either green/white, or green/black i cant remember off the top of my head right now
post #156 of 258 Old 10-16-2012, 01:36 AM
B4U Task Force
I get it...can it be picked up at the OBD2 connector?
Apple Red 96 SS
post #157 of 258 Old 10-16-2012, 01:40 AM
Jimmyfied
Drain Bamaged's Avatar
User is: Drain Bamaged is offline
I gave up n mine
post #158 of 258 Old 10-16-2012, 01:53 AM
B4U Task Force
What I have is a short ohc with a long ohc module. It only has temp and compass so I'm hoping it on't be too bad. I'm not sure why I would need the VSS unless it's for the compass.
Apple Red 96 SS
post #159 of 258 Old 10-16-2012, 02:31 AM
badmofo529's Avatar
you dont need the vss unless you have the mode version
post #160 of 258 Old 10-16-2012, 02:48 AM
Slowly but eventually
98lowerednewproje's Avatar
User is: 98lowerednewproje is offline
I think you need the VSS for the temp. Everything the compass needs is contained in the bracket that you attach the OHC to, but I believe it uses the VSS to adjust the temp depending on the speed. Would just have to find the wiring diagram thru deathphoenix's sig.
Procrastination has carried me this far in life, it will carry me to my grave, and hopefully put that off as well.
'98 RCSB on jack stands, waiting on me to get the 4.8 and T56 swap together, while I steal parts off of it to keep the daily going.
'99 2DR 2WD Blazer that I bought for a daily but just can't leave it alone.
post #161 of 258 Old 10-16-2012, 02:52 AM
badmofo529's Avatar
i didnt event think about the temp adjustment
post #162 of 258 Old 10-16-2012, 03:00 AM
I just double checked, since I thought, but wasn't sure, and yeah, you need the VSS, and its the green with white stripe, and yeah the best place to get it is the radio harness. I tried a couple of other places, and it didn't work out well.
post #163 of 258 Old 10-17-2012, 01:40 AM
Now, one thing that I remembered, there are at least two green wires with white stripes. One is the VSS and the other is one of the speaker wires, at least thats what it is on my 98, so might want to find a pin out of the radio, or in my case, it was the one that didn't have anything on the radio side of the adapter harness, since they don't have the automatic adjustment for speed like a stock radio does.
post #164 of 258 Old 10-19-2012, 12:53 AM
That 3D picture dude guy
DfntPntbll's Avatar
User is: DfntPntbll is offline
Send a message via AIM to DfntPntbll Send a message via Yahoo to DfntPntbll
update: I figured out what to do with my headliner since I installed the rag top. Also, to answer your question, IIRC the VSS can be found at your OBDII port and is the SOLID light green wire... or that may be the data signal. Not 100% sure.
1998 Ext. Cab S-10 4.3L bagged front/lowered 6" and rear disc
Like my 3D work? PM me for a rendering!
ASE Certified Alignment Tech
post #165 of 258 Old 10-24-2012, 02:03 AM
User is: FentonDude is offline
I picked up a short console out of a 97 Blazer with a sunroof. It doesn't have homelink, just the rocker for the sunroof. It also has the external compass sensor. The lights are the ones where you push the lens to turn on and off.
It looked like someone had tried to remove the console and gave up. The wires were cut at the plug in the dash, and the jackwagon ripped the three wires out of the plug for the map lights. The harness has black, white and orange wires, and the plug on the console has black white and grey.
I can find a dozen pinouts for the LED readout, but there are no postings for the lights.
Can someone tell me how the colors line up between the harness and the plug for the lights? Also, any idea which wire is hot and which is switched? Can I just tap into the wiring for my rear view mirror? (It's not an auto-dim, it just has the two little map lights)
Thankx!
post #166 of 258 Old 10-24-2012, 02:47 AM
Thankx!
Also, there were no bulbs in the map lights. Can someone tell me what bulb size these take? I'm going to go for LED's but I need a starting point as to what type bulb.
post #167 of 258 Old 10-24-2012, 09:50 AM
B4U Task Force
I think they are 194's
Apple Red 96 SS
post #168 of 258 Old 10-24-2012, 05:13 PM
Originally Posted by DfntPntbll View Post
1. 1998 S-10 Ext. Cab
7. No harness, did my own wiring straight to OBD2 port
Your OHC looks just like mine.
Can you tell me how you tapped the grey, white and black wires for the push-lights?
post #169 of 258 Old 10-24-2012, 09:26 PM
1991JIMMY4X4's Avatar
User is: 1991JIMMY4X4 is offline
hey everyone i have a 1991 4 door jimmy and im thinking about getting a console from a 1994 blazer, the guy that owns it says he doesnt have any wiring for it, not sure if it has homelink or onstar or any other special features. now how would i go about wiring it so that the two lights on it work?
post #170 of 258 Old 10-24-2012, 10:04 PM
User is: Noob17268 is offline
has anyone mounted gauges in a overhead console , like boost or a air fuel ? Is there enough room to run a small vacuum line for a boost gauge tucked in nice?
post #171 of 258 Old 10-25-2012, 12:45 AM
Go back a page and look at this posting
http://www.s10forum.com/forum/f62/ov...ml#post6719230
Some OHC came with controls for the rear A/C instead of an information display. Pull the controls, put in a plate, and there should be room for a couple gauges. There is room in the pillar for drain lines the size of your finger for sunroofs, there should be plenty of room for any lines you need for gauges.
post #172 of 258 Old 10-26-2012, 04:53 AM
Fenton- do you have a rearview mirror with lights? That is where I got my black(ground), orange(power), and white, since the lights in the mirror are hooked up like courtesy lights as well. The grey wire, I went down to the radio harness.
post #173 of 258 Old 10-26-2012, 01:59 PM
badmofo529's Avatar
marcus, how bright is yours? when mine actually works, i cant see it unless its dark lol
post #174 of 258 Old 10-26-2012, 02:45 PM
Electrical Mod
deathphoenix99's Avatar
Mine have always been bright, you might need a new module badmofo. Too bad, because I just tossed like 5-6 mode computers since I no longer wanted to store them. All of them were good too.
post #175 of 258 Old 10-26-2012, 05:05 PM
Yes, I have the mirror with the lights. Since the harness uses black white and orange, I can just go with the same colors tapping the feed to the mirror, yes? (Thanks)
My main question is how to put those 3 wires back into the male plug for the OHC since the female connector on the console itself uses black, white and grey.
post #176 of 258 Old 10-26-2012, 05:37 PM
I'm assuming this was meant for me.. and yes my mirror does have lights so i will try it as soon as i buy the console later today
post #177 of 258 Old 10-26-2012, 10:34 PM
badmofo529's Avatar
im guessing thats whats wrong with it, it works on and off and is pretty dim, and im pretty sure my wiring is good. ill probably end up putting some kind of gauges or volt meters in there so im not really worried about it.
post #178 of 258 Old 10-27-2012, 02:11 AM
I can see my console any time, day or night.
Jimmy, it actually was meant for Fenton, but if it helps you too, then even better.
post #179 of 258 Old 10-29-2012, 07:13 PM
I was at the salvage yard this past weekend, and pulled a console down that looked like mine. the three wires from the harness, black, white and orange, connect to the three wires on the console (lighting circuit) black, white, and grey. Not sure why they didn't just go with Orange on the console, but .. whatever..
Looks like next week I'll have time to install the console, as well as a gauge cluster with Tach.
post #180 of 258 Old 11-06-2012, 11:30 AM
Grant H's Avatar
User is: Grant H is offline
1. YOUR VEHICLE YEAR/MODEL/TYPE (FOR EXAMPLE, 2002 BLAZER 2-DR, 1998 SONOMA EXT. CAB, 1997 BRAVADA, ETC.)
2000 Jimmy 2 dr 2wd.
2. IF IT CAME ORIGINALLY WITH THE OVERHEAD CONSOLE
Yes.
3. SHORT CONSOLE OR LONG CONSOLE. IF SHORT CONSOLE, PUSH LIGHTS OR BUTTON OPERATED
Long console.
4. ON/OFF BUTTON OR MODE BUTTON
On/off.
5. HOMELINK OR ONSTAR IF PRESENT ON THE CONSOLE
Nope.
6. ANY OTHER FEATURES
Nope.
8. DOES EVERYTHING WORK?
Yep.
2000 Jimmy 4.3, RallyXing it like the fat dude at the gym
Grant H is offline
post #181 of 258 Old 11-11-2012, 12:05 AM
redhotyellaboi's Avatar
User is: redhotyellaboi is offline
mine just worked bright all the time at first but if i remember correctly to get it to dim when you turn the headlights on there are two wires that have to be joined together then ran to the dimmer wire wheich i think is gray..if you need help i can pull the trim that runs down the windshield to see which ones i put together..
post #182 of 258 Old 11-11-2012, 02:13 AM
badmofo529's Avatar
it gets dimmer when the headlights are on, but its just too dim to see in the daylight most of the time
post #183 of 258 Old 11-11-2012, 11:16 AM
ok then if you unhook the dimmer wire it should stay bright all the time and wont change no matter if the headlights are on off
post #184 of 258 Old 11-11-2012, 01:17 PM
badmofo529's Avatar
i know that. i cant see it during the day, i have no issues at night
post #185 of 258 Old 11-11-2012, 02:51 PM
OK guys I'm going to need some help here. Please bare with me as I am a total noob at electrical and wiring.
I have a 1991 first Gen Jimmy, I just picked up an Overhead console from another first gen but it did not come with a wiring harness. So I went to the junkyard ands picked up a harness from a 2nd gen blazer (99?) All the way from the overhead console to the firewall. I also picked up the digital meter that's suppose to say the temperature and compass. So what I need is help on how to connect everything to make sure it'll all work. I'm guessing I'm gonna need A temp sensor and compass sensor? where are they located in the second Gen and what do they look like?
post #186 of 258 Old 11-11-2012, 02:55 PM
with mine unhooked its b right day or night..so maybe as someone mentioned before that you have a bad unit..
post #187 of 258 Old 11-11-2012, 09:33 PM
24digger's Avatar
User is: 24digger is offline
Is your console a mode or on/off console? All you need is the temp sensor, compass is built in. If its a mode console it won't work in your truck.
You need to know the year of console for the temp sensor because 98+ are different, the temp will be about 30 degrees off.
Also there should be wiring diagrams at the first of this thread to tell you where the wires go.
24digger is offline
post #188 of 258 Old 11-13-2012, 01:55 PM
Thanks. It is the on/off console. I can always go back to the junkyard and pull the sensor off the same blazer I got it from. Just need to know where the temp sensor is located
post #189 of 258 Old 11-13-2012, 05:16 PM
badmofo529's Avatar
its right behind the grille
post #190 of 258 Old 11-14-2012, 08:35 PM
cool thanks man, you wouldnt happen to have a picture of one would you? just so i know exactly what im looking for next time im at the yard lol
post #191 of 258 Old 11-14-2012, 10:56 PM
badmofo529's Avatar
here you go!
post #192 of 258 Old 11-15-2012, 01:41 AM
User is: sc39482 is offline
Originally Posted by xtrememeasures10 View Post
Thats baddasss!!! I wanna do that 2 my truck bad!
hey whats up! do u know if that console in ur pic thats powder coated blue is compatible with an 02 sonoma ? just curious, thanks !
sc39482 is offline
post #193 of 258 Old 12-20-2012, 03:00 PM
41chev
User is: ccmiz is offline
puting 2000 short console in 41 chev, i bet i have questions later.
ccmiz is offline
post #194 of 258 Old 12-20-2012, 03:50 PM
41chev
need wireing diagram or info. putting 2000 blazer short ohc in 41 chev. advice?
ccmiz is offline
post #195 of 258 Old 12-20-2012, 04:27 PM
DfntPntbll's Avatar
if it is the 1 with the mode function, you need the ECU out of a blazer. The console works off of information from that to get gas mileage, range, etc. If all it has is the temperature and compass, all you need to do is find a switched power and ground and then wire into the vehicle speed sensor. The wire for the temperature sensor will be stand alone.
post #196 of 258 Old 12-20-2012, 04:58 PM
41chev
thanks. it has mode and home link. i got the lighted visor mirrors also. where is speed sencer. speedo in 41 is electric.
ccmiz is offline
post #197 of 258 Old 12-20-2012, 05:06 PM
DfntPntbll's Avatar
It depends on your drivetrain. It is probably in the transmission.
post #198 of 258 Old 03-02-2013, 01:04 AM
tonkaman's Avatar
User is: tonkaman is offline
Has anyone tried to change the display color on the compass and temp display?
1991 4.3L 5 speed Ext cab 4x4 AKA Little Smokey
1993 S-dime 4.3L auto ext cab 4x4 SOLD
1987 S-dime 2.8L 5 speed SOLD
tonkaman is offline
post #199 of 258 Old 03-02-2013, 01:27 AM
Jimmyfied
So I if I switched to the mode from the on off one it goes to dashes after a period of time do I need to ecu as well
post #200 of 258 Old 03-31-2013, 06:00 PM
ITSMYDIME's Avatar
User is: ITSMYDIME is offline
01 reg cab long console w/trip
ID:	131860   Click image for larger version
ID:	131861   Click image for larger version
