odometer reads "Error" - S-10 Forum
post #1 of 30 Old 02-03-2009, 10:30 PM Thread Starter
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
so ive had a flickering odometer/gear indicator for quite a while now, since the summer i think.
basically if i tapped the front plastic it turned back on again until i hit another bump where it turns off again.
i figured it was just a display connection issue.
but today, the odometer started reading "Error" (flickering issue doesnt change)
the trip odometer works, although it did get reset to zero when it started reading Error.
ive tried turning it off, on, etc but no change.
what's wrong? what happened? what do i need to fix it?
post #2 of 30 Old 02-03-2009, 10:35 PM
User is: richy_21 is offline
Send a message via AIM to richy_21
Re: odometer reads "Error"
Does your speedometer work?
richy_21 is offline
post #3 of 30 Old 02-03-2009, 10:39 PM
This season SUCKS.
dngrous_dime's Avatar
User is: dngrous_dime is offline
Send a message via AIM to dngrous_dime Send a message via MSN to dngrous_dime Send a message via Yahoo to dngrous_dime
Have you pulled the cluster out to check the connections?
If there's nothing wrong with it there, you should shorten your bed.
Brian
Originally Posted by 1fast4by View Post
Also, in case you were unaware Ass dynos never work
Originally Posted by MotorNut123 View Post
yea i graduated. My whole family is proud. High school graduation is a huge thing. At least for my family it is.
post #4 of 30 Old 02-03-2009, 10:43 PM
Avgas's Avatar
User is: Avgas is offline
Send a message via AIM to Avgas
'98 Std Cab S-10
'00 4-Door Blazer 2wd
Avgas is offline
post #5 of 30 Old 02-03-2009, 10:52 PM Thread Starter
s-series #2?
yup. all gauges work. nothing else wrong.
have not pulled the cluster. wont have time to do that until the summer.
from now on i only respond to longbed comments if they come from people with sweeter trucks than mine.
post #6 of 30 Old 02-03-2009, 10:54 PM
This season SUCKS.
So, should I bump this thread in a year?
Brian
post #7 of 30 Old 02-03-2009, 10:58 PM
FUCK YOU
Wicked Mayhem's Avatar
it takes all of but 5 minutes to pull the bezel off and get the cluster out. you cant be that busy. and you gotta have a 7mm socket and ratchet layin around.
(sorry if im wrong, but im pretty sure thats all you need)
Wicked Mayhem is offline
post #8 of 30 Old 02-03-2009, 11:11 PM
i thought it was .5 a inch drive. 6.5?
richy_21 is offline
post #9 of 30 Old 02-03-2009, 11:13 PM
This season SUCKS.
wha?
Brian
post #10 of 30 Old 02-03-2009, 11:18 PM
I thought it was like a 6.5 mm.... or was it a 5.5 mm.
richy_21 is offline
post #11 of 30 Old 02-03-2009, 11:28 PM Thread Starter
s-series #2?
i wasnt aware it would be that easy...
but the problem is all my tools are at the parent's and i cant afford the time to drive there and back.
but am i looking for a loose connection? that might fix the flicker, but does that fix/explain the "Error"?
post #12 of 30 Old 02-03-2009, 11:30 PM
It's a Blue thing...
♠ lυε ♠'s Avatar
User is: ♠ lυε ♠ is offline
It's worth a try.
-Jay
♠♣NEW CALIFORNIA S10 FORUM♣♠
www.WaylayedInc.com
♠|♦ '97 Noma Bagged DD ♣|♦ '98 S-10 4.3l Static 5/5 ♦|♣
WANTED: '55-'57 CHEVY BIG WINDOW PICKUP
♠ lυε ♠ is offline
post #13 of 30 Old 02-03-2009, 11:32 PM
This season SUCKS.
Don't you have full access to a shop? I'm sure they won't miss one ratchet and socket for 15 minutes.
Brian
post #14 of 30 Old 02-03-2009, 11:56 PM Thread Starter
s-series #2?
we dont use metric stuff there.
post #15 of 30 Old 02-04-2009, 12:55 AM
mooninites are after me
hds1o's Avatar
User is: hds1o is offline
Ive used the closest standard socket before, 1/4 I think. Your not going to strip the screws, they shouldnt be that tight.
hds1o is offline
post #16 of 30 Old 02-04-2009, 01:26 AM Thread Starter
s-series #2?
alright cool. ill take a look this weekend hopefully
post #17 of 30 Old 02-04-2009, 01:41 AM
cokehead
Dr. Pepper's Avatar
User is: Dr. Pepper is offline
Send a message via AIM to Dr. Pepper
its 9/32" btw. . .
★No Regrets★ MD
post #18 of 30 Old 02-04-2009, 01:44 PM
Harley's Avatar
User is: Harley is offline
Odo reading is stored in the gauges anyway, so I don't think it is from the PCM tune we did this weekend. Check the cluster and get back with us. If you need a hand I should be available Sunday as long as the laptop keeps cooperating haha.
Harley is offline
post #19 of 30 Old 02-04-2009, 01:47 PM Thread Starter
s-series #2?
cool, i think i can handle it,
and i dont think its tune related because it worked fine before.
is there an internal gauge battery or something? the trip odometer is not working perfectly. every time the truck sits for a while without power, it gets reset.
so laptop still okay?
post #20 of 30 Old 02-04-2009, 02:02 PM
That's Life
Xtremegurl's Avatar
User is: Xtremegurl is offline
Send a message via AIM to Xtremegurl
Bwahaha, I second that
-Sarah
'04 WRX
post #21 of 30 Old 02-04-2009, 02:10 PM Thread Starter
s-series #2?
donate me a project and i might consider
post #22 of 30 Old 02-04-2009, 02:39 PM
Harley's Avatar
Cluster may be crapped internally too.
I've gotten the laptop working, but haven't figured out if the problem is the battery or one of the many windows updates it keeps asking me to install after the reinstallation. Got all night to play with it today.
Harley is offline
post #23 of 30 Old 02-04-2009, 03:48 PM Thread Starter
s-series #2?
its possible. been wanting to upgrade to a stock tach cluster anyways.
know the pricing of clusters from PG?
post #24 of 30 Old 02-04-2009, 04:56 PM
Harley's Avatar
I hope that was a rhetorical question haha. $6
Harley is offline
post #25 of 30 Old 02-04-2009, 05:59 PM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
The one in the Blazer has been doing this for a while too. Its prob a loose connection on the board. Im too lazy to take it apart, so Ill wait till it completly deosnt work.
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #26 of 30 Old 02-04-2009, 11:51 PM
That's Life
Xtremegurl's Avatar
you can have the noma but i want it back
-Sarah
'04 WRX
post #27 of 30 Old 02-05-2009, 01:22 AM Thread Starter
s-series #2?
haha cool. another thing to add to the list of things to find. its getting bigger lol
it says error or it being flickery
fine with me. i want one so i can just keep parts laying around to measure off of
post #28 of 30 Old 02-24-2009, 10:03 PM
chevyistheway's Avatar
User is: chevyistheway is offline
i have had the exact same problem w/ my 98 s10
sometimes though the selector will only light up the D and all the gauges will go crazy til i slap the dash
i suppose u havent had any luck fixing yours
mine started to this after i wrecked my truck and a shop rewired the whole front end and screwed w/ the fuse block tryin to find something to tack on the efan to
98 4.3 ext cab auto transgo shift kit 1, 266 cam, 1.6 full rr, 2.02 and 1.6 valves, pcm"shit"tuneforless, .030, 10 cr flat top forged pistons, balance shaft removed, msfi upgrade, accel distributor, msd wires, lt hookers and true duels to a delta 40
1/8 is 9.7@ 74mph 1/4 miles 2.3 60ft 15.3@ 88, and 14.4@ 98 w/ a 75shot99 sonoma scfs w/ 99 350, stock, fi, painted black 1st gen zq8s 2.3 9.5@ 76 14.6@ 95
http://www.youtube.com/watch?v=9Ovb1Pb36_I
post #29 of 30 Old 02-24-2009, 10:34 PM Thread Starter
s-series #2?
nah havent had the time to tear into it yet.
post #30 of 30 Old 10-22-2009, 11:02 AM
User is: sdimeman is offline
Wink Re: odometer reads "Error"
mine started this back last summer i know that you can change cluster out and it will read mileage off of cluster that you put in it! mine reads error also and resets tripometer all the time this is very annoying but i have had to deal with it due to the truck still runs and i'm cheap!
sdimeman is offline
