Need Help
Old 06-29-2009, 06:52 PM   #1
Oh So Low
Baggedconversion's Avatar
Need Help
I posted in the baggin section, but dont kno how to move a thread.....Im having trouble trying to figure out why i dont have any juice at my CRANK fuse in my under hood box, and why my milage doesnt light up and why my radio does not come on...... im stumped ive gone over my harness 3 times and cant seem to locate a problem...am i ovver looking soemthing help would be great......
Old 06-29-2009, 07:05 PM   #2
Oh So Low
Re: Need Help
sine im a Fvckin and didnt put the started relay back in.....Yeah....thats no good.....but now it starts......BUT I STILL DONT HAVE ANY GUAGES......and what is a CHMSL fuse????
Old 06-29-2009, 07:15 PM   #3
US Beer Drinking Team
hamagc's Avatar
Re: Need Help
chmsl is the 3rd brake light (center high mount stop lamp).
glad you got the starting problem found now lol. any other missing relays?
Old 06-29-2009, 07:32 PM   #4
hamagc's Avatar
Re: Need Help
ok everything i can find points to the radio fuse. apparently that fuse goes inline with the gauge lights?
are the fuses in the dash getting power?
Old 06-29-2009, 09:46 PM   #5
Oh So Low
Re: Need Help
well, i found another problem....when i dropped my fuse block.....seems a few wires werent soldered as well as i thuoght and pulled apaart......now
everything works in sync with one another....thanks everyone for the help!
Old 06-29-2009, 10:13 PM   #6
Oh So Low
Re: Need Help
ok so i lied, i still have a problem...it seems to me like the chmsl fuse is gettig warm,,,, i tesed it with the truck off, and i have juice to the 3rd brake light.....any suggetsion???
Old 06-30-2009, 10:30 AM   #7
Oh So Low
Re: Need Help
so theres nos specific reason anybod knows of as to why the relay would be getting warm???
Old 06-30-2009, 10:39 AM   #8
Electrical guy
deathphoenix99's Avatar
Re: Need Help
maybe a bad relay, it always has power going to it, well, at least the brake pedal switch has power to it. Are your brake lights on? Try replacing the relay and see if that fixes it, if not, you might have some wiring thats getting power from another wire.
Old 07-01-2009, 12:25 AM   #9
Oh So Low
Re: Need Help
brake lights arent hooked up yet.... i dont have them grounded yet.... or do th tail lights ground as part of the fuel pump.....cause the fule pump is grounded.....and it turn on and off..... thats the only thing im stuck on....I got all my dashboard back radio etc..... but when i test where the 3rd brake light bulb would snap in, i get a juice reading....key off and everything.....and i dbl checked all my splices and they are good......
Old 07-02-2009, 12:20 PM   #10
Oh So Low
Re: Need Help
well, i got everything hooked up, but now my brake lights areon constant...nothings pinched nor does anything seem crossed...anny suggestions??
Old 07-02-2009, 12:25 PM   #11
Electrical guy
Re: Need Help
Check your brake switch that it is adjusted properly, if it isn't, the switch will think the brake pedal is always pushed in. Check that and we can go from there.
Old 07-02-2009, 02:04 PM   #12
Oh So Low
Re: Need Help
how do i adjust the switch??
Old 07-02-2009, 02:40 PM   #13
Oh So Low
Re: Need Help
Ok......So i had to adjust my brake light switch, no biggie...thanx all for the help......
Old 07-02-2009, 04:35 PM   #14
Electrical guy
Re: Need Help
Glad you got it fixed.
Old 07-03-2009, 02:15 PM   #15
Oh So Low
Re: Need Help
thanks again for the help...... i took it out today and im amazed how how smooth the 5 link rides
