My Headlights Are Always On?
Old 10-30-2009, 03:14 PM   #1
Just Some Guy
l008com's Avatar
So mine's a 2000 S10 pickup. I just recently realized that my headlights when it's dark? Mine are always on, tail lights too. Even on the brightest, sunniest day. Is this normal or is something messed up? I can hit the dome override 4 times and they'll shut off, and my dash lights will get bright enough to actually SEE.
Old 10-30-2009, 03:19 PM   #2
94 2.2, feel the power?
deathphoenix99's Avatar
Re: My Headlights Are Always On?
Ok, are you sure your lights are on and not your daytime running lights? If so, is your light switch turned to off, fully counter-clock wise? If these are good, then you probably have something on your light sensor located on the passenger side speaker cover on the dash. If its dirty, covered, or broken it will cause your lights not to work correctly.
Old 10-30-2009, 03:26 PM   #3
rear on ground, finally
bigpokie's Avatar
i have a similar problem except my DRL and my low beams are on during the day. but its normal at night. mine started after a relay behind my sterering colum burnt up and i had it replaced. any ideas phoenix?
Old 10-30-2009, 03:33 PM   #4
What year vehicle bigpokie?
Old 10-30-2009, 09:43 PM   #5
Just Some Guy
l008com's Avatar
Any thoughts? My sensor seems fine, but my lights definitely seem to be on?
Old 10-31-2009, 02:21 AM   #6
Laying hard on zq8s!
colbye32's Avatar
call me crazy, but that sticker is prolly blocking the light from hitting that sensor, making the headlights come on..
edit : you can click the e brake down one notch and it will solve your problem.. just be sure to do it everytime you get in..
Old 10-31-2009, 09:20 AM   #7
Just Some Guy
l008com's Avatar
That picture is misleading, the sticker is hardly blocking any light at all. Even in a sunny summer day, the headlights are on. Even if I'm not at that exact angle when I'm driving down the street.
I'd rather fix the problem properly, than drive with the E brake on, even if it's just barely on. Anyone know how?
Old 11-02-2009, 09:48 AM   #8
Alright, you should have wiring diagrams for the headlights, so I would look at that first. Maybe try switching out the Ambient light sensor with a junk yard one. The BCM controls your automatic headlights feature. Another test you could do, is disconnect the light sensor, there should be 5V to one wire. Use a jumper wire and connect between the two. The light sensor works by resistance, the "darker" it is outside, the more resistance in the sensor. So the jumper will have little resistance and appear to be really bright out. If this turns your headlights off, we know there is a problem with the BCM or sensor.
Old 11-02-2009, 02:23 PM   #9
Just Some Guy
l008com's Avatar
OK so I took it all apart and played with it a little bit. I am reading about 5.5V coming through the sensor's wire. I stuck a paperclip into both ends to see if that would shut the lights off, but it didn't. I left it for a while, turned the truck off and back on, still the lights just stayed on. Then, I tried measuring the resistance of the sensor itself, and couldn't get a reading. Light or dark, my meter reads from 1 ohm (probably less than 1 also) up to 2MOhms, and it read nothing the whole time. Not zero, but no reading at all, as if I wasn't even touching the probes to anything. Based on that it would seem like my sensor is bad. But the paper clip should have bypassed it, right? So do I have multiple problems? Or maybe no resistance is too little resistance for the system?
Old 11-02-2009, 02:30 PM   #10
I'm going to guess the sensor is fine, they should never go bad, unless there is an external problem. But regardless, yours is probably fine as the bypass should have turned the lights off. So you are looking at a problem elsewhere, either your BCM, or a control somewhere else. I'd suggest looking at a wiring diagram and see if anything looks like a probabe place, either a bad switch, bad contact, or module. Have you done anything new, remove dash etc...? Something that might have pinched a wire or damaged something.
Old 11-02-2009, 02:33 PM   #11
Just Some Guy
l008com's Avatar
I've taken the radio out a few times, thats it. I think it's been like this for a while though. I know whenever I hook up a trailer, the trailer lights always come right on. I've never really thought much about it until recently.
Old 11-02-2009, 02:45 PM   #12
forum idiot
orangesonoma's Avatar
did you take off the grill and look at the wires going to the sensor? my 02 had the same issue and the moron who owned it before me never plugged the sensor back in..yours may be the same...or maybe even a bent pin in the sensor..
Old 11-02-2009, 07:43 PM   #13
Just Some Guy
l008com's Avatar
You mean the speaker grill? Yeah the sensor seems fine. There is some nasty mold under the speaker grill but moving on . . .
Maybe I'm making this more difficult than it needs to be. Is there an easy way (like pulling a fuse) to disable the whole automatic system? That way I'd have to use the knob to manually turn the lights on and off? That would be fine.
Old 11-02-2009, 10:05 PM   #14
forum idiot
you have to put a resistor in the plug for the sensor in the grill
Old 11-03-2009, 12:33 AM   #15
colbye32's Avatar
or ground the wire that goes to the ebrake to somewhere metal, then pull the brake light from the cluster. thats what i did, now my headlights are manual, with the switch only.
Old 11-03-2009, 10:22 PM   #16
GET'R'DONE's Avatar
im havin the same problem..
Old 11-03-2009, 10:30 PM   #17
bigpokie's Avatar
sorry so late. 00, 2.2, 5spd
Old 11-03-2009, 11:03 PM   #18
GET'R'DONE's Avatar
when i press the ebrake down it does nothin. lights stay on
Old 11-04-2009, 09:23 AM   #19
There must be a short or something wrong in the BCM. It controls the lights.
Old 11-04-2009, 04:48 PM   #20
Just Some Guy
l008com's Avatar
What IS a BCM?
Old 11-04-2009, 04:50 PM   #21
forum idiot
body control module
it controls the lights in the truck as well as most of the trucks functions..
could have a bad sensor too...try to replace it? if you put a resistor in there and they shut off you know that the sensor is bad
Old 11-04-2009, 06:03 PM   #22
Just Some Guy
l008com's Avatar
Quote: Originally Posted by orangesonoma
body control module
How many ohms should turn the lights off? I tried a paperclip aka just about zero ohms, and it had no effect.
Old 11-04-2009, 06:10 PM   #23
Just Some Guy
l008com's Avatar
Or I could just hit the dome-override button 4 times, every time I get in. But I'd rather make it work normally.
Old 11-04-2009, 06:17 PM   #24
sdimenightlight's Avatar
im working on one right now same thing his does it even with the key off n out, i have the bcm unplugged the switch unplugged same problem, do yours stay on with the key off? ill post it when i find the problem.
dan
Old 11-04-2009, 06:19 PM   #25
Just Some Guy
l008com's Avatar
No I think mine shut off when i turn the key off, but the interior lights etc say on after i remove the key, until I open the door. I assume thats normal.
Page generated in 0.59424 seconds with 31 queries
[Output: 123.45 Kb. compressed to 113.63 Kb. by saving 9.83 Kb. (7.96%)]
