Motorized License Plate Device HELP - S-10 Forum
post #1 of 14 Old 01-04-2011, 03:30 PM Thread Starter
kickflipking_04's Avatar
User is: kickflipking_04 is offline
Question Motorized License Plate Device HELP
Hey guys, I was wondering if anyone could help me figure out how to make a motorized (up & down) license plate tag. I've thought about using a motorized antenna from a Caddy, or mabye a window motor, and make my own tracks for it.... I was planing to use a rocker swtich to move the plate up and down. I'm just not sure what to use and from which vehicle to get a window motor from and if an antenna motor would do the job right and last. I was wanting to install it inside the tailgate and have it come out the top of the tailgate, and make an access panel to install it and hide it inside the tailgate. I have searched on here for about a day and a half now. I havn't really seen any pics or descriptions on how to do it, or what to use to get the best results. I know that AVS use to make a License plate retracter kit awhile back, but they seem to no longer make one. So, I guess with some helpful advice and maybe some pics from you guys. Maybe I can make my own Motorizrd license plate device.
post #2 of 14 Old 01-04-2011, 04:03 PM
KRIS
chevygurly's Avatar
User is: chevygurly is offline
Re: Motorized License Plate Device HELP
antenna motor,ball bearing track,tube (avs used copper),desired shape of back and front metal
take antenna remove the little ball. bend it about 1/8"
weld bottom piece of ball bearing track to bottom piece
weld copper tube to bottom piece
slide antenna through tube and weld bent piece to top piece
weld top piece of ball bearing track to top piece
I use to make em at a v s if you need more help.
post #3 of 14 Old 01-04-2011, 05:13 PM
KRIS
chevygurly's Avatar
i got a few PMs about this here is more info
http://www.bestbuy.com/site/Metra+-+...=1218105187727
they used that type of motor. the top of the antenna that goes up and down has a ball at the end of it..heat it up with a torch and it will come off. you will need to cut off the wires so all you have left is two wires. if i remember correctly red and green. they would enclose the antenna itselfs inside 1/2" airline that had 3/8" airline inside of it. that way it was more durable.
post #4 of 14 Old 01-05-2011, 08:27 AM
User is: aaronajb1981 is offline
is your truck bagged? if so you can get an air cylinder for about $20-25 then plus a control valve. this could take care of the lifting and lowering. this size cylinder is only about 3/4" diameter with a stroke of about 6"
post #5 of 14 Old 01-06-2011, 12:00 AM Thread Starter
Dose anyone have any close-ups of a AVS retractable license plate kit? Like the back of one, wires etc. how it mounts up.... How did you mount yours? Thanks.
post #6 of 14 Old 01-06-2011, 11:01 AM
rolling work in progress
Mr.woodscrewsNbondo's Avatar
User is: Mr.woodscrewsNbondo is offline
Maby you could rig up a pop up headlight motor to work
post #7 of 14 Old 01-06-2011, 12:22 PM
KRIS
chevygurly's Avatar
it mounts with just bolts and nuts. Nothing fancy. Wires were simple as well. Power and Ground from motor to a toggle/rocker switch.
post #8 of 14 Old 01-06-2011, 11:34 PM Thread Starter
Ok kool. Thanks chevygurly. If I run into any issues I'll let ya know.
post #9 of 14 Old 01-06-2011, 11:47 PM
Porno Music Producer
zhillz's Avatar
User is: zhillz is offline
What the hell is a BB track?
If you wanted to go super low tech you could get a spring loaded gear driven set up like you see in some cigaret lighters or over head compartments.
zhillz is offline
post #10 of 14 Old 01-07-2011, 02:18 AM
renswic's Avatar
User is: renswic is offline
http://lmgtfy.com/?q=motorized+license+plate+mount
Honestly. Forum registration should require a 'knowledge of how to use google' test.
1991 Baja.
renswic is offline
post #11 of 14 Old 01-07-2011, 08:46 AM
I searched that before i posted that the first time. i couldnt find any that went up/down. most of them are like the "flip-up radio" style where it slides out, then pivots up. you mount them to the bottom side of your bumper.
post #12 of 14 Old 01-07-2011, 01:06 PM
zhillz's Avatar
Regardless, you should make your own. The cheapest kit I saw was about $105 + shipping! Crazy! You can make your own for under $15.
zhillz is offline
post #13 of 14 Old 01-07-2011, 01:41 PM Thread Starter
I have already looked thru yahoo and google and they all came up with the same thing your trying to show me..... I'm not trying to make one like that, that attaches to the front bumper and moves that way. If you would have read the earlier post you would have read that I am looking to make a retractable/motorized license plat tag deal like A V S use to make. But thanks just the same for your input.
post #14 of 14 Old 01-28-2012, 08:16 AM
louder than you
p169's Avatar
User is: p169 is offline
Send a message via AIM to p169 Send a message via Yahoo to p169
I searched and it sent me to this thread lol
p169 is offline
