led light bulb comparison
Old 11-06-2008, 12:56 AM   #51
forum idiot
orangesonoma's Avatar
re: 194/3157/211 led bulb comparison
Quote: Originally Posted by tt85_GM
I wonder if they will look just as good as the LED's from superbrightLEDs like others have installed.
well i am working with that company to send me some "samples" to compare so if that pans out i will be able to show you the difference
Old 11-06-2008, 01:00 AM   #52
forum idiot
any body have any extra clusters they can send me? i went to the junk yard to pick up some but all the ones they had were beat up.. i will pay shipping and i will send them back if you like..
Old 11-06-2008, 01:40 AM   #53
Moderator
Wicked Mayhem's Avatar
you have a house full of s-series.? why not use the cluster outa one of them?
Old 11-06-2008, 01:42 AM   #54
forum idiot
i dont feel like taking mine apart...lol
Old 11-06-2008, 03:05 AM   #55
R/C Guru
92 s10 project's Avatar
I will go get one from a first gen at the junk yard this weekend if you wanna test it and a second gen if someone sends you that...or if they have a second gen I can get that too.
Old 11-06-2008, 12:34 PM   #56
forum idiot
sure let me know how much
Old 11-06-2008, 12:50 PM   #57
good bye red, it was fun
1/4milecrazy's Avatar
i could just take pics of mine with the LEDs, no install pics, but finished product, I used the blue LEDs like i posted above with the white background that we did
Old 11-06-2008, 03:56 PM   #58
Uncommon Engineering
badmatt's Avatar
The 194 bulb is the cluster bulb?
Old 11-06-2008, 04:51 PM   #59
forum idiot
yes
Old 11-06-2008, 04:51 PM   #60
forum idiot
do it
Old 11-06-2008, 06:19 PM   #61
Moderator
hurry up brian!
Old 11-06-2008, 07:38 PM   #62
forum idiot
well the shipment came in from v-leds.com...one short but i am talking to them about it..so far i very impressed with the quality of the lights.. i have seen many led bulbs and these so far look like the best quality so far...nothing looks cheap or weak...we shall see..
i got a full autometer cluster to try the 360 ones in.. i know i will be happy with them but i am going to post up my pics of that..
i also have a s10 with stock dome light and caddy tail lights to try this in.. only bad thing abut the caddy lights is they are not in the bezel but you will get the idea.. but so far i put the dome lights in my blazer and i am very happy with the light output...i will be using my white blazer as a test dummy...so this should go well...
Old 11-07-2008, 12:45 AM   #63
forum idiot
ok got some more test done.. and i found the best bulb i believe for plate lights for a 98+ s10 or blazer
it is a flat top led that has a heatsink that i am told will extend the life of the led bulb since heat is what kills them (its true i have had several of the non heatsink ones go bad and they do run hot)
this is the 360 dgree ones from early test
now this is the flat top heatsink one
and for shits and giggles this is stock bulbs
they are the same size as a regular bulb but perform better...these pics were taken with a regular shutter speed.. you be the judge...
Old 11-07-2008, 12:50 AM   #64
forum idiot
i also got my hands on some 3157 bulbs for running/brake lights..
now i need to test these in a s10 light but so far i have the pics from my blazer..the ones in the pic above are white...i used the correct color for the light..so red in red and so on...
stock on the right and led on the left running light...i would say better output from these pics...and in person they have a sharper color
close up of led tail...running light
you can see that the entire lense is lit up
now this is the stock bulb...running light
this is again stock right and led left...brake lights only
it is a much crisper light in person and there is no mistaking these regular bulbs with there fast turn on..
now the same bulbs but for reverse...i was not to happy with...yes they look cool but if you need to see stick with regular bulbs..
Old 11-07-2008, 12:53 AM   #65
forum idiot
now on to the front 3157 and 194 running in amber...the 3157 are the same looking as the brake lights but the 194 is different looking and is a bit longer then the stock bulb...it is the one at the bottom of the pic...edit...these are too long to fit in a 94-97 s10 side marker... but fit fine in a 98+
stock regular bulbs
running light with both leds
blinker on with running light
blinker only...and yes the 194 is not lit up since it does not work with both "forward" and "reverse" voltage
not much of a difference with the front bulbs..but you can tell the change in brightness from one to the other...
so these get a thumbs up from me as well...
Old 11-07-2008, 12:58 AM   #66
forum idiot
moving on to interior bulbs..man are these bright!
this is a light that will work with many applications
i think these will work well in the under dash foot lights since they come with the 194 base and have double side tape to stick them to the panel..i will try them soon under dash to compare
this pic does it no justice
so i took a pic with no extended shutter speed of it lighting up my wall
amazing...
this one is just as bright but more spread out
this is what i am using right now in the blazer for the front dome light
i am not kidding when i say they are bright..
i am going to do a test soon in a stock s10 to show the light difference using these
they are forward only facing and are pretty bright...you will see
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Old 11-07-2008, 01:01 AM   #67
forum idiot
for the hell of it i took my cluster that i made for my sonoma
yellow rugular bulbs standard shutter speed
one second shutter
four second shutter
now the fav. 360 led
regular shutter
one second shutter
four second shutter
hands down the best gauge bulb ever..the one second shutter speed i would say is the best to real life output
now all i have to do is test them in my cluster and we are set for them
Old 11-07-2008, 01:09 AM   #68
forum idiot
so far i am blown away by the quality from www.v-leds.com
not only do they ship fast, have many many applications but the craftsmanship that is put into these units is just amazing
again these lights were paid out of pocket and nothing swayed my opinion other then the real world results
Old 11-07-2008, 01:11 AM   #69
Former S10 enthusiast
01cherryreds10's Avatar
Brian this thread is awesome! I'm glad someone did a comparison of the bulbs. I think I may wonder over to vleds' site now. I bought some "cool white" leds from superbrightleds and they look more blue than anything, they arent that bright, and one is already defective after like 2 months.
You wouldn't mind getting other colors and seeing how bright they are would you
Old 11-07-2008, 01:15 AM   #70
forum idiot
lol i plan to get some from that vender in other colors...
what lights do you want to use them in? interior?
Old 11-07-2008, 01:20 AM   #71
Definately interior. Maybe just the usual colors people use like red blue green and such. I didn't see any 5 SMT's in color just the 9's though
Old 11-07-2008, 01:24 AM   #72
forum idiot
well this is what i have in my blazer...only this is blue..so if you like the light output in the interior shot...you will like this...but let me test it in a s10 dome light to see if it fits...its very large and you have to figure out a way to secure it...no big deal
or even this one
Old 11-07-2008, 01:24 AM   #73
Moderator
sick nasty! cant wait to get these bad boys in my blaze! im ready for some bright lighting!
Old 11-07-2008, 01:31 AM   #74
Those would be bright as hell with my Silverado dome light
Old 11-07-2008, 01:37 AM   #75
Moderator
so you didnt get 6 red 3157's for the tails? remember my reverse lights are red?
Old 11-07-2008, 01:39 AM   #76
forum idiot
that is what i have in my blazer...that is why i did not go into it with that truck since its not a s10/blazer light
Old 11-07-2008, 01:40 AM   #77
forum idiot
nope i ****ed you and got white..lol i did that incase you ever put stock tails on...lol
sorry...i friggin forgot
Old 11-07-2008, 01:44 AM   #78
Moderator
how funny will they look together?
but i guess its not really a big deal seeing how itll only be noticeable in reverse lol.
Old 11-07-2008, 01:45 AM   #79
forum idiot
it will light up some but not well..lol
we shall see right
Old 11-07-2008, 01:47 AM   #80
Call me Mario, Princess
AceHaag's Avatar
I think I have a cluster I can send you. I will look tomorrow.
Old 11-07-2008, 01:51 AM   #81
What about lights for the HVAC and headlight controls? My headlight bulbs burned out so I might as well do those while my interior is already torn apart
Old 11-07-2008, 01:53 AM   #82
forum idiot
that would be sweet..that way i can test on different bulbs without taking my truck apart every time
Old 11-07-2008, 01:54 AM   #83
forum idiot
i would have to see what bulbs are used.. i dont remember off hand
Old 11-07-2008, 02:13 AM   #84
I wanna say they are 3mm bulbs that you need to solder in. But I'll wait until you confirm anything.
Old 11-07-2008, 02:15 AM   #85
forum idiot
i really dont want to get into that since it was covered so well in the interior how to...plus if i did that i would have to get many dash parts to test them in...
i picked the lights i have done so far since they have not changed in s10's or blazers...
shit the dome light is the same from 82-05..lol
Old 11-07-2008, 02:51 AM   #86
Works too much.
BlownDime's Avatar
Well done Brian.
On a side note regarding the heatsink LED, I thought LEDs ran cold? It's the reason snow has to be brushed off big rig led tail/marker lights, the snow doesn't melt like with a normal bulb...
Old 11-07-2008, 05:53 AM   #87
I AM CANADIAN
tt85_GM's Avatar
wicked brian, but did you mean the brake lights/turn signals turn on and off fast enough like at regular speeds?
Old 11-07-2008, 09:59 AM   #88
I'm Back!!
beandip's Avatar
Amazing results, hell im going to be replacing my cathodes under the dash and get those leds.
License plate test looks similar to mine (stock vs. led)
Old 11-07-2008, 10:58 AM   #89
forum idiot
leds go full bright instant...incandescent bulbs take a second to get to full bright
Old 11-07-2008, 10:59 AM   #90
forum idiot
Quote: Originally Posted by BlownDime
Well done Brian.
its not the leds that run hot..its the resistor inside...they get hot
Old 11-07-2008, 01:48 PM   #91
Works too much.
BlownDime's Avatar
That explains it. Thanks for clarifying that.
Old 11-07-2008, 02:19 PM   #92
AceHaag's Avatar
I still have the cluster pm me your address and I will send it out.
Old 11-07-2008, 02:55 PM   #93
badmatt's Avatar
It would be awesome if you put together a full list of LED's like quantity and number of bulbs needed and what bulbs
Matt'
PS. ill send you a stock cluster if you send it back with teh LED's installed
Old 11-07-2008, 03:02 PM   #94
I AM CANADIAN
tt85_GM's Avatar
They give you the guide on their site. Just put your make and model in.
Old 11-07-2008, 05:43 PM   #95
Yeah definately. I got the same cathodes but from pictures of these LED's they look so much better, plus I'm sure they are a ton easier to hide.
Old 11-07-2008, 05:52 PM   #96
Slap my meat on your pita
GeorgesBlazah's Avatar
How do the LEDs look during the day when the brakes are pressed?
Old 11-07-2008, 08:34 PM   #97
forum idiot
they are pretty bright i would say...i have them in my red blazer and i have not been rearended yet
Old 11-08-2008, 09:50 PM   #98
Brian, in order to use any leds for the turn signals, you will have to modify your flasher, correct?
I was also thinking maybe we can contact v-leds about a possible group buy
Old 11-08-2008, 09:57 PM   #99
forum idiot
98+ yeah you can mod the flasher...i need to do one from chris..wicked mayhem so when i do his i will take good pics
and i will email them about maybe a promo code for the forum...
Old 11-08-2008, 09:59 PM   #100
Page generated in 0.66305 seconds with 31 queries
[Output: 226.46 Kb. compressed to 207.40 Kb. by saving 19.06 Kb. (8.42%)]
