forum idiot
led light bulb comparison
this post will be list of leds that i would recommend you using if you don't like my recommendations pick something similar for the same effect
as always please check your bulbs before you order...this is from my experience and i may not know everything about what fits where...so check first..and if you don't know pm me a picture with the lights you want to replace 194 gauge lights in white http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 blue http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 194 tag lights these should work best in all applications that the lights aim right at the tag http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 dome light...few option and they all depend on $$ i will start off $ and go to $$$ the first ones i did not test.. http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 the pic can be seen in this thread of these http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 two of these will fit in a standard dome light but need to be spliced together or one is just as good http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 Last edited by orangesonoma : 11-12-2008 at 02:31 PM. |
forum idiot
we now get a discount from v-leds.com
enter in s10forum in the promo code to get 10% off... buy from the direct do not use ebay i have a few different led bulbs and i figured i would do some real world testing in gauges...i also am in touch with a company that sells led bulbs and i should be receiving a good amount of bulbs to show you guys what they look like in different lenses and gauges so you can pick the one you like best...instead of guessing what they look like. so first test is in a auto-meter pressure gauge... this gauge relies on light to travel around the gauge face to light up the front i have right now a regular bulb and three led ones ![]() ![]() i will start it off with the regular bulb ![]() ![]() and with a one second shutter speed ![]() next is a forward facing led with two leds made by piaa ![]() ![]() and a one second shutter speed ![]() now the flat top led ![]() ![]() and with the once second shutter speed ![]() now the five led one with 360 degree lighting ![]() ![]() one second shutter speed ![]() the only led bulb that worked very well was the one with the 360 degree lighting... i got them from this vendor http://www.v-leds.com/Shop/Control/fp/SFV/32481 and this is the link to the bulb http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 i must say i am impressed with the light output..and the pics do not lie..now i could have gotten better results from the dimmer ones by keeping the shutter open but then the results would not be true... now this is just for gauges...i am going to test them one by one in a plate lights and in the front corner lights on both 94-97 and 98+ as well as test more along with taillight and blinker bulbs comments? questions? all these bulbs were paid for out of my pocket and nothing swayed my opinion other then results thread update! the company v-leds gave us 10% off our orders... promo code is s10forum 194 plate light test http://www.s10forum.com/forum/f62/le...ml#post5729249 3157 tail light test http://www.s10forum.com/forum/f62/le...ml#post5729281 http://www.s10forum.com/forum/f62/le...html#post57293 interior light test http://www.s10forum.com/forum/f62/le...ml#post5729328 dome light test http://www.s10forum.com/forum/f62/le...ml#post5736733 foot well test http://www.s10forum.com/forum/f62/le...ml#post5736751 Last edited by orangesonoma : 11-15-2008 at 10:39 PM. |
forum idiot
re: 194/3157/211 led bulb comparison
this test is for you black face gauge lovers
regular bulb ![]() straight forward led ![]() flat top ![]() 360 degree ![]() i did not do a one second shutter but i can if you like Last edited by orangesonoma : 10-18-2008 at 01:50 AM. |
Moderator
bad ass. now make me a list of all the bulbs i need to do my interior and exterior in bad ass led's.
i pay in sonic |
forum idiot
Kurrupted Kreations
nice info
Moderator
forum idiot
after seeing the bad results with the other bulbs i wondered what it would take to see them in the gauge...well i set the camera for a 4 second shutter
my results regular bulb ![]() forward facing led ![]() flat top led ![]() 360 degree ![]() |
♠ Camber'd ♠
good info...
i need to install the ones i have... |
Moderator
360 degree ftmfwwww
good bye red, it was fun
I have a different set in my cluster, ther have the clear refractor arond a single LED, ill try to get you some pics, also i alsp have an extra first gen clear corner marker i could send you for testing.
-Work in Progress-
Great info. I had tried some LEDs in my gauges when I first got them and was not impressed at all. This helps to eliminate all the guess work and trial and error situations. Thanks for spending your time to save us some.
forum idiot
B&B Customs
Location: Rolling in the Midwest in the Driftwood Metallic S10 User is: OffLine |
Good info Brian.
forum idiot
i have used ones similar with good results... http://superlumination.com/images/au...2face_r_wm.jpg 4 LED 2 Face High Flux http://autolumination.com/festoon.htm |
B&B Customs
Thanks Brian. I edited my post cuz I was like oh crap this is only for the 194 someone is going to flame me. Thats what I couldnt find is ones that shined both ways. Due to with the single sided which ever way you point it either its looks kinda like to lines in the housing when you face them out or it really dim when you face them in.
forum idiot
i know what you are talking about and i wish someone would have tested them in the first place...since you have no idea how they are going to look in the housing... |
getting shit done
This is why I leave the electronics to you. Great Info BTW. Thanks for the testing.
B&B Customs
forum idiot
V8 with bags
those people are cool to deal with? Ive been needing some new brighter bulbs for my tails but never want to just order from some turds on ebay.
needs to be lower...
Any pics of a 360 LED install in a cluster?
I'm Back!!
Sweet write up!
#24 |
B&B Customs
#25 |
The Dreamsicle
Those are sweet. x2 on pictures of them in a cluster. thats where i really want to put some.
#26 |
![]() these are what i used in my cluster, i got them for free so it was no question, there was one dark spot that i used one of the extras and just wired it into the area where it was dark. ill try to get some pics tonight. i am happy with them in the cluster, i wonder how they would work in a gauge. |
#27 |
forum idiot
#28 |
CDN 2WD 2Gen 4-Door!
Good comparo brian!
Im interested to see the 360's in a gauge cluster too. The single foward facing LED looks good in a cluster, but, wonder what a 360 or flat top would look like! Also, like we talked about in the other thread, i got my LEDs with the 6-facing in the mail the other day for my sidemarker/backup lights. In a day or two, ill do a comparo with halogen 194, sinlge led, and 6 led and email you my results if you like? Last edited by K Dawg ONE : 10-19-2008 at 02:35 PM. |
#29 |
Registered Boozer
I just bought the 74, forward facing, single red LED from www.autolumination.com. You think those are ok. I wish i would have seen this before i bought them.
#30 |
forum idiot
#31 |
forum idiot
#32 |
Registered Boozer
sweet
#33 |
R/C Guru
This is awesome, just in time too! I was about to give a guess and order but not anymore...subscribed.
#34 |
Nimbus9.net
I was just trying to figure this out for my motorcycle. Great info! Easy to see and understand as well. You posted this at the perfect time for me. I'm waiting for a new headlamp to arrive and now is the easiest time for me to get to my cluster
#35 |
Very awesome thread. Looks like the gauges in my truck need some changing!
#36 |
how well do these dim? I have some leds from superbrightleds.com and they dont dim very well. Almost to the point where i'm about ready to change them back.
#37 |
forum idiot
most led bulbs do not dim well since they work on way less voltage...
#38 |
Moderator
wtf, nothing new yet? slacker
#39 |
forum idiot
#40 |
Moderator
on what? more bulbs?
#41 |
forum idiot
#42 |
getting shit done
Need any money for more bulbs? I'll send you some just to see the comparisons.
#43 |
forum idiot
#44 |
getting shit done
how much do you want? be reasonable, lol
5, 10, 20,? |
#45 |
forum idiot
well i can send you the bulbs after i review them if you like..so that way we both win...
#46 |
getting shit done
no need, just feel like being nice lately. Give me your paypal address or how ever you would like the money sent. |
#47 |
sweet can't wait to see gauge cluster tests
#48 |
forum idiot
#49 |
Moderator
#50 |
I AM CANADIAN
I wonder if they will look just as good as the LED's from superbrightLEDs like others have installed.
