Location: Indianapolis (Castleton), In User is: OffLine ![]() |
how to wire square d
how do i wire my square d up with 2 viar 450s? i dunno what goes where on it or what size wire to exactly use?
Tuckin swirls bitches!
Re: how to wire square d
very much appreciated i remember seeing a thread a while back ago but wasnt finding it to easy today
Ok I think I have it figured out per Kris Dye. Heres a Diagram:
The compressors can be an 8 or 10 gauge wire and the Positives str8 to the battery should be a 4 or 8 gauge wire with fuses to be safe. A relay is not needed with the square D because it works as a relay. Feel free to correct me if I'm wrong. In my picture I don't have ti finished wiring and wont for weeks cause i don't have the money to finish it. |
To wire and have an ignition source turning it off and on wire in using 30/40 amp relays.
Adapt And Overcome!
Here is if you want to wire it to you Ignition so your compressors dont run with your truck off killing your battery!!
![]() Last edited by Jadesmarine : 07-05-2008 at 12:43 AM. |
or if u want u can run 30/40 amp relays but it has to be 1 per compressor... he has 80 amp solenoid so he can use 1 solendoid for both the compressors
2 Tone
quick question. If your running this ps with an EDC and the truck is off and the pressure goes down in the tank, the ps will suck the juice from the battery and stay open right?
or do you wire it to ignition source so it doesn't kick on unless the truck is on? Is there a diagram for this |
refer to jademarine's last post and his picture
2 Tone
yeah thats what i thought, i just had to look at it closer
Adapt And Overcome!
This diagram may be easier to read!!!! ![]() |
