how to: sound and light door switch
Old 05-15-2008, 01:17 AM   #1
Panda s10 driving mofo.
PandaS10's Avatar
PandaS10 is on a distinguished road
we've all been there, working on something inside the truck with the door open and the key in the ignition so we can listen to some tunes while we work. all the while an annoying pingggggggggggg sound rings out through the music unless you've really got it cranked. well that happened to me yet again tonight, and i decided to do something about it and i brought out the camera to help you, the loyal s10forum members, get rid of this headache producing sound. when i started i had two goals, keep the door activated light functional, and get rid of the noise. and this is how i did it.
...note, i have a 97 s10, I don't know if it works on first gens or 98^ second gens. this is how i did it, suggestions are welcome, this is my first ever how-to, hope it helps.
First i located the switch. there is one on each side of the truck but after i did the first one, i realized you didn't have to do both. so i did the drivers side. if you don't know what it looks like, its next to the fuse cover and appears to be a small stick poking out of the side of the dash.
next, i partially removed the dash bezel (it pops off but there are two screws in the top of the gauge cluster)
and i removed the bolts that hold the lower parts of the dash and the plastic under the steering column (careful not to break the plastic sticks that hold it on...)
you don't have to fully remove the lower part of the dash, you just need to be able to squeeze your hand in there to locate the wires and disconect them.
then i located the switch assembly
its hard to see and its a tight squeeze so i used a small flashlight.
you can either squeeze your hands and a flathead screwdriver in there and disconnect the wires like i did, or you can pull the assembly out and then disconnect it. i suggest the second option, much easier imo.
either way you need to remove the switch assembly. i used needle nose plyers to pull it out.
be carefull when removing the assembly as it is two main pieces that seperate.
the assembly looks like this when removed.
and the wires should be dangling somewhere inside unless you managed to keep them in the hole.
next pull the black half of the assembly off of the white part and take care not to lose the spring that is inside.
now examine the white half and you should find three narrow bars on the inside.
simply pull out the bar on the far left if the bars are on the bottom. ( again the needle nose were helpful.)
the bar you just removed should look like so...
and the white piece should now look like this..
now reinsert the spring into the white piece...
and make sure everything lines back up...
and snap the two pices together.
make sure the stick springs back into place after you push on it.
next, take those wires and feed them through the hole,
line up the switch and wires,
apply pressure until they snap together. it should look like this when assembled.
now push the switch through the hole..
and push until it snaps into place...
reassemble everything...
and enjoy having the freedom to open your doors, with nice silence, and fully functional lights. hope this is helpful.
Old 05-15-2008, 01:20 AM   #2
^ Im With Stupid ^
stevehh's Avatar
Location: Levittown, PA -=- North East Philly -=- Trenton, NJ
stevehh is an unknown quantity at this point
Re: how to: sound and light door switch
damn dude cool
Old 05-15-2008, 01:22 AM   #3
PandaS10's Avatar
it only took me about ten minutes. unfortunately it took three years to finally do it...makes me feel dumb. lol. totally worth it though.
Old 05-15-2008, 08:05 PM   #4
PandaS10's Avatar
bump so people can see this.
Old 05-15-2008, 11:01 PM   #5
immexicansostfu's Avatar
immexicansostfu is an unknown quantity at this point
wow this is really helpful. this should be a sticky or something. I F***ING HATE that noise!!!
Old 05-15-2008, 11:03 PM   #6
DeXtreme on 20/22's
Xtreme24's Avatar
Xtreme24 is an unknown quantity at this point
I just pulled the buzzer out of the BCM.
Old 05-15-2008, 11:54 PM   #7
PandaS10's Avatar
I guess that works too. i don't know what the BCM is though.
Old 05-16-2008, 01:18 AM   #8
Is in Austraila.
travy's Avatar
travy is on a distinguished road
good job on this how to.
Old 05-16-2008, 01:41 AM   #9
PandaS10's Avatar
thanks. i tried not to let it get confusing.
Old 05-20-2008, 04:39 PM   #10
did this and i skipped the trouble with having to partially take the dash off i just unbolted the fuse board moved it and then pulled it out. took 3 minutes.
Old 05-20-2008, 05:03 PM   #11
Neckro211's Avatar
Neckro211 is on a distinguished road
Is this the same for the 98+?
Old 05-20-2008, 05:21 PM   #12
Vertically-Challenged Mod
xloud9t5gmcsuvx's Avatar
xloud9t5gmcsuvx is on a distinguished road
nice write up.. ur lights still work though right?
Old 05-20-2008, 11:48 PM   #13
Pac is a hackin!
comics22's Avatar
comics22 is on a distinguished road
haha me too went nuts one day and found it and took it out. i thought i could remove select pins but i musta removed an important one cuz now nothign works lol
Old 05-21-2008, 11:36 PM   #14
yes lights still work and buzz still works when ur lights are left on to.
Old 05-22-2008, 10:30 AM   #15
Dialed!
tg900's Avatar
tg900 is on a distinguished road
comics 22, you may have removed the wrong side.
the 98+ are similar, i had to take the sensor out of my passenger side so i could mount my sirius box on the inside of the dash. i never took the sensor apart, but it looks and comes out just as easily
Old 05-22-2008, 12:41 PM   #16
aaronajb1981 is on a distinguished road
Just be aware if you install an alarm that if you go to the BCM for the door triggers (like some tech sheets say to) that they may not test and a doom light is what you will need to.
Old 05-22-2008, 12:53 PM   #17
Photoshop Fiend
ACE2790's Avatar
ACE2790 is on a distinguished road
How do you know which left bar to pull out? Im asking how do you know you you have the white thing lined up correctly to pull out the correct "left bar"?
Old 05-22-2008, 02:18 PM   #18
Whood'a Thought
russell's Avatar
russell is on a distinguished road
isnt it the orange wire your disconnecting?
The plug has the ends off center, hold it where the plugs are towards the bottom and get the left one
Old 05-23-2008, 12:40 AM   #19
vv future wife vv
Merritj2417's Avatar
Merritj2417 is on a distinguished road
are the assemblies the same on 98+?
Old 05-23-2008, 03:17 PM   #20
Whood'a Thought
russell's Avatar
I just tried this and now my interior lights won't go off...WTF?
any help?
Old 05-23-2008, 03:23 PM   #21
donut king
lee-mill's Avatar
lee-mill is on a distinguished road
"...note, i have a 97 s10, I don't know if it works on first gens or 98^ second gens."
he answered this already
Old 05-23-2008, 03:25 PM   #22
Whood'a Thought
russell's Avatar
anybody? it was on my 95
Old 05-23-2008, 03:28 PM   #23
Bring back *DARK STYLE*
droppedime's Avatar
droppedime is on a distinguished road
any help?
You put it all back together right?
Old 05-23-2008, 03:37 PM   #24
Whood'a Thought
russell's Avatar
It was grounded to the spring. I fixed it, and yes it was put together right
Old 05-28-2008, 05:09 PM   #25
PandaS10's Avatar
sorry about the delay, i've been in canada. alright on the bar/pins you pull out. with the bars on the bottom, pull out the left bar. i don't know about the 98^ models. i know this is how i did it. i haven't had any problems at all.
Old 05-28-2008, 08:04 PM   #26
Pac is a hackin!
comics22's Avatar
i might have to do this. but first gotta get a new buzzer assembly lol
Old 05-28-2008, 08:25 PM   #27
FLOWIDA STUNTERS
mudkingchevrolet is on a distinguished road
hey the lights that light up the drivers and passengers floor stay on after i close the door, how i can i jerry rig this so they dont go on and stop draining my battery?
[IMG]http://[/IMG]
Old 05-28-2008, 11:46 PM   #28
Pac is a hackin!
comics22's Avatar
your door pin switches are broke. find out what one and reassemble/get new ones.
they come on with the domelight if u havent noticed...
Old 05-29-2008, 12:30 AM   #29
glass machine
95 pinkpanther is on a distinguished road
this....is....awesome. i'm going to do this tomorrow, no... tonight. i hate that god damn noise.
Old 05-30-2008, 08:29 PM   #30
my truck is a 95
95 S_Trucker's Avatar
95 S_Trucker is on a distinguished road
thanks for finding out how to do this. Now I can use my screwdriver as a screwdriver from now on. lol
Old 05-31-2008, 07:53 PM   #31
Works too much.
BlownDime's Avatar
BlownDime is on a distinguished road
Where can I get one of these doom lights?
Old 05-31-2008, 07:59 PM   #32
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
DJDAudio is a glorious beacon of lightDJDAudio is a glorious beacon of lightDJDAudio is a glorious beacon of lightDJDAudio is a glorious beacon of lightDJDAudio is a glorious beacon of lightDJDAudio is a glorious beacon of light
Old 05-31-2008, 09:47 PM   #
