How to: H4666-H4 conversion with HIDs and 4x6 - S-10 Forum
post #1 of 21 Old 04-19-2010, 02:21 AM Thread Starter
User is: mcguire6799 is offline
Okay, I just recently did the H4 conversion on my truck, and ran into problems I couldn't find a solution to on here so I figured I would give a shot at a how to myself to maybe answer some questions others may have.
First a parts list:
I used a set of H4 high temp pigtails from Autozone brand was doorman, cost me like $12 for the 2 only sold in package of two.
Wire strippers
Wire crimpers
some form of wire connectors(butt, quick splice, bullet, spades, etc...)
H4 bulb recommended but can test with just the HIDs
Okay first off you cut off you original h4666 plug on the DRIVER'S side. There will be 2 brown wires(low beams), 2 green wires(high beams), and one blue wire(ground). You will need to see which of the brown wires jump over to the passenger side.
Strip the ends of the brown wires and the blue wire. Twist the ends of the pigtail ground(black in my case) with the blue wire(ground). Then take the wire from the pigtail for the low beams(red in my case) and twist it with one of the browns. You can either just test with your HID kit that is already wired up or get an H4 bulb which should have came with your headlights if you're doing 4x6.
Turn on the lights, if you hear the relay kick on(if doing HID test) and no lights, wrong brown wire. If the H4 bulb doesn't kick on, wrong brown wire. If this is the case just switch to the other brown wire, and it should work just fine.
Once you have figured which wires belong together, use the splices of your choice to connect them permanently, I chose bullet connectors in case I need to disconnect them some day.
Also you need to disable your daytime lights, which if you have NO factory foglights, simply take out fuse 15. If you have factory foglights, check the how to on the forum to disable them.
If anyone needs help with HID wiring, I can help with that too. The kit I have is a 10000k, came with relay, balasts, bulbs, and all wiring for $60(shop here in Indiana I get killer deals at) I am also running just a black housing projector 4x6, paid $80 for them new. For $140 for HID and headlights.
post #2 of 21 Old 04-20-2010, 11:32 AM
Electrical Mod
deathphoenix99's Avatar
Re: How to: H4666-H4 conversion with HIDs and 4x6
neat. But they'd be brighter if you didn't get the projector style.
post #3 of 21 Old 04-21-2010, 12:28 AM Thread Starter
only way I could go without paying a ton heh I am just gonna get some driving lights. I had sealed beams.
post #4 of 21 Old 04-21-2010, 12:37 AM
Electrical Mod
Don't forget i have a 94 that also had sealed beams. I did the same addition, and mine cost about the same price total. But mine was $30 for the lamps. And $99 for the HID's, but they came with a relay harness and they have a high and low beam, but uses the HID. There's a few threads in here that show my set up.
post #5 of 21 Old 04-21-2010, 12:46 AM Thread Starter
ah cool cool. I ain't too concerned about it, I love projectors my civic has them too, but no HID kit, just HID bulbs if that makes sense? Haha. I am just gonna get a set of KC driving lights and they will match my KC off road lights.
post #6 of 21 Old 02-15-2011, 01:25 AM
User is: aosparks is offline
hey man, I'm in idiana too, wanting to make the conversion, I was wondering where you got the hids from???? I've looked online and all the sites either look super sketchy, or are ridiculously high priced
aosparks is offline
post #7 of 21 Old 02-15-2011, 01:29 AM
Electrical Mod
^^^DDMtuning.com
post #8 of 21 Old 02-15-2011, 11:40 AM
Thanks man, and def thanks for posting this! I've been getting sick of the sealed beams in my sten and wanted to do something like this but didn't know how!
aosparks is offline
post #9 of 21 Old 02-15-2011, 02:34 PM
black92 4.3's Avatar
User is: black92 4.3 is offline
did it on mine. super easy
1992 4.3 ex cab s10 SOLD.
now 1996 ex cab 4.3. cai, magnaflow with cutout, 33mm front swaybar, hellwig rear sway bar, 2/3 drop , GM roll pan, camaro RS rims, center console shifter, blazer front
1998 trans am bolt ons with cam SOLD
1995 camaro- full exhaust, intake, gears, spray.
post #10 of 21 Old 02-15-2011, 05:33 PM
Blazin_Jason's Avatar
User is: Blazin_Jason is offline
That's a lot of glare, brutal :S
85 Blazer 4x4, 350, 3" BL, 33's, project
89 Jimmy 4x4, 4.3-->5.7 project
90 Jimmy 4x4, 4.3, DD, 2" BL 31's
post #11 of 21 Old 02-17-2011, 07:33 PM
Joshdwr's Avatar
User is: Joshdwr is offline
just finished mine. not too hard ha. thanks for the help!
Joshdwr is offline
post #12 of 21 Old 04-09-2011, 08:02 PM
austinsonoma's Avatar
User is: austinsonoma is offline
can you swap beetween brights and dim if you do this??
post #13 of 21 Old 04-09-2011, 10:50 PM
User is: losixxx-nt is offline
add the glare to the purple Ricer look
do everyone a favor and use proper HID retro to zero out the glare.and go with a 5K or lower temp.
post #14 of 21 Old 08-27-2011, 03:14 AM
User is: Wiqqur is offline
I just did my conversion today I'm having a problem mine are no way brighter then the stock sealed beam and my passenger side blub cuts out after 13 minutes of use PLEASE I need help , Another thing I replaced my passenger side pigtail to the h4656 from 4666 on your conversion you said you did the driver side well I couldnt do my driver side for the fact that the battery is on the passenger side in which you must connect your relay to here is a picture of mine lit at night they barely have any glare and I have flash lights that put out more light I'm really pissed off about the whole situation because my girl bought them for me as a birthday present off ebay and im not sure about returning them after they have been hooked up aslo the brand of the kit is O-nex please can some one guide me in the right direction into maybe fixing this problem or atleast figuring it out here
Wiqqur is offline
post #15 of 21 Old 08-31-2011, 01:50 PM
muddyman184's Avatar
User is: muddyman184 is offline
Right after it cuts off i would check with the lights still on to see if you have power coming out of you ballast and power going into your ballast could be as simple as that and with the brightness what color did you get looks like 10k they should be brighter but the higher number you go the darker the color will be and harder to see
post #16 of 21 Old 08-31-2011, 02:29 PM
Electrical Mod
The brightness is dependant upon the quality of housings and the color of lights you buy. The white/yellow will be the brightest.
post #17 of 21 Old 09-03-2011, 07:03 PM
User is: Ethicz700 is offline
First a parts list:
Wire strippers
Wire crimpers
nice job
post #18 of 21 Old 09-19-2011, 06:52 PM
kzak's Avatar
User is: kzak is offline
so what do we do with the brown wire that jumps to the passenger side? just leave it? im getting read to do my conversion and am a little confused,
kzak is offline
post #19 of 21 Old 10-03-2011, 03:48 PM
kzak's Avatar
nvm, i found out you have to spin the 2 browns together =\ same with the greens, is there a reason you didnt hook up the highbeams? mine work fine.
kzak is offline
post #20 of 21 Old 12-01-2011, 11:40 PM
Texas dimes
biggy's Avatar
User is: biggy is offline
i know this is an old thread ,but is what kzac is saying about the 2 brown wires and 2 greens correct?...im in the process of doing the conversion...thanks
biggy is offline
post #21 of 21 Old 12-01-2011, 11:45 PM
kzak's Avatar
Yup. Mine still work so it must be right. Haha
kzak is offline
