#51 |
Useless posting member
Re: How to Broken Hazard Switch Repair
#52 |
Beer time!
Any of you geniuses ever think to look in a junkyard for a replacement turn signal assembly? HAHAHAA
the whole assembly costs about 10-20 bucks and it's quite easy to replace. |
#53 |
Ticket Magnet
#54 |
#55 |
Beer time!
Why...you say?...... This is why... |
#56 |
Ticket Magnet
Without a little more info it's hard to make an accurate diagnosis. |
#57 |
Beer time!
#58 |
Ticket Magnet
^^^ ignorant^^^... ![]() |
#59 |
Beer time!
keep the thread on the same topic and stop gettin your panties in a wad... |
#60 |
I got a good deal on brand new turn switch assembly, so I've already got that anyway and can sell the hazard light switch if I have to replace it. Problem is the same, even after replacing it now, most of the time anyway. During the day though it seems to work just fine, obviously... Is there a write-up or any good experience on how to swap out the whole assembly? I may just take off some work tomorrow and replace it if I can find some quick, accurate steps to swapping it out. Thanks! |
#61 |
Ticket Magnet
What year truck do you have?? Thru '97 they had rocker style light switches. The contacts tend to corrode and when the switch gets hot, expansion causes the contacts to expand ( my theroy). I had the same problem with the dash lights and headlights after about 20-25 minutes. Try moving the light switch up and down gently. If iot is the switch, the lights will flicker on/off when you move it. Picked up a new switch and problem solved for $20. |
#62 |
By the way, the basic rundown has been that I had a broken hazard switch sometime ago. I used electrical tape to hold it down until recently, which always did the trick.
Finally, it started being difficult and out of nowhere it wouldn't allow my brake lights, signals, etc to work when I turned my lights on. I have replaced the hazard light switch, which seemed to work to begin with, or some of the time anyway, but now it has been keep the left turn signal light on the dash on solid (not blinking) and is again not allowing my rear lights to turn on at all with my lights turned on. Is there anyway a ground or some sort of fuse could be the problem or is it more than likely the entire switch? Fuses in the fuse box seem to all be just fine... |
#63 |
Makes me wonder if this could be the problem as when I first replaced the hazard light switch it seemed to work just fine with my lights turned on... |
#64 |
Ticket Magnet
#65 |
Ticket Magnet
#66 |
Thanks a lot, I'll have to try this tomorrow. If that doesn't work looks like I will be trying to get that assembly in, as I don't see it being much of anything else... |
#67 |
Ticket Magnet
#68 |
If that's not the case, don't you think it's looking like the turn switch assembly for sure? |
#69 |
Ticket Magnet
#70 |
I just can't imagine it being fine for so long with electrical tape on it and then all of the sudden stop letting my brake lights or anything work with my lights turned on. Just really strange how it does that all of the sudden. |
#71 |
Ticket Magnet
#72 |
I will for sure! Thanks for the help. Hopefully I can figure it out. Just seems like I have read so much about fuses and switches and grounds going wrong that I don't know whether to end up tearing into this assembly deal or go looking for a needle in a haystack!
#73 |
I'm going out to check the lights now...
#74 |
Ticket Magnet
Well....it's 0553...what's the holdup?? ![]() |
#75 |
Makes me wonder if some type of switch has gone bad or something is shorting out. |
#76 |
Ticket Magnet
That's probably the relay..well...I'm out of ideas..good luck. |
#77 |
#78 |
Ticket Magnet
#79 |
Guess I'm going to have to find someone who needs one... |
#80 |
none of the pix are working on my compe could some one guild me to where i can see the the repair pictures just to make sure im doing it right? thank that would be nice. btw i got a early 96 s10 slightly liffted and a camper top on back my names matt btw.
#81 |
Go get the hazard switch replacement piece from a dealership, which often has to be ordered in, if nothing else but the red button is broken. If I remember right, it was pretty simple to remove the broken button and then slide the new piece down into place.
#82 |
David
This thread saved me a ton of money...I was rolling around for about a year with 3 plastic forks holding down the hazard swtich..lol..
Though, when my dad and I went to take out the old one..it was a hassle..I know some of yalls came out easy..mine didn't..and for the people who are having problems..what we did was..drill a hole into the center of the button...screwed in a screw..and jerked the hell out of it..worked..after that you may have to dig out the rest of the housing..slip new one in..no more headaches! lol |
#83 |
Glad to hear it worked out well for you!
#84 |
Emaleth66
wow, this is awesome, i was fliping out thinking i was gonna have to go to dealer and get robbed!
#85 |
I still have an ENTIRE turn signal switch assembly right now. If anyone needs it, I would be willing to sell it for less than I paid for it. Still in the box.
#86 |
Alright guys, I'm going insane. I went out and bought the new hazard piece today from a dealer. Got home, couldn't get the old piece out, went to home depot and bought some thinner needle nose's. Got the thing out in a few pieces. Greased up the new part, go to put it in-Nope, not gonna fit. It's the part number that was specified and everything. What's the deal? I read it would fit a 1996 S10. Is there a different switch for that year???
Thanks for any info, I'm about to scream. ![]() |
#87 |
Wow, it helps to take out the housing too. I'm an idiot. And blonde.
Hazards work not but still not turn sigs. Back to work... |
#88 |
WOOT! Nevermind, all is working! All hail the replacement hazard switch!!
#89 |
where can i get the hazard switch i cant seem to find it nowhere
#90 |
. if you still have it |
#91 |
hack, bag, and drag it
broke my hazards working on the dash and what not all the time, fixed it in 3 min (timed it) will remember to remove hazard switch ever time i take the dash off now
#92 |
#93 |
sounds good
![]() how do i send u the money? |
#94 |
#95 |
No problem, bud.
Anytime! |
