[How To] AVS Door Acuator Install
Old 03-05-2007, 01:34 PM   #51
Acrophobia1's Avatar
Re: [How To] AVS Door Acuator Install
what's the avs website
Old 03-05-2007, 02:15 PM   #52
Kris
AVS
Old 03-15-2007, 11:57 AM   #53
This setup sounds and looks like it's so easy to install and wire. A lot easier than my car alarm. So what source would you use the back up for, i mean do you have to have a 12v source. Just wondering because i don't want to break glass.
Old 03-15-2007, 12:28 PM   #54
Beyond Basic.
Basic's Avatar
the pre-wired kit has a backup made for you that you can run to anywhere.
Old 03-15-2007, 02:39 PM   #55
Kris
^^^ hes right
Old 03-18-2007, 07:23 PM   #56
Deftones EST.1988
cherrywaves's Avatar
so you can wire it to your own switch??
Old 03-18-2007, 07:39 PM   #57
Beyond Basic.
Basic's Avatar
No it's a couple wires that are meant to have power run to them + and - then it'll pop open your doors, or at least one anyways. lol
Old 03-18-2007, 08:27 PM   #58
Deftones EST.1988
ohhh alright gotcha like just touch them to another cars battery or something for an emergency? thanks dude
Old 03-18-2007, 11:07 PM   #59
Kris
yup....
Old 03-28-2007, 10:34 AM   #60
forum idiot
orangesonoma's Avatar
dude..lol
Old 04-07-2007, 12:30 AM   #61
i was wondering if these will also work with a 88 s10??
Old 04-07-2007, 03:41 AM   #62
Kris
our kit for the older s10 is similiar but installs slightly different...
Old 04-29-2007, 07:03 PM   #63
I just put my kit in, and I am having trouble with binding up where the latch arm and acuator arm connect, any HELP????
Old 04-29-2007, 10:16 PM   #64
Kris
loosen the nut little bit then try it..you may have it too tight
Old 05-06-2007, 01:48 AM   #65
Like my Boobies??
s10junkie98's Avatar
any info on when your sale is gonna be???
Old 08-04-2007, 01:00 AM   #66
EWood91's Avatar
hey i got some of these for my 88 but the spring/popper that i got it said i couldnt put them by the latch so where do i put them?
Old 08-04-2007, 10:14 PM   #67
Kris
you would want to be them by your door hinges
Old 08-07-2007, 04:40 PM   #68
IZ
sik4door's Avatar
this kit is great just installed it on my 4 door and love it but i did run in to a lil problem with the dome light if any one has the same problem just leve all the plugs out of the latch and your good to go. well thats is you have the plugs ..lol
Old 09-01-2007, 09:59 AM   #69
Stock tires with 5.7
TuckaBlaze's Avatar
How Much Noise does these make?
Old 09-01-2007, 06:02 PM   #70
Kris
hardly any.
Old 09-02-2007, 02:30 AM   #71
TuckaBlaze's Avatar
Quote: Originally Posted by AVS_KRIS
hardly any.
so its alot less then a 45lb solenoid?
Old 09-02-2007, 03:39 AM   #72
Kris
as far as sound...lol...ours are just a lil sound when the solenoid scares the shit out of people cuz its loud lol
Old 11-28-2007, 02:35 AM   #73
Real Men Wear Skirts!!
my2ks10xtreme's Avatar
I noticed no one really gave a good website to buy these so I'm going to provide a couple links for you guys:
This link will get you the poppers with the pre-wired relays, all you need to do is tap into your extra channels on your alarm...
http://avsontheweb.com/store/product...2e0fa36104b89c
If you dont have an alarm you can buy either one of these kits (links below vary from poppers with alarm, poppers with 3 or 12 channel remote system):
http://www.suicidedoors.com/AVS94-03...rPopperKit.php
Old 11-28-2007, 12:19 PM   #74
Kris
^^^^^ thanks
Old 12-20-2007, 07:51 PM   #75
I have everything wired up, bolted in, set and everything, but i can't figure out why the remotes don't work. i called the tech guy and he told me how to program it, but the red light never turns on with the 12 volt source. i think the 12 channel brain is dead or something. any advice?
Old 12-20-2007, 11:01 PM   #76
Kris
your kyle right? i think im alil late...you got it worked out right?
Old 12-21-2007, 04:47 AM   #77
haha sadly no. i went through all my connections like 3 times, tested it all, and yea, its just not working. i mean i tried to reprogram and im not even getting the red light from the reciever when i apply direct power. yea i just bought a new reciever and hopefully that will fix it. until then i'll just keep checking everything and looking for problems. you don't think its in the relay box isnt putting power towards the box? i thought that for a while till i tried to reprogram. who knows. i got all week to mess with it. maybe i'll figure it out... i'll let you know if i do.
Old 02-25-2008, 01:55 PM   #78
sosolos10's Avatar
Thumbs up Re: [How To] AVS Door Acuator Install
this is the easy door acuator kit that i have ever installed on any car or truck
Old 10-29-2008, 01:15 AM   #79
Wizard31
ethanevans31's Avatar
is there a bolt on kit for a 92 s10. and wheres the site to order them from
Old 10-29-2008, 02:00 AM   #80
I Need $
supasoulja's Avatar
did you even read the thread? its in post #52. avsontheweb.com
Old 06-29-2009, 06:52 PM   #81
I'm wanting to get this kit, but I'm confused as to what the "Interior Rocker Switch" option is, on the order form.
Old 06-29-2009, 07:09 PM   #82
TuckaBlaze's Avatar
any way to make this work with with SDs?
Old 06-29-2009, 07:10 PM   #83
forum idiot
a switch to control the popers from inside the cab
Old 06-29-2009, 07:12 PM   #84
bagged DD on 20's
Big_Bake's Avatar
what exactly do you mean? this attaches right to the door latch and takes care of everything in the door. all you gotta do is hook it up to your alarm/remote
Old 06-29-2009, 07:24 PM   #85
forum idiot
i think he is asking about suicide doors
Old 06-29-2009, 07:37 PM   #86
I'm assuming since it is optional on the order form, a switch of any kind is optional, or do I have to have a switch to open the door from inside?
Old 06-29-2009, 07:42 PM   #87
TuckaBlaze's Avatar
I am asking about suicide doors. I was thinking about how hard it would be to mod these to make them with with a Suicide kit from SD.com
Old 06-29-2009, 10:44 PM   #88
bagged DD on 20's
Big_Bake's Avatar
might just wanna get the universal actuator, they are buy one get one free right now, so $50 for two.
Old 06-30-2009, 03:49 AM   #89
TuckaBlaze's Avatar
from where? are they good ones? I dont want em wearing out the first week i get them haha.
Old 07-03-2009, 08:50 PM   #90
bagged DD on 20's
Big_Bake's Avatar
the AVS ones from AVS themselves. they should be as good of a quality part as the bolt in ones. better than solenoids IMO
Old 07-06-2009, 05:09 PM   #91
I was wondering. It would be possible to install the actuator first and then shave the handle later, right? I don't have access to all of the tools to do bodywork right now, so I was thinking of installing them and leaving the handles until I could shave em. But with this kit, it eliminates the ability for the door to lock, so I don't know if this idea would be possible.
Old 07-06-2009, 11:36 PM   #92
bagged DD on 20's
Big_Bake's Avatar
yeah you could do that. you take out all the rods except the interior handle one. all the outside handle will do is cover the hole in your door until you actually shave it. i'm actually gonna do it that way on my buddy's vw golf, get all the inside stuff working first before i pull the handles off and weld in fillers
Old 07-07-2009, 12:02 AM   #93
~02DIME~'s Avatar
I did that, only problem I had was that the handle got in the way of the door pusher so it didn't pop out all the way.
Old 07-07-2009, 03:39 AM   #94
So the door wouldn't open, when you left the handle?
Old 07-08-2009, 11:51 PM   #95
~02DIME~'s Avatar
depending on where you put the pusher. I popped out the black plastic filler on the door itself. In the spot the bolt of the pushe will hit the handle so it doesn't compress all the way. It'll pop it open but not all the way, it'll "half latch" again almost like you didn't close the door all the way. Just make sure your there when you pop it and you're all good
Old 07-09-2009, 04:04 PM   #96
Alright. Thanks. That just helped me make up my mind. I'm gonna go ahead and order the kit.
Old 07-09-2009, 07:10 PM   #97
~02DIME~'s Avatar
no prob man you won't be unhappy with that kit
Old 07-09-2009, 10:53 PM   #98
bagged DD on 20's
Big_Bake's Avatar
yeah i've got about 2 years on the kit and it hasn't failed me yet. pops everytime. and the emergency wires on the pre wired relays came in handy once or twice
Old 08-14-2009, 11:39 PM   #99
Where do you get those door pushers?
Page generated in 0.68321 seconds with 31 queries
[Output: 201.37 Kb. compressed to 183.15 Kb. by saving 18.22 Kb. (9.05%)]
