how do i bypass the pink ebrake wire for dvd player? - S-10 Forum
Old 10-22-2007, 05:02 PM   #1
slammed99sseries's Avatar
i have the jensen phase linear uv7i dvd player and i was trying to save money and was wondering how to bypass the wire using a toggle switch. well i bought a 3 way toggle switch and i dont know if this is the corrrect one or not but if it is how would i go along using this?
Old 10-22-2007, 05:11 PM   #2
BUT I WONT PUT IT HERE
bmxbang's Avatar
Re: how do i bypass the pink ebrake wire for dvd player?
well dont quote me on this because i have no idea what model mine is but its a jenson indash and theres a code floting around that way you dont even have to mess with the wire... ill hook ya up give me a second i just hope its for your model 2.
Old 10-22-2007, 05:13 PM   #3
bmxbang's Avatar
works on these JENSEN VM9311,VM9411, VM9511TS and/or 9021TS
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
Old 10-22-2007, 05:13 PM   #4
i gotta order the remote for 16 bucks
Old 10-22-2007, 05:15 PM   #5
bmxbang's Avatar
i dont think i even used that 1st step but i could be wrong. i have been told this dosent work on the newer model jensons though but its worth a shot
Old 10-22-2007, 10:23 PM   #6
o chit...
ßɭĬƮƵ's Avatar
just take the wire and ground it. thats what i did with mine and it worked.
Old 10-22-2007, 10:35 PM   #7
Registered Coon-Ass
bubba99's Avatar
x's 2...but mine isn't a jenson
Old 10-22-2007, 10:43 PM   #8
got SFA?
Geoff03's Avatar
yup, just ground it and you'll be fine. i did that to my jvc and it works wonderfully
Old 10-22-2007, 10:46 PM   #9
AcrophobiA
layinlow88's Avatar
werd...try to ground it to itself....on the high dollar clarions...you have to power it...so you can try that also
Old 10-24-2007, 12:46 AM   #10
aight ill try it....
Old 10-24-2007, 12:57 AM   #11
(s)AINT
eric s's Avatar
be thankful its not a pioneer n2....damn soldering lol
Old 10-24-2007, 01:50 AM   #12
Token TSX Owner
ACE2790's Avatar
I have a new model Jensen and I got a bypass code off the net. Works great.
Old 10-24-2007, 02:32 AM   #13
SFBD 4 door
TrYiN2LaYaDiMe's Avatar
where did u find the code at tony
Old 10-24-2007, 04:01 PM   #14
Token TSX Owner
ACE2790's Avatar
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
There is the code, but to find it I just googled "JensenVM9312 bypass code".
Old 10-24-2007, 05:00 PM   #15
SFBD 4 door
ok thats what i was wondering the google part. i have the vm9311 but ive had mine for a while. and i already have the thing grounded but id rather have the code so i dont have to flip the switch all the time.
Old 10-24-2007, 09:03 PM   #16
Layin Low since 88'
dirty jerzey's Avatar
i got the phase linear uv8, anyone else got this? any problems with install? any tips? mines not in yet
Old 10-25-2007, 02:53 AM   #17
Can I get a hot tub?
Big_Bake's Avatar
yeah, i got the vm9311TS and i used the code but you do need the remote.
Old 10-26-2007, 04:20 PM   #18
Mr. Sparkle
Onimun's Avatar
SO did grounding it work?
Old 10-27-2007, 11:19 AM   #19
Rarely goes over 20mph
beaniebmx's Avatar
grounding it works, but its a pain in the ass for me atleast.
it took awhile for it to work, and then after sitting for awhile, it reset and i had to flip the switch again for awhile, then one time it didnt work, so i got fed up and went out and used the code bypass ACE2790 posted, and left the 2 wires i had just let them hang and whala, never have to worry about the switch anymore.
i have the phase linear uv8, i like it, but going from my olddddd jvc headunit, my subwoofer isnt as loud sounding, could be because of the one subwoofer amp out, instead of 2 like my old one
Old 10-30-2007, 04:52 PM   #20
S10Blazer98's Avatar
I have the same one you have. Which code did you use to disable it?
Old 10-30-2007, 09:47 PM   #21
sick & twisted
1sikPuP's Avatar
im not 100% sure on my model indash screen but my older one i just grounded the pink wire and had no problems, but my newer touch screen has that "parking brake sequence" crap that sucks, i was tryin to get the truck ready for a show and i threw a toggle on the wire and run it for 3 seconds, then turn it off for 3 seconds, then kick it back on an it would come on. ima have to try that code on mine, i hope it works on mine too
Old 10-31-2007, 07:48 PM   #22
beaniebmx's Avatar
my phase linear uv8=jensen, has the pink wire, we hooked the pink wire to a switch, and then another wire off the other switch's pole to a ground, when you turn the switch on, it grounds and makes a connection, when you turn it off, it ungrounds, just like a lightswitch disconnects power when down, and connects when up.
it was fussy and didnt work sometimes, found a code to bypass it, and whala dont need it grounded at all, you have to redo the code if you disconnect battery or reset it though.
