hooking up a custom tach on 92 chevy s10 - S-10 Forum
post #1 of 32 Old 08-02-2009, 02:57 PM Thread Starter
User is: brettley is offline
i have a 92 chevy s10 ss 4.3L, and i want to put a tach on it, i have the tach all hooked up, but i need to figure out where to put the signal wire for the tach. does anyone know where it needs to go? any help would be greatly apreciated!
brettley is offline
post #2 of 32 Old 08-02-2009, 11:01 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
Re: hooking up a custom tach on 92 chevy s10
What kind of options does it have to be considered an ss?
Now pull back the carpet as shown, and gently bring down the ECM wiring harness. Look for the white connector taped to the harness. Find the solid white wire going into it. Tap into that white wire and that is the connection for the tach. There is no need to go to the coil or into the engine bay.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #3 of 32 Old 08-02-2009, 11:08 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
On a first gen 1992 its actually an off white colored wire. No connector,it just runs through the firewall in that harness,its the only off white/dirty white colored wire.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #4 of 32 Old 08-02-2009, 11:09 PM
jtcfanof3's Avatar
The RPO code B4U.
post #5 of 32 Old 08-02-2009, 11:22 PM
Works too much!
laydout97's Avatar
Originally Posted by jtcfanof3 View Post
The RPO code B4U.
That RPO code was available on a 92?
post #6 of 32 Old 08-02-2009, 11:51 PM
jtcfanof3's Avatar
No,you just asked a question,what option make it an SS so I was just answering that question,guess they just kinda ran together.
lol
post #7 of 32 Old 08-02-2009, 11:59 PM
BarelyGettinBy's Avatar
User is: BarelyGettinBy is offline
never seen a 1st gen ss
post #8 of 32 Old 08-03-2009, 12:04 AM
Works too much!
laydout97's Avatar
lol
I knew about the RPO code. I have just never seen it on a 1st gen. I have also never seen a 1st gen SS...
post #9 of 32 Old 08-03-2009, 10:13 AM
jtcfanof3's Avatar
LOL,its not you just asked what options made it an SS even though they didnt make SS's in the 1st gens............Im totally confused now,why did you ask:
Did the OP say it was an SS? If so he must have edited that part out! Your question now seems like it is out of left field!
post #10 of 32 Old 08-03-2009, 10:33 AM
99 Xtreme
andysutt's Avatar
User is: andysutt is offline
Nope, he didn't edit out the part about it being a SS
1999 Xtreme
94 Suburban
00 Jimmy
andysutt is offline
post #11 of 32 Old 08-03-2009, 10:34 AM
99 Xtreme
andysutt's Avatar
double post
1999 Xtreme
94 Suburban
00 Jimmy
andysutt is offline
post #12 of 32 Old 08-03-2009, 10:42 AM
jtcfanof3's Avatar
OK,well I guess Ive completely overlooked his SS coment!
LOL
Man O man!
No guy,someone stuck SS badges on your truck,the first SS S10 was built as a 94 model,not 92.
Sorry laydout,I was coming from left field!
post #13 of 32 Old 08-03-2009, 12:58 PM
Works too much!
laydout97's Avatar
LOL
Man O man!
Its cool, at first, I thought I misread it.
post #14 of 32 Old 08-03-2009, 02:43 PM
jtcfanof3's Avatar
Nah,I have a bad habit of skimming the text!
post #15 of 32 Old 08-05-2009, 08:21 PM Thread Starter
hmm maby my s10 isnt a 1st gen, all i know is that its a 92 chevy s10 for sure, and i tried tapping the solid white wire, and 2 different tan ones and neither of them worked with my tach... where on the ecu does it come out of? and where is the ecu?
brettley is offline
post #16 of 32 Old 08-05-2009, 08:33 PM
Works too much!
laydout97's Avatar
Did you not look at the pictures I gave you? Yes, you have a 1st gen. No, it is not an SS.
post #17 of 32 Old 08-05-2009, 08:41 PM Thread Starter
i did look at the pix you gave me to look at, they were kinda hard to follow though... i couldnt realy make up or down... also, i hooked it up to the white wire, and it did nothing, and 2 dirty white looking one...
brettley is offline
post #18 of 32 Old 08-05-2009, 08:48 PM
Works too much!
laydout97's Avatar
Did you not find that connector in the picture? If no, keep looking. If yes, look closely, there will be a white wire that goes into the connector but does not come out the other side of the connector. That is the tach wire. I know this wire is there. I have a 92 with a 4.3. Mine was right where the picture shows you.
post #19 of 32 Old 08-05-2009, 09:09 PM Thread Starter
well, i have found the white wire and hooked it up to the tach, but nothing showed up on the tach, its an equus tach if that helps...
brettley is offline
post #20 of 32 Old 08-05-2009, 09:20 PM
Works too much!
laydout97's Avatar
green- tach signal
white- dash light
red- power
black- ground
Are you sure that the tach has power?
post #21 of 32 Old 08-05-2009, 09:25 PM Thread Starter
yah, im sure it has power, i have it set right for the 6 cylender setting, and it will spin the needle and everything saying its on, but when it idles, it idles at 0, and when i rev it, it does nothing
brettley is offline
post #22 of 32 Old 08-05-2009, 09:28 PM
Works too much!
laydout97's Avatar
I dunno man. That is the right connector and that is the right wire. I have my tach hooked up there and it works perfectly.
post #23 of 32 Old 08-05-2009, 10:30 PM
jtcfanof3's Avatar
Ok so bypass all this BS and go directy too the coil!
post #24 of 32 Old 08-05-2009, 10:51 PM
Works too much!
laydout97's Avatar
We were thinking the same thing...lol You beat me too it.
post #25 of 32 Old 08-05-2009, 10:52 PM
jtcfanof3's Avatar
LOL,YA!
I meen this huge issuie about finding the right wire(shortcut)screw it and just go too the coil,simple,easy!
post #26 of 32 Old 08-06-2009, 08:50 AM
99 Xtreme
andysutt's Avatar
I agree...
On a lot of vehicles theres already an extra wire there for installing the tach to anyways, so you dont have to cut anything
1999 Xtreme
94 Suburban
00 Jimmy
andysutt is offline
post #27 of 32 Old 09-07-2009, 10:47 PM
92 Black 4.3
Dmizzle12's Avatar
User is: Dmizzle12 is offline
I just installed my tach on a 4.3L and i was just wondering if anyone knew what to set the redline at?
Thanks
post #28 of 32 Old 09-08-2009, 08:04 AM
99 Xtreme
andysutt's Avatar
8500 should do you fine.
1999 Xtreme
94 Suburban
00 Jimmy
andysutt is offline
post #29 of 32 Old 09-11-2009, 04:50 PM
92 Black 4.3
Dmizzle12's Avatar
Well i finished install on my Tach. this is what it looks like:
post #30 of 32 Old 09-11-2009, 08:44 PM
99 Xtreme
andysutt's Avatar
Nice safe way to take a picture of your tach...
while driving down the road. lmao
1999 Xtreme
94 Suburban
00 Jimmy
andysutt is offline
post #31 of 32 Old 01-30-2010, 09:43 PM
User is: ltsprinter is offline
Ok have a question... And I am sure you have answered this already but please try to bare with me.
I have a 1993 GMC Jimmy with a 4.3L V6 and I am trying to install a Mallory tach. I think I have found the "white wire" to hook to the signal (green) wire on the take,that I have been reading about to hook it up to but I have read so many different ways of hooking it up I am getting a little lost...
... So in other words, I am just looking for some guidance on hooking up the signal wire on the tach... Any help would be greatly appreciated.
Thanks
post #32 of 32 Old 02-19-2014, 08:48 AM
95s-dimer's Avatar
User is: 95s-dimer is offline
Mines a 95 should I wire mine to the coil or ecm wire thingy haha
