High beam problem - S-10 Forum
post #1 of 7 Old 04-17-2004, 11:33 PM Thread Starter
S10 Crazy
User is: afboomers is offline
Send a message via AIM to afboomers Send a message via MSN to afboomers Send a message via Yahoo to afboomers
High beam problem
My drivers side high beam is not working. I have checked the bulb, which is fine and there is no fuse that I can find that is blown. I don't know what is wrong or what else to check. Anyone have any suggestions.
Its a 2001 4.3
Thanks
post #2 of 7 Old 04-17-2004, 11:53 PM
Registered Stepsider!!!!!
minilowz's Avatar
User is: minilowz is offline
Send a message via AIM to minilowz
Re: High beam problem
Did you pull the DRL relay?, if you did one of the high beams won't work I don't remember which one, I haven't used my high beams since I installed the H.I.D.'s
99 Black Xtreme Ext Cab Stepside 2.2L 5 Speed(Gone on 6-17-04)
04 Electric Blue Dodge SRT-4 w/Sunroof(Gone Feb 06)
Current: 99 Grand Prix GTP
minilowz is offline
post #3 of 7 Old 04-17-2004, 11:58 PM Thread Starter
S10 Crazy
the DRL Relay is inside the fuse box in the engine compartment, correct? If so my headlight stopped working before I pulled it.
post #4 of 7 Old 04-18-2004, 07:49 AM
Insane Network Engineer
rlith's Avatar
User is: rlith is offline
Send a message via AIM to rlith
Pull the grounds on both sides, clean them up with sand paper, do the same with where they attach to, if that doesn't work, have the bulbs tested...Though I suspect it's mnore the bulb than ground because your low beams are working..
See my ride at
http://www.pghconsulting.net/teal
and www.s10planet.com
Support Sattelite Radio! Goto www.siriusbackstage.com
rlith is offline
post #5 of 7 Old 04-19-2004, 12:38 AM Thread Starter
S10 Crazy
I will give it a try but I have already switched my high beam bulbs and they both work.
post #6 of 7 Old 05-06-2004, 12:02 PM Thread Starter
S10 Crazy
If my problem is with the DRL Relay how do I fix that. Do I just have to buy a new one.
post #7 of 7 Old 05-06-2004, 01:14 PM
minilowz's Avatar
Yes or, for testing purposes you can pull one of the other relays in the box to try it out.
minilowz is offline
