HELP! electrical problem!
Ok, it started with my gas gauge going haywire when it feels like it about a week ago, which i figured to be a short in the system for the sending unit. Now my security light stays on and the seatbelt light will stay on even if your buckled up. When this happens the remote doesnt work to unlock/lock/alarm the truck. but then last night I unlocked it with the remote, and everything inside worked fine, but the remote wouldnt work again. then this morning, remote works once and thats it, and the interior problems started again. Anyone have any ideas and could help???????????
Re: HELP! electrical problem!
apparently nobody has any ideas, ive also noticed the dome light does not come on when the door is opened, automatic headlights dont work, its ****ed up!
HELP! truck starts then turns off
ok, I hadnt ran my truck for 3 days, I go out yesterday and the bat is dead, had 6 volts in it, So I charge it, go to start the truck, it starts runs for a second then shuts off just like i turned the key back off, the security light has been staying on over the past week and now its doing this, anyone have any ideas? ive searched with no luck....
Truck starts then shuts off
my truck sat for 3 days, i go out yesterday to drive it and it wont start, batt is at 6 volts, i charge the batt and then it starts runs for a second and shuts off just like I turned the key off, security light is on, and has been on for about a week, but this is the first time this has happened where it wont run. I cant figure it out, really frustrates me! Ive searched and cant come up with anything....... anyone have any ideas or suggestions?
BTW, 2000 S10 extended cab LS xtreme, 4.3 auto, 130k miles. |
registered s10 sex offender
Location: Indian Trail, NC User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Truck starts then shuts off
do you have a remote start? it sounds like a passlock problem
the youngest has been
no remote start, but the remote to unlock the doors has not been working either since the security light came on, seatbelt light stays on even though it was on, and DRL/AHL were not working when the truck would run, also no interior dome lamps. IDK, I took the batt out to charge it and im gonna check it out when i get back home later. the stock stereo has been out for almost 3 years and bno probs up until now.
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
Click here for info on how to reset your VATS (vehicle anti-theft system). Check the pictures of the keys on page 8 to see if you have Passlock or Passlock 3, then refer to that section of the text for instructions on how to reset it. If you have more than one key note that you only have 10 sec. to insert the second key.
I meant to say Passkey III, not Passlock 3. I have a '98 Blazer and it is Passkey III. Passkey II systems have the visible chip on the side of the key.
s-series all have passlock II not three... three did not come out till later and was never in s-series it was in cars larger gm 00+ gm and up cars some even have passlock III+ and yes that has a "chip" in the key but it is built into the plastic end...you do not have a visible chip in the key...if you do you got screwed some how you do not have passlock III Last edited by orangesonoma : 08-10-2008 at 08:29 PM. |
cant copy the text off the site..so here is a link to a site that list all the cars and there type of immobilizer
http://members.tripod.com/~alarmtek/VATS.html |
You got 30 minutes?
Re: HELP! truck starts then turns off
passlock issue. search for passlock relearn procedure. its on here somewhere.
two threads?
threads merged... did you check for blown fuses?
havent found any blown fuses, its a really wierd problem, that it would run even though security light was on and none of the interior lamps worked and no AHL, The keyless entry did not work but the power windows and locks did, Im gonna read up on how to relearn the security system, my only thing is, i dont beleave i have a chipped key, because i have copies that are deff not chipped and never had a prob with them, i guess ill try to check some stuff out in the am, its midnight here and pouring.
the seperate threads were because i didnt seem to get any response to my first nor in this electrical section. thanks orangesonoma for the help. |
ok, I tried the key on for 10-15min then start and i have the same problem. Ive removed the body computer completely, and i get the same issues with no more effects, this leads me to belive the body computer is prob DOA. Anyone have any othe ideas or would think the same thing I am?
ok, so 10 min on, how long off? between the three cycles? and i tried opening the link to the article, but nothing loaded, may be my computer?
well it loaded just now....
OK. Did you see the Passkey III key relearn procedure on page 3?
saw it, but it did not do anything, i tried but the security light stayed on and would not go out, im getting the same issue as well. I dont understand why GM would use this retarded ass system.
Im printing wiring diagrams now to check that im getting power and ground where I need it to and from the BCM. I absolutely hate electrical work so this is going to drive me nuts! MY security light on steady, whether the key is on or off and no matter what, it will not go off. im stuck on this and im ready to burn the freakin truck. |
#24 |
plain and simple..ask anybody that works for gm what passlock system 98+ s10's have they will all tell you that you have passlock 2 that may just be some jackasses website but it is 100% correct... and i know that is corretc since i have installed more alarms with remote starts in 98+ s-series then i can even think about counting trust me i have been doing this since 94 and have worked on hundreds of thousands of cars... passlock 3 has a pk3 stamped into the base of the key ... does your have that... and if you dont believe me check your site you linked.. These keys are usually identified by the letters PK3, or PK3+ stamped into the steel body. a copy and paste from your link... oh and yes the picture is wrong the pic in the upper left is a vats only key...passlock 2 never had a chip in it.. passlock 2 systems use a resistance built into a switch in the ignition switch and all the key does is complete the curcuit... Last edited by orangesonoma : 08-11-2008 at 07:07 PM. |
#25 |
another link..
http://www.audiovox.com/manuals/inst...8-6011A_IM.pdf audiovox a large maker of alarm and remote starts they have a list of all the immobilizers check what it says next to chevy blazer 98+ if you dont feel like looking Chevy Blazer 98+ Passlock 2 if you want some good info about gm immobilizers read that link.. |
#26 |
try the correct way 1. First, insert the ignition key and turn the ignition switch to the “On” position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 . 2. Turn the ignition switch off for 30 seconds. 3. Turn the ignition switch to the “On” position (as in step #1) for 11 minutes again. 4. Turn the ignition switch off for another 30 seconds. 5. Turn the ignition switch to the “On” position for 11 minutes a third time. 6. Turn the ignition switch off for 30 seconds one final time. 7. Turn the ignition switch to the “On” position one final time and wait 30 seconds. 8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. Last edited by orangesonoma : 08-11-2008 at 07:21 PM. |
#27 |
PASSKEY 3 AND
PASSKEY 3+ In this system, the vehicle theft deterrent functions are provided by the theft deterrent control module. There is a transponder embedded in the head of the key that becomes energized by the exciter coils in the ignition lock cylinder when the ignition switch is turned on. from your link... would you like to see the key that starts my 98 blazer that is passlock 2 equipped |
#28 |
ok so i cut open the factory issued gm key that starts my 98 blazer
and surprise surprise there is no "chip" in the key...do you still think you are correct? or would you like to see the pics? according to your fancy ass website there should be a transponder built into the head of the key right?? well then why does it start oh and yes i always go to such great lengths to prove a person wrong |
#29 |
You got 30 minutes?
