Headlight Wiring Diagram 98+ - S-10 Forum
Old 02-18-2007, 02:33 PM   #1
PaintRush's Avatar
Does anyone have a copy of the wiring diagram for the 98+ s10/blazers? I have a 2001 blazerX and the right highbeam does not work and it is not the bulb. So I need the diagram to search this little bugger out.
Old 04-11-2007, 04:14 PM   #2
Re: Headlight Wiring Diagram 98+
Sorry I can't help you out with your problem, but I have a 99 s10 and want to disable the "auto-on" for the headlights. 98% of the time my headlights are on. Having the headlights in the "off" position has no effect. What can I do?
Old 04-13-2007, 12:56 AM   #3
My truck has the same problem...one side does not work with high beam and i replaced the bulb...i had a shop check it out a year ago and they told me it was a $300 job to fix it i said f that..but when redoing some other elctrical work they left a wiring digram in there and i snatched up that b**** so when i get home ill check it out and put it up if its for the head lights
Old 04-13-2007, 12:57 AM   #4
look in the how to section and read about the drl and ahl...it tells you what wires to mess with
Old 04-13-2007, 02:16 PM   #5
jstblz's Avatar
Old 04-13-2007, 02:31 PM   #6
Old 04-13-2007, 02:32 PM   #7
sorry if its small but hopefully you can zoom in on it some how....
Old 07-26-2010, 07:14 PM   #8
HEY WAS UP S-DIMERS
conatus's Avatar
HI IM REALLY TRYING TO FIND THE HARNESS THAT HASS THE LOWS AND HIGHS FOG LIGHTS AND THE EXTRA LIGHTS THAT ARE ON THE TURN SIGNAL LIGHTS UNDER THE MAIN HEADLAMPS I HAVE SEEN EXTREMES AND BLAZER WITH THESE LIGHTS BUT I CANT FIND THE HARNESS TO DO IT ON MINE
Old 07-26-2010, 07:15 PM   #9
HEY WAS UP S-DIMERS
conatus's Avatar
Hi Im Really Trying To Find The Harness That Hass The Lows And Highs Fog Lights And The Extra Lights That Are On The Turn Signal Lights Under The Main Headlamps I Have Seen Extremes And Blazer With These Lights But I Cant Find The Harness To Do It On Mine
Old 07-27-2010, 11:02 AM   #10
Electrical Mod
deathphoenix99's Avatar
I have the diagrams in my sig.
Old 12-25-2010, 12:44 AM   #11
2000 GMC Typhoon?
Beau 2000 Blimmy's Avatar
My lights were Not working, and my jimmy would shut off on its own right after the highbeam Indicator light would come on. cause i had HIDs in my HighBeams.
First the DRLs Would flicker for about a week, then the second week they would turn on, now it just shuts off the whole car.
Problem was it melted the inside of the fuse box under the hood and shorted out the whole suv.
Now I gotta get a whole new Box.
this time i'm gonna run relays for all my lights, HEAD/HIGH/FOG.
acctualy i was gonna put the stock highbeams in the bumper, and run HIDs in the Highbeam compartment, straight from the battery to a relay to a switch.
