#51 |
... i dont know?
Re: Headlight Rewire How-To 98+
#52 |
I'm Back!!
Yeah post some pics of the comparison between the bulbs.
#53 |
I hate DEER!
I'm gonna finnaly do this mod this weekend! Hopefully not having a grille will not affect the life of the relay. I might just mount it on the other side of the core support, and on the driver's side, so I can use the positive off the fusebox.
#54 |
... i dont know?
dont get power from your fuse box, you want it directly from your battery or you will have defeated the underlying purpose of the mod, to make as short of a connection from the battery to the headlights as possible
#55 |
So I just found a bunch of 12awg wire that was given to me a while back and I was wondering if it would work or do I have to use 10awg wire?
this is the wire I was given http://www.cerrowire.com/default.aspx?id=3180 It is kinda stiff and has 19 strands in it. Also if the 12awg is too small to run both left and right lights at one time, would it be safe if I wired each light individually with it to 4 relays? And hold up to the Nokya 80/100w lights too? |
#56 |
... i dont know?
if you can make a run of 8 or 10 to the relay, the 12 ga will work fine, with 2 relays. you will be pulling about 10 amps, the wire is rated for about 30-35, you will be fine
the 8 or 10 will keep your voltage drop to a minimum to the relay |
#57 |
I'm Back!!
I need to redo mine, wire the relay inside the engine compartment instead of where it is and make the harness all fancy like the one you built in your thread. |
#58 |
Mr. Fix-it Perfectionist
I got a 95 s10 with a newly accuired 98 blazer front end. You are my hero !!! I was searching for something like this for WEEKS now...
This week for me will be wiring this up during work !! I got a dumb question though... is there a way to create DRL lighting using this as well?? OR do you know how to add DRL lighting the diagram above ? my s10 did not come with DRL... not even a relay for it...(only had el-cheapo sealed beammers....bummer man) Lastly.., I am going to add factory looking fog lights... I am wanting them to run on a relay as well.... can the above type wiring to the relay be used to power fog lights? (i got a factory fog light swith out of a blazer to use in my dash...it just a on/off type switch) Thanks Beandip for the write-up !!!!!!! |
