Ice storm, no power brb
Welcome to another of Beandip's How-To's
Today we are going to be upgrading the bread tie thin factory headlight wiring to something a little more beefy to increase the light output from your headlights. There is already a How-To for this but it is for sealed beams, the same principle applies with this How-To but this one is for the 98+ trucks and has more pics. I decided not to do a wiring diagram since the pics explain it themselves. This is a relatively simple mod but as stated in the other thread it does require some knowledge on what you are doing. The How-To was made after i upgraded my headlights so i tried to get as many pics of the process as i could without taking everything apart. sealed beam How-To can be found here ---->http://www.s10forum.com/forum/f199/h...rewire-195221/ The How-To below shows upgrade for LOW BEAMS only. Difficulty: Moderate Equipment list: 30 Amp inline fuse 3M electrical tape 10 gauge black wire 10 gauge yellow wire 10 gauge quick connectors 10 gauge ring terminals Crimper Wire cutter Soldering Iron 4 SPDT 12v Bosch relays (http://www.partsexpress.com/pe/pshow...number=330-070) Small flat screwdriver Self tapping screws Heat shrink tubing DMM (Digital Multi-Meter....optional) 30 amp inline fuse not shown below ![]() First step is to Disconnect the battery, after that remove the grille shell and headlights, then proceed to disconnect the connectors from the headlight and set the headlight aside. Then start by getting the 10 gauge wiring and route it from the battery to the headlight area. There is a hole in the core support along with other wires that lead to the passenger side headlight (shown in following pics below). Do not connect power to it yet but loosely route it to determine how much wire you need. ![]() OK, next lets start with the headlight plugs themselves. Shown below is the low beam plug. ![]() To remove the connector inside, insert a paper clip here to release the clip holding the connector inside the headlight plug. Push down and you should feel it release, when it does gently pull the wire and the connector should come out. I used an old codder pin but whatever works for you. Before you remove them mark a + and a - on the connector for future reference, blue is + yellow is -. ![]() After you remove both connectors cut the wires as close as you can to the connector and SAVE THESE. Next you need to take both blue and yellow wires you just cut and feed them back though the wire loom to where the main harness connects. (explained later) Now its time for soldering. Strip the end of the 10 gauge wire and insert it into the connectors you saved in the previous step. Solder as shown here. The black wire should take place of the yellow factory negative wire and the red should be in place of the blue wire. Also the clip pointed in the pic needs to be brought out some so it can "click" back into the headlight connector after both wires have been soldered. If not then the connectors will pop out of the headlight connector when you try to plug them back in. ![]() Re-insert the newly soldered plugs to the connector matching the + and - you wrote on the headlight plug. Give it a slight tug to ensure both connectors are seated securely inside the headlight plug. ![]() Comparison pic of the wire thickness, low beam connector on the left, high beam on the right. ![]() So now that you soldered both wires route them like this and cut the excess. The factory blue and yellow wires should be routed to where the relay is. Its a tight fit in the factory wire loom but just enough room to fit those 10 gauge wires. From the general relay location route 1 red 10 gauge wire to the driver side headlight though the factory wire loom and rewire the low beam plug as you did with the passenger side one. ![]() Wire the black 10 gauge wire from the headlight connector plug to this area here, this will be the ground for the passenger side headlight so ensure it is bare metal before you connect it (ignore 1 of the black wires, i made a mistake). Crimp and solder the wire to a ring terminal and tighten the bolt. On the driver side do the same, go from the headlight plug to the bolt on the driver side. Also shown in the pic is where you route the constant 12 volts to the relay. MAKE SURE THE POWER WIRE IS IN WIRE LOOM TO PREVENT IT FROM SHORTING OUT!!! ![]() OK now here is how you wire the relay, make sure before you bolt the relay to the core support that it will clear the headlight. ![]() With the relay bolted on and wires hooked up. ![]() After ensuring all the connections are secure and correct, install the connectors to the bulbs connect the main power wire and turn on the headlights. If you made a mistake somewhere the inline fuse will blow. pic of the upgraded headlight wire ![]() If the test is successful ensure the wires are in the wire loom and electrical tape the factory harness back to the way it was. Now install the headlights and grille shell, refer to this to make sure you installed your headlights correctly.http://www.s10forum.com/forum/f199/9...how-to-171732/ ![]() Now my headlights are really shining and getting 14 volts to the bulb making my low beams brighter than my high beams. i rarely use the high beams so thats why i kept the factory wiring but i may upgrade them as well.![]() Quote from the sealed beam headlight rewire How-To If any of my pics do not work or have been deleted give me a PM and i will send them to you. -Jonathan Last edited by orangesonoma : 07-13-2009 at 11:54 PM. |
I AM CANADIAN
Re: Headlight Rewire How-To 98+
Nice write-up Bean, I may do this in the near future!
The upgrade should help other bulbs like HIR's or other non-HID aftermerket bulbs. Make this a Sticky. Last edited by tt85_GM : 11-05-2008 at 12:55 PM. |
bellcranks no more
Il Brutto
Nice write up man!
How do you know how many volts your headlights are getting?? Just wondering how you know they were getting 12.5 volts
I AM CANADIAN
voltmeter at the plugs im guessing.
Overhead Console Expert
ok...i guess it hasn't rained by you yet. i mean that relay is gonna get toasted when it gets wet. but a good mod....but you can buy a relay harness on ebay and do the same thing just for a thought
The voltage at the headlight will always be the same as the battery voltage, only the amperage will vary with the wire size.
Is that the factory relay? |
AKA DavidAndSomeNumbers
Nice write-up.
Even if your housings are aimed properly will other drivers flash their brights at you? |
i did consider the relay harness at ebay but didnt see one and thought making my own would be cheaper. The more amperage you pull though a given wire, the MORE voltage drop you get. but no its not the factory relay. Last edited by beandip : 11-06-2008 at 08:13 PM. |
OK, just a note on the water and relays dont mix issue, raven2510 you are correct, i opened one of the extra relays i had so they are not sealed as i thought they were. so i took the relay off my truck (1 minute job) and i sealed the perimeter with silicone just to aid with water prevention.
so if your doing this mod, SEAL YOUR RELAYS OR MOUNT THEM WHERE WATER CANNOT GET TO THEM!!! come to think of it i could have just used a hot knife and melted the edges to keep water out instead of silicone....but silicone works ![]() |
I AM CANADIAN
or you could get a weatherproof cover for your relay...
![]() we make these at my work ![]() |
The Dreamsicle
Great how to. It looks a lot easier than what i would have thought. Did it really give you a noticeable higher output?
It sure did, here is what you can do. start your truck and turn your headlights on manually, if they are already on just turn the switch to keep them on after you turn off the truck. next turn off the truck and watch the headlights dim, its like that but in my case they get that much brighter. |
Just to add to the How-To
If you can use a 40 amp relay. If you use a 30 amp relay and a 30 amp fuse you may run the risk of blowing both the relay and the fuse. Im not sure how possible that is but its up to you. thanks Brian.Last edited by beandip : 11-09-2008 at 09:38 AM. |
Mr. Sparkle
/me votes for more beandip how to's.
Awesome job dude |
_-*KNUCKLE SANDWICH*-_
i want to do this.
sometime soon! |
I AM CANADIAN
well between this, the LED's from orangesonoma's thread and an overhead console, I think I got enough work to keep me busy all winter, I'll be hybernating in the garage
Ticket Magnet
Subscribed...so I can find it again...
I'm guessing this will work with my Blazer conversion?? |
Tim loves his doritos
How will this upgrade affect HID kits? I'm curious if it will have any effect on it at all.
not quite sure about the HID. I know that you need to get bigger gauge wire for the ballasts so you could do that. on HID wiring i believe its more high voltage than amperage. |
#24 |
alright sorry to bump a month old thread but its better late then never.
I finally got some before/after pics to show the increase in brightness from doing the mod. Camera exposure 1/3 sec. for both pics and using silverstar bulbs (low beams). ![]() |
#25 |
I Need $
#26 |
94 s10 in progress
does anyone see it better (in terms of redundancy) to wire each light individually. atleast if a relay goes you loose one light, not two.
the factory setup has each light on its own fuse (yes i know it does not matter in this setup). if each light were isolated you would get the same or more output per light using the same wiring as the OPs setup for highbeams, do we use the same setup, or bigger wires, fuses and relays? and just for peace of mind. factory headlight pos goes to relay "on", relay out goes to headlight pos headlight gnd goes to core with bigger wire batt goes to batt (DUH) is that correct? |
#27 |
Banned
#28 |
I know this thread is 2 months or so old but it seems i missed a post or two that needs answering.
If you were to wire the high beams you wire them the same way you see it in the how-to (just wire it to the high beam pigtails). if you want you can wire them separately (one relay per bulb) but to me this seemed unnecessary and too much wiring to achieve the same purpose though technically it would be a little bit "brighter" but i was only seeing a .2 volt drop with the setup shown above. and if a relay fails well you still have the high beams anyways. as to what wire goes to what, refer to post #1, pics 10 and 11, i dont think i can get any simpler than that. and 8 months later the mod is still going strong (knock on wood), though i did burn though 4 bulbs, given i used to drive every night to work and back home (only in the mornings now, new job ) round trip 50 minutes for 5/6 days for 8 months, the decrease in bulb life was worth the extra visibility and safety, besides the "average joe" doesnt exactly drive that much at night, unless you work at night of course. the decrease in bulb life the mod was well worth it and i have done this to 2 other vehicles with very happy customers in the end.sorry for the book/bump Last edited by beandip : 07-08-2009 at 10:26 PM. |
#29 |
Well at $50 for a set of Silverstar bulbs is it REALLY worth it? How often did you replace your bulbs before the mod? Cause 2 sets a year seems a bit much.
#30 |
actually that is driving EXCLUSIVELY at night for 50 minutes a day, 5 days a week and that is not including when i go out at night either. IMO its worth it. like i said the average person will not drive as much as i do at night so the bulbs will last you a year or so. OR you can use just stock bulbs with the relay mod and get better shitty lighting that will last longer than the silverstars, its up to you but personally i think its worth the extra $$ for added safety. also the first set blew out shortly after i did the mod (about a month or so) but they were over a year old, this second set i have is still going strong so 2 sets a year is not actually a very accurate statement since this second set is the real test on how long they will last since they are brand new. when these bulbs go i may just get the siverstar ultras but i don't think i will notice a difference. i cant say that unless i try it though! also not only does it make it safer driving on the road it also puts less electrical strain on the alternator and the electrical system. The before/after pic i posted below doesn't do justice on how much of a difference it makes, the only way to truly find out is to do the mod yourself, i guarantee you wont regret it...unless you like using those stock candlelight bulbs powered by bread tie thin wires to "see" the road at night. |
#31 |
Ticket Magnet
That does seem a little excessive..I've had mine for several years (4+) and haven't replaced them yet, and I do a lot of night driving. Now on the other hand...the wifes Blazer goes thru silverstars about once every 18/20 months. I think it's because the drl's are left on.
#32 |
Got Art?
#33 |
Got Art?
#34 |
![]() get some pics up if you want. Last edited by beandip : 07-19-2009 at 04:10 PM. |
#35 |
Quick question...
Will this mod also apply to 1997 Bravada Composite lights? And, Will the wiring affect my Quad-beam mod? |
#36 |
well bean I am going to do the ENVOY conversion I have the whole setup to do it but since its a real PITA to hybrid it into the the Sonoma ex cab in just gonna get a Jimmy headlamp harness w/fogs and OHC and just use the envoy buckets and Silverstars (which I currently use) and go this route
#37 |
Got Art?
#38 |
Got Art?
i dont know how the quad beam is set up on yours, but i just added the quad beam mod to mine tonight here is how i have mine ![]() |
#39 |
I need to do the quad beam mod to mine and relay the high beams. though i do have the low beams on a relay so i dont really have to relay the highs since the only load on the stock electrical is the high beams but im curious how bright the highs will be.
#40 |
Got Art?
#41 |
Got Art?
also something to add, i added the quad beam mod to the upgraded high and low wiring by installing 2 diodes in parallel from the high switch pin to the low switch pin (i used 2 for extra current carrying capacity insurance, i doubt ill need the extra, but it never hurts to be on the safe side) i would recommend the quad beam along with the upgraded wiring, the visibility is incredible to say the least, best money ive spent in a long time
EDIT: oops i guess i posted it above |
#42 |
mooninites are after me
Yeah, old post...but plan on doing this over the weekend. I wanted to ask the OP how the bulbs were holding up, and if there were any problems since the rewire?
#43 |
Got Art?
i cant speak for the OP but mine have been holding up fine, the only problem ive had is that i hit a bump VERY hard and my positive wires to the headlights came unpluged from the relay, i would say find some sort od way to lock the wires onto the relay (like an actual relay plug insted of spade clips) and that should never be a problem
#44 |
So I took my truck to work yesterday and did this mod, and wow...this was well worth it. It was really easy too, i think the hardest part was routing the wires to be safe and hidden ( put my relay by the horn so it would stay dry and theres already a hole there). Total cost was about 20 bucks... I got 2 relays, one to keep in the truck as a back up...a lot of the supplies i had at work. When i finished, I parked it next to a coworkers blazer and we both turned the lights on.....im doing his next week.
#45 |
haha told you guys this was worth it.
sorry for the delay but i just moved to a new house and finally got internet, 6 mbps ftw! but anyways bulb reliability is good, really it depends on the user and flicking from high beams to low beams back and forward doesnt help the bulbs last but since my new job i dont drive at night as much as i used to. i still drive at night in the mornings but that is about a 30 minute drive every day as opposed to close to an hour at my old job working the graveyard shift. Last edited by beandip : 10-05-2009 at 04:03 PM. |
#46 |
Got Art?
so has anyone tried nokya arctic white bulbs with this? i was thinking about getting some here pretty soon
#47 |
never heard of them...*googling*
ohh shit! i want to try these , i like the "not DOT" label on them. at around $17 that makes it really cheap just to try them. i am going to google around a little more about them but i wouldnt mind trying them out. also does it say they are 80 watts? if so i wonder how many amps that will draw on the 40 amp relay i have on there...:edit: nvm it says output watts as 70 and it consumes 55 watts. but its 12 bucks on ebay, really makes me wonder how they will last. Last edited by beandip : 10-06-2009 at 09:00 PM. |
#48 |
I sell Nokia bulbs in my store, there great. They have two 9006 bulbs in arctic white, one standard watt and one high watt, part # 7210 is 80w. I think there the best of the cheap bulbs. By my math (divide volts by total watts) a pair will draw 11.43 amps.
#49 |
Got Art?
#50 |
Funny you should ask. When I bought my truck it had one stock and silverstar, the silverstar was notably brighter and made my stock bulb look dull. Then I found one Nokia 80w in my garage so I replaced the stock one, the nokia was WAY brighter and had just a little bit more blueish color then the silverstar. A short time later it blew the fuse for the Nokia, tried to find something ells wrong but it was just too much bulb for the 10amp fuse. So I will be doing this upgrade (thanks to beandip's write up) and buying a pair of 80w Nokia bulbs.
