Hazard Switch Busted - S-10 Forum
post #1 of 19 Old 11-12-2003, 09:25 PM Thread Starter
Executive Platinum Member
User is: sportruck00 is offline
Send a message via AIM to sportruck00
I have a 1995 Chevrolet S10. I was taking off my dash to fix a squeak. Brooke the emergancy flasher switch on top of the steering wheel. So it wont shut off, just keeps flashing. So i shuved a tooth pick down there to hold it down from flashing. But I went to get it fixed, and I was told I would have to buy the whole turn signal handle switch and all that. Anyone know anything else, or what I have to do. Part #'s Costs? Thanks
t.minear@comcast.net
post #2 of 19 Old 11-23-2003, 02:54 AM
No it's not riced.
FatBabyJoe's Avatar
User is: FatBabyJoe is offline
Send a message via AIM to FatBabyJoe Send a message via Yahoo to FatBabyJoe
well i did the same... rode around with a toothpick sticking up out of the steering column for a week and a half then totalled the truck
but my paint and body guy had looked that assembly up for me... don't know part # but it was gonna cost 60 for the assembly and if u get some1 to do it labor wont be cheap... that steering column is a bia to work on.
'96 S-10, Xcab, 4.3L, 4.10 gears
Sittin' easy in East & South Mississippi and West Alabama
My Garage
Mississippi Customs
post #3 of 19 Old 02-03-2004, 04:55 PM
MINITRK's Avatar
User is: MINITRK is offline
Re: Hazard Switch Busted
I just broke mine too, Do u have the part #?
MINITRK is offline
post #4 of 19 Old 02-04-2004, 09:58 AM
s_mkustoms's Avatar
User is: s_mkustoms is offline
Same here, but I don't plan on using hazard lights anytime soon, so instead of using a toothpick, I took a piece of a buisness card, about 1/2" x 3/4", and stuck it on the right hand side of where the switch is. Turn signals still work, just no hazards, and no more toothpicks.
post #5 of 19 Old 02-04-2004, 04:27 PM
MINITRK's Avatar
Its fixed now, it took me like 20 min to fix it and about 18 dls, i just went to the dealer and buy the part #15174447, took off the broken one and slide in the new one!
MINITRK is offline
post #6 of 19 Old 02-04-2004, 06:56 PM
ninety_nine_s_10
User is: bryan11joseph is offline
I just broke mine too when I was taking off my dash. However, the flashers are not on. They stay off. I have a 99 and I can stick my finger in the hole and push it down to turn them on if I need and I can push it again to turn them off.
Should I leave it? It looks better than that stupid thing showing. It looks a lot smoother and I don't think it'll hurt anything. But I'm just wondering if i should buy it and fix it or not.
post #7 of 19 Old 02-04-2004, 08:40 PM
MINITRK's Avatar
Its up to you, i think mine looks better now cuz the one u get from the dealer is black and it looks cooler
MINITRK is offline
post #8 of 19 Old 02-09-2004, 10:43 PM
SK= Midwest's Elite
SLAMnoma95's Avatar
User is: SLAMnoma95 is offline
Send a message via AIM to SLAMnoma95
could i see some pics possibly on this....maybe even a how to....the hot glue that i got holdin the switch in place aint workin anymore...and it looks ghetto LOL
post #9 of 19 Old 02-10-2004, 12:06 AM
MINITRK's Avatar
What i did was take off stering column cover, that means take off the dash bezel too, then i used a screw that i screwed in the piece left of the switch and i pulled it with a pliers. It was a lil hard but it worked for me, just be careful of not hit your windshield when it comes out, then slide the new switch put all back together and you are done.
Note: If you can grab the piece left with the pliers theres no need of use the screw.
I think this trick works on 98+ s-10 i dont know if it can work on other years or models
MINITRK is offline
post #10 of 19 Old 02-10-2004, 02:16 PM
www.psychotickustoms.net
User is: chaotic is offline
Send a message via AIM to chaotic Send a message via Yahoo to chaotic
Same problem here. I broke mine taking off the dash i have a 2001 S10. But i was just reaching in the hole and pushing it down and it would turn off and on. Now it doesn't. I need flashers to pass inspection. But was told by my dealer that it would cost over $500 to repair the part alone they stated was over $300 bucks. Talk about being analy raped by GM. So my idea is to find the wires that control the Hazards and rewire it to a button on my dash. Good idea? Bad Idea? and how could we go about this. Many of us have broken that hazard button. So this would be helpful to all of us if someone knows.
chaotic is offline
post #11 of 19 Old 02-10-2004, 02:22 PM
MINITRK's Avatar
When i went to the dealer to get it repaired they told me that they had to replace the whole switch and it was going to cost me $350, then i just buy a new button and i replaced by myself it cost me $18.
When you need to repair something of your truck, before going to the dealer first make a search in the forum and most of times you will find a quick answer and you will save alot of money
MINITRK is offline
post #12 of 19 Old 02-10-2004, 02:26 PM
Problem is. My Hazard switch in the steering collumn no longer functions. I gotta keep playing with it for the hazards to come on. Its totally fubared now.
chaotic is offline
post #13 of 19 Old 02-10-2004, 02:28 PM
MINITRK's Avatar
Does the right and left turn signals work? if so you just have to replace the button. The part number of the button is somewhere up in the thread
MINITRK is offline
post #14 of 19 Old 02-10-2004, 02:38 PM
illusivedreams.org
Bagged4MyPleasure's Avatar
User is: Bagged4MyPleasure is offline
Wow, my hazard switch broke a LONG LONG time ago....I had the same problem where it broke and the hazards would just keep flashing. I have my switch in place, but I wrapped it about 5 times (the switch and steering column) with black electrical tape. The only problem I have is if direct sunlight hits it for to long the tape expands and the switch loosens...hehe.
Thanks for the part number, ill have to try that.
Sponsored By: A Plus Performance and Coast2Coast Designs
Gauge Magazine - Staff Photographer
Unified Productions - Co-Owner/Promoter
"The Next Generation of Car Show Productions"
post #15 of 19 Old 02-10-2004, 02:40 PM
MINITRK's Avatar
No Prob!
MINITRK is offline
post #16 of 19 Old 02-19-2004, 04:05 PM
Grizzly8380's Avatar
User is: Grizzly8380 is offline
Send a message via AIM to Grizzly8380 Send a message via MSN to Grizzly8380
a friend of mine did that to her blazer, broke the hazzard switch off somehow. dealer told her they'd have to replace the whole switch assembly, so she went to the junkyard, got the whole steering column for like $100.. and i put it in for her. all i did was unbolt the first half from the inner firewall and replaced that part.. not a long process if you have the right tools, found that out the hard way...
post #17 of 19 Old 02-19-2004, 04:10 PM
gumby green
whitebowtie9's Avatar
User is: whitebowtie9 is offline
Send a message via AIM to whitebowtie9
a $300 mistake i dont want to make either
Eric - 2008 Subaru STi DGM
NJ S-Series
Afterhours Fabrication 732-619-5293
post #18 of 19 Old 02-03-2005, 08:33 PM
sdimenightlight's Avatar
User is: sdimenightlight is offline
Send a message via AIM to sdimenightlight
the dealer said it would only work (that part #) on trucks like 2000 or newer i have a96 would it work on mine.
post #19 of 19 Old 02-04-2005, 08:35 AM
Insane Network Engineer
rlith's Avatar
User is: rlith is offline
Send a message via AIM to rlith
You don't have to replace the entire switch assembly, only the button which runs about 15 bux. I did a complete how to with pics and part numbers here http://www.s10forum.com/forum/showth...=hazard+switch
You DO NOT have to remove the steering cowl. Only tools requires is a pair of needlenose pliers.
See my ride at
http://www.pghconsulting.net/teal
and www.s10planet.com
Support Sattelite Radio! Goto www.siriusbackstage.com
rlith is offline
