"POSTAL" Hatin'
H4 Sealed Bem Upgrade...What is needed
I have a 96 S10 with sealed beam. I was wondering what all is needed beside the headlights themselves.... Are the H4 bulbs High and low beams??
"POSTAL" Hatin'
Re: H4 Sealed Bem Upgrade...What is needed
anyone?
I'm curious about this too... I'd like to get the 90/100watt H4 bulbs, is that possible with the stock headlight harness?
SoCal Football
Yep H4's are both hi and low beam. You'd need housings to replace your sealed
beams. I prefer Cibie, but Hella'a are fine too. Stay away from AutoPal. As far as bulbs there are many to choose from. I again prefer Narva Xenon bulbs, but PIAA and many others are avail. Nismo who is a member here, has a great how-to on wiring upgrade if you choose to go that route. Just makes it a lil easier on your elect system while providing a full load to your bulbs. I redid my harness using 10 ga wiring, relays, etc. I suppose you could put the "diamond" type lamp housings in your rides if wanted. You can find just about any lamp you want on eBay. Here is Nismo's how-to on the wiring upgrade. http://www.s10forum.com/forum/f199/how-to-headlight-rewire-195221/ I use this guy here. He knows his business when it comes to automotive lighting and will answer any e-mail pertaining to lighting and helping you get set up. My setup ran around 160.00. It's high, but now I can see where I'm going. Dan Stern also sells semi plug and play wiring relay kits that make things really easy. Well worth getting. I spendt much more than that doing my own relay system. I should of just bought one of his..Anyway > http://www.danielsternlighting.com/p.../products.html Last edited by bg's : 02-12-2006 at 04:00 PM. |
Yeah, I checked that out, and I've never really messed around with relays before, is it tricky?
SoCal Football
Simple. Here's another help link >
http://www.redpulsar.us/~coldfusion/relay.html |
PIAA makes some stock watt bulbs that have the output of a higher wattage bulb. I had those in my 91 Blazer H4 conversion. REAL nice bulbs that didn't require upgrading the wiring. I think they were called Xtreme Whites or something like that. Actually gave them to my dad when I did an H4 conversion on his 46 Chevy street rod.
Or could this simply be done with some wire and female connectors? Last edited by ShineyBlackDime : 02-14-2006 at 04:33 PM. |
H4 bulbs plug directly into the stock headlight plug. You want to run a heavier harness if you're using bulbs that pull more than the stock wattage so you dont' melt the wires and start a fire.
Umm..98+ didn't have sealed beams. They all had composites. I did the H4 conversion on my 91 Blazer and it was a direct plug in. Same on my dad's 46 Chevy Street rod.
SO sorry...I was going by every other vehicle I have and they all had the same plug that was on my 91 when I did the H4 conversion on that. I have never had a 94-97 with sealed beams so I didn't know they had changed. Seems stupid since the same style plug has been used on sealed beams for about 55 years or so.
Master of Tech
Check out LMC Truck......I just got their new catalog for dimes and it has a upgrade harness in it for the H4 upgrade that plugs directly into H4 bulbs...........
