H4 Sealed Bem Upgrade...What is needed
Old 02-12-2006, 11:01 AM   #1
"POSTAL" Hatin'
I have a 96 S10 with sealed beam. I was wondering what all is needed beside the headlights themselves.... Are the H4 bulbs High and low beams??
Old 02-12-2006, 11:06 AM   #2
"POSTAL" Hatin'
Re: H4 Sealed Bem Upgrade...What is needed
anyone?
Old 02-12-2006, 12:07 PM   #3
DA2Ricky's Avatar
I'm curious about this too... I'd like to get the 90/100watt H4 bulbs, is that possible with the stock headlight harness?
Old 02-12-2006, 02:31 PM   #4
Hard at work
bg's's Avatar
Yep H4's are both hi and low beam. You'd need housings to replace your sealed
beams. I prefer Cibie, but Hella'a are fine too. Stay away from AutoPal. As far as
bulbs there are many to choose from. I again prefer Narva Xenon bulbs, but
PIAA and many others are avail. Nismo who is a member here, has a great
how-to on wiring upgrade if you choose to go that route. Just makes it a lil easier
on your elect system while providing a full load to your bulbs. I redid my harness
using 10 ga wiring, relays, etc. I suppose you could put the "diamond" type lamp
housings in your rides if wanted. You can find just about any lamp you want on
eBay.
Here is Nismo's how-to on the wiring upgrade.
http://www.s10forum.com/forum/f199/how-to-headlight-rewire-195221/
I use this guy here. He knows his business when it comes to automotive lighting
and will answer any e-mail pertaining to lighting and helping you get set up.
My setup ran around 160.00. It's high, but now I can see where I'm going.
Dan Stern also sells semi plug and play wiring relay kits that make things
really easy. Well worth getting. I spendt much more than that doing my
own relay system. I should of just bought one of his..Anyway >
http://www.danielsternlighting.com/p.../products.html
Old 02-12-2006, 03:57 PM   #5
DA2Ricky's Avatar
Yeah, I checked that out, and I've never really messed around with relays before, is it tricky?
Old 02-12-2006, 06:52 PM   #6
Hard at work
bg's's Avatar
Simple. Here's another help link >
http://www.redpulsar.us/~coldfusion/relay.html
Old 02-12-2006, 10:28 PM   #7
Zeeke98's Avatar
PIAA makes some stock watt bulbs that have the output of a higher wattage bulb. I had those in my 91 Blazer H4 conversion. REAL nice bulbs that didn't require upgrading the wiring. I think they were called Xtreme Whites or something like that. Actually gave them to my dad when I did an H4 conversion on his 46 Chevy street rod.
Old 02-14-2006, 03:28 PM   #8
ShineyBlackDime's Avatar
eBay.
http://www.s10forum.com/forum/showthread.php?t=195221
Are you saying there is a straight conversion plug that connects the old wiring harness to the new style bulb? ie makes the harness: | __ \ Fit the new bulb: | __ |
Or could this simply be done with some wire and female connectors?
Old 02-14-2006, 03:37 PM   #9
Zeeke98's Avatar
H4 bulbs plug directly into the stock headlight plug. You want to run a heavier harness if you're using bulbs that pull more than the stock wattage so you dont' melt the wires and start a fire.
Old 02-14-2006, 03:45 PM   #10
I'm guessing for the 98+ it works fine, but I have a '96 Dime and the headlights don't plug right into the stock harness. (see my diagram above). Anybody encounter this problem?
Old 02-14-2006, 10:51 PM   #11
Zeeke98's Avatar
Umm..98+ didn't have sealed beams. They all had composites. I did the H4 conversion on my 91 Blazer and it was a direct plug in. Same on my dad's 46 Chevy Street rod.
Old 02-15-2006, 09:03 PM   #12
83firebirdS/E's Avatar
Sorry dude you are wrong. The H4 bulbs do not plug directly with the sealed beam harness on the 94-97s.
Old 02-15-2006, 10:08 PM   #13
83firebirdS/E is right...completly different harness than the H4's.Does anyone know of a quick adapter for the 94-97 sealed beam harness?
Old 02-15-2006, 10:08 PM   #14
Zeeke98's Avatar
SO sorry...I was going by every other vehicle I have and they all had the same plug that was on my 91 when I did the H4 conversion on that. I have never had a 94-97 with sealed beams so I didn't know they had changed. Seems stupid since the same style plug has been used on sealed beams for about 55 years or so.
Old 02-15-2006, 10:19 PM   #15
Master of Tech
llawmaster's Avatar
Check out LMC Truck......I just got their new catalog for dimes and it has a upgrade harness in it for the H4 upgrade that plugs directly into H4 bulbs...........
Old 02-17-2006, 12:32 PM   #16
Its all good man. Its completly retarded how the 94-97's are all different. It only succeeds in making things more complicated for guys like us. llawmaster, thanks for the helpful link, thats exactly what I was looking for!
