GPS Module wiring question
Old 09-23-2008, 02:53 AM   #1
drummerdude89's Avatar
drummerdude89 is on a distinguished road
First off i hope i'm putting this in the right forum, i figured since it's power and wiring related it should go in electrical...
I've decided to upgrade to a stereo w/ an included GPS module. It has one wire for ground, constant 12v and 12v accessory, and parking brake. I plan on grounding the parking brake because there's no need for it in a GPS. My question is this: does anyone have suggestions of good sources i can tap into for the constant and accessory power, and where these wires are located?
Old 09-23-2008, 02:54 AM   #2
Re: GPS Module wiring question
here's a link to the install guide: http://inform3.kenwoodusa.com/manual...10_install.pdf
Old 09-23-2008, 04:54 AM   #3
Resident A-10 Crewcheif
ablues10's Avatar
ablues10 is on a distinguished road
just use the ones on the radio.
Old 09-23-2008, 05:00 AM   #4
ok cool so just split the power and such off so they connect to both? lol way easier than i thought in that case... should the colors match up too?
Old 09-23-2008, 05:22 AM   #5
ablues10's Avatar
yellow is constant and red is acc. on our stock harnesses.
Old 09-23-2008, 05:37 AM   #6
cool man thanks for the help i appreciate it
Old 09-24-2008, 12:33 AM   #7
Dr.Fiero's Avatar
Dr.Fiero is on a distinguished road
Do you have a '93 as in your sig line?
If so... on the truck side, ORANGE is constant power, and PINK is switched power. And since we're on it... brown is the lighting, grey is variable voltage for back lighting, black is ground (duh).
The poster above might have been referring to the radio harness, or a later model vehicle.
Old 09-24-2008, 12:58 AM   #8
ablues10's Avatar
Shit! I thought it said 98!
Old 09-24-2008, 02:17 AM   #9
ya its a 93. I have a metra harness that i'll be wiring the new stereo to, so i think that the yellow and red colors will hold true, but if that wiring method doesn't work then i know which colors to look for when i'm diggin around in the truck
Page generated in 0.12710 seconds with 12 queries
