Fuse Location
Old 07-12-2008, 05:34 PM   #1
gimage is on a distinguished road
Fuse Location
The center floor console has a cigarette lighter and no power to it. I've checked the fuse block and they are all good. Anyone know the fuse location?
Thanks,
Greg
Old 07-12-2008, 06:15 PM   #2
Bill Wheats's Avatar
Bill Wheats is on a distinguished road
Re: Fuse Location
It should be at the other end of the feed wire.
Are you sure that the ground is still good.
Old 07-12-2008, 07:39 PM   #3
mechanicix's Avatar
mechanicix is on a distinguished road
Re: Fuse Location
the cigarette lighters are good for burning out. You might just want to change it out.
Old 07-12-2008, 08:35 PM   #4
Re: Fuse Location
I checked for power after disconnecting the cigarette lighter from the connector. I tried to follow the orange and black wires that come from the lighter and go up into the dashboard. I did not see those two colors on the fuse block but it is pretty cramped in there after the previous owners hack job when they put in a remote starter. I really don't want to disassemble the dashboard just to find the fuse. I have the factory service manual for the truck but it does not have any diagrams, that I could find, regarding the lower center console lighter.
Old 07-13-2008, 07:58 AM   #5
"better days"
bryanking11's Avatar
bryanking11 is on a distinguished road
Re: Fuse Location
im no help, but
i have a cig lighter with the 2 acc ports on each side... AND the left acc port and cig lighter dont work, but the right acc port does...
any thoughts?
Old 07-13-2008, 10:40 AM   #6
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
Re: Fuse Location
thread moved...did you pull it out to see if it came unplugged..
what year is the truck?
Old 07-13-2008, 03:00 PM   #7
Re: Fuse Location
I checked for power from the connection, not the lighter. There is no power to the connector. It's a 1994 S10 Blazer.
Old 07-14-2008, 09:32 AM   #8
capspauld's Avatar
capspauld is on a distinguished road
Re: Fuse Location
What year is your truck?? Looking at a 2000, the schematic says it is fuse 13 AUX PWR.
Old 07-18-2008, 01:06 AM   #9
Re: Fuse Location
It is a 1994 S10 Blazer. I have checked the fuse block under the left side of the dash. I've checked the power from the plug not the lighter itself. Anyone have any ideas?
Thanks,
Greg
Old 07-18-2008, 08:32 AM   #10
Re: Fuse Location
well i believe it shares the same power with the radio and other plug in the dash..and the dome light...
when you checked power were you missing ground or power at the plug?
Old 07-18-2008, 09:35 AM   #11
Synn is on a distinguished road
Re: Fuse Location
orangesonoma's right, it shares power with the dome, horn, etc. And since you're not getting power at the plug, all I can tell you is to trace the wires backwards until you find a break.
Old 07-21-2008, 07:28 PM   #12
Re: Fuse Location
Old 08-11-2008, 04:47 PM   #13
94 Blazer Tahoe LT 4x4
Duncan is on a distinguished road
Re: Fuse Location
Same ride... same problem... plus no remote lock/unlock and no power seat. The radio works the dome/courtesy lamps work so I don't believe the cig lighter/power plug are on the same circuit. There are no blown fuses but the 30 amp breaker on the top right side of the fuse block keeps resetting intermitently. I tested the wires and cig plug with VOM and it checks ok, no shorts and the wires have continuity. The problems all started at the same time. Have you found the gremlin in yours yet or does anyone else have an idea where to look without pulling the entire harness?? Is there a thermal overload breaker somewhere in the circuit??
Page generated in 0.12872 seconds with 12 queries
