firewall relay help - S-10 Forum
post #1 of 9 Old 10-01-2009, 07:24 PM Thread Starter
deadbroke's Avatar
User is: deadbroke is offline
firewall relay help
i had 4 relays mounted on my firewall for my 97 4.3 s10. i modded my harness but looked at a diagram today and noticed another relay i am pretty sure 2 are for the ac system one is for the adrl (daytime run lights) and the last is for my fog lights. is this correct or is one of those for my charging system. help a buddy out please
post #2 of 9 Old 10-01-2009, 10:48 PM Thread Starter
deadbroke's Avatar
Re: firewall relay help
anyone know for sure? they sit on the right side of the firewall 4 in a row i got a pic if it can help anyone but this is generally where it sits.
post #3 of 9 Old 10-02-2009, 03:40 PM
User is: cHUcKs10 is offline
I think one of those goes to the starter or ignition or whatever. I tried to delete them after I removed my A/C system and had to keep one because the truck wouldn't crank without it. Try removing one by one and see what stops working then.
cHUcKs10 is offline
post #4 of 9 Old 10-02-2009, 08:42 PM Thread Starter
deadbroke's Avatar
yeah i cut them already! that picture i just had wires dangling. in the haynes manual it says 3 of them were ac relays and the other was a third brake light but i am hearing different things. i am going to hit up the dealership to ask for a wiring diagram i already tried a used truck lot but they sold the twin version for reference.
post #5 of 9 Old 10-02-2009, 10:52 PM Thread Starter
deadbroke's Avatar
well i been having bad luck with the wiring but i found a guy with the same motor and wiring and went and took a look at his relays. i popped out all the relays and found the right one. so i'm home now and took a pic maybe someone else can benefit from a mistake like this.
thanks for the help too man i probably wouldn't have double checked if you didn't tell me one of them was for starting.
post #6 of 9 Old 10-03-2009, 12:32 AM
ROLL TIDE!!!!!!
draggindime072010's Avatar
User is: draggindime072010 is offline
does any1 kno if i will need the one for starting with my carbed v8 im about to do all my power and grounds for it tomorrow
1995 GMC Sonoma-bagged with carbed 350v8
2000 Ford F-150-ext cab hok tangelo orange, 20s
2003 gmc sierra-regency edition
"Sometimes The World Is Cruel To Shiny Things..."
post #7 of 9 Old 10-04-2009, 03:29 AM
Sgt. Stv-LoNowitz
stv-lo's Avatar
User is: stv-lo is offline
Send a message via AIM to stv-lo
if not you wont have a starter id leave that one in for now and see if itll work without it after youve wired everything
Stephen
stv-lo is offline
post #8 of 9 Old 10-04-2009, 03:42 AM
ROLL TIDE!!!!!!
i cut those out awhile ago
post #9 of 9 Old 10-11-2009, 12:18 AM
ROLL TIDE!!!!!!
i have the relay and the wires coming from it but i am going to have to re wire it does any1 know to do that
im sure one of the wires is power one is the starter wire and one is a ground but what is the other one will i even need that last wire
