Electric cooling fan. - S-10 Forum
post #1 of 19 Old 11-28-2011, 06:35 PM Thread Starter
992drjimmy's Avatar
User is: 992drjimmy is offline
Just installed dual fan setup from a v6 camaro. Install went nice and works great. Wired up with relays to an adjustable thermo control. The unit also has an input from the ac compressor. One problem though. With s10s the ac compressor kicks on when the defrost is used. So this kicks on fans when they don't need to be. Is there a different place to hook the wire for ac up that will only activate fans when ac is selected on control in cab? And not on defrost.
sent from HTC G2 on t mobile
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #2 of 19 Old 12-03-2011, 05:49 PM Thread Starter
992drjimmy's Avatar
Re: Electric cooling fan.
Another question, you guys using a thermo control with a temp probe where are you guys mounting it? I mounted it to the radiator, but i dont think thats good. It cycles the fan too much and too quickly on and off, With the dual fans and shroud completely covering the radiator, i think it fools the temp probe too quickly. So i moved it and taped it around the upper radiator hose. And problem solved. I dont like this hack solution though. I picked up and adjustable control with a thread in sensor. Suggestions on where to thread the sensor into.
post #3 of 19 Old 12-03-2011, 06:05 PM
AWD V8's Avatar
User is: AWD V8 is offline
I threaded my fans sensor into the right hand head. I removed the plug above the 2 front cylinders and threaded the sensor in.
AWD V8 is offline
post #4 of 19 Old 12-03-2011, 07:06 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
You always want it to turn on the fans any time the compressor is running, including defrost. You need to pull air through the condenser.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #5 of 19 Old 12-03-2011, 07:11 PM
goin broke but n style
S15vortecpwr's Avatar
the a/c coming on in defrost is the way it is designed. EVERY car on the road with a working a/c system will activate the a/c compressor while selector is in defrost.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #6 of 19 Old 12-04-2011, 12:08 PM Thread Starter
992drjimmy's Avatar
I knew every gm car I've ever had did this. However, my mustang gt does not run compressor for defrost. Nor did the geo tracker I drove a few winters ago.
Poor warm up when defrost is on and fans are roaring when it 25degrees out. What's the logic behind this?
What about unhooking compressor over the winter?
*sent from autoguide android app*
post #7 of 19 Old 12-04-2011, 12:09 PM Thread Starter
992drjimmy's Avatar
Anyproblems with unbolting the dipstick?
post #8 of 19 Old 12-04-2011, 06:15 PM
Zeeke98's Avatar
CONDENSER
This is the area in which heat dissipation occurs. The condenser, in many cases, will have much the same appearance as the radiator in you car as the two have very similar functions. The condenser is designed to radiate heat. Its location is usually in front of the radiator, but in some cases, due to aerodynamic improvements to the body of a vehicle, its location may differ. Condensers must have good air flow anytime the system is in operation. On rear wheel drive vehicles, this is usually accomplished by taking advantage of your existing engine's cooling fan. On front wheel drive vehicles, condenser air flow is supplemented with one or more electric cooling fan(s).
As hot compressed gasses are introduced into the top of the condenser, they are cooled off. As the gas cools, it condenses and exits the bottom of the condenser as a high pressure liquid.
^That is why your fan will always run when the AC system is in operation.
Wade
Zeeke98 is offline
post #9 of 19 Old 12-04-2011, 07:45 PM Thread Starter
992drjimmy's Avatar
I fully know why the fan would run in ac position. But what is the purpose of having electric fan running when trying to warm truck in 20 degree weather with the defrost on? This just tremendously slows warm up.
post #10 of 19 Old 12-04-2011, 09:47 PM
Zeeke98's Avatar
How? The thermostat doesn't open until it reaches operating temp anyways.
Wade
Zeeke98 is offline
post #11 of 19 Old 12-06-2011, 04:23 PM
S-Series Sucker
chcknugget's Avatar
User is: chcknugget is offline
I wish I had an answer for you, it doesn't make sense for the fans to turn on when it's cold out. One of the benefits of the efan is supposed to be quicker warm-ups lol.
post #12 of 19 Old 12-06-2011, 04:37 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
yea no crap haha i hate my blazer when it does that.
my 95 s10 deforst extremely well with no ac from the factory, i feel there isnt a reason to activate the ac system to "dry out" already dry winter...
i read somewhere its so the compressor circulates and runs in the winter so come spring/summer your ac compressor isnt locked up
comics22 is offline
post #13 of 19 Old 12-06-2011, 10:31 PM
AWD V8's Avatar
Nope, I just made this little extension to move it out of the way. If left unsupported it would likely crack and break off.
AWD V8 is offline
post #14 of 19 Old 12-08-2011, 09:10 PM Thread Starter
992drjimmy's Avatar
The temp controller has a wire that goes to the ac compressor. Since using defrost runs compressor this in turn runs the dual elec fans. Till summer I have disconnected that wire from compressor and pulled ac relay. Doesn't make sense to be constantly running the ac for heat to defrost.
post #15 of 19 Old 12-08-2011, 10:23 PM
Zeeke98's Avatar
*Waits for the thread next summer....My AC compressor seized.
Wade
Zeeke98 is offline
post #16 of 19 Old 12-09-2011, 02:37 PM Thread Starter
992drjimmy's Avatar
I do see where they should be cycled occasionally to MAYBE prevent seizing. In my 98 mustang gt the ac compressor does not run with defrost. Never has. My 97 jimmy has a r134 leak so by summers end ac doesnt work. So compressor doesnt run all winter. Works every year when i put r134 in it. This year though i plan to fix it right.
post #17 of 19 Old 12-14-2011, 09:33 AM
Electrical Mod
deathphoenix99's Avatar
It won't hurt to not use the a/c for the winter, I had my a/c setup on a switch so that I could manually disable it for winter use and expecially since the 2.2 was underpowered for a/c at idle. As for the fan being on with the a/c, YES, if the truck is not moving faster than about 25-35 mph, then the fan NEEDS to be on if the A/C is on. It's very hard on the system to not have air moving through the condensor when the a/c is running. I found this out the hard way when my a/c fan went bad. When idling with the a/c running, it would overpressure and luckily the high pressure switch would kick the a/c off, but it's still hard on the system to keep doing that. And it gets up to temp really quickly, so the fan is needed early on.
post #18 of 19 Old 12-14-2011, 04:46 PM Thread Starter
992drjimmy's Avatar
Agree totally with what you wrote. Makes perfect sense to need fan with ac. But dont need ac with winter defrost.
Running the 2 camaro fans when its 20 degrees outside trying to warm the engine to defrost the windshield just makes no sense. So ive disabled the fans coming on with defrost and pulled the AC relay for the winter.
post #19 of 19 Old 12-14-2011, 10:41 PM
Electrical Mod
It helps because it removes moisture from the system, that's the reason it's on. But I agree, normally you can get by without a/c to defrost. I mean my truck came without a/c and it worked fine for 14 years before I installed A/C.
