Cruise control dont work... - S-10 Forum
post #1 of 5 Old 01-31-2006, 08:08 PM Thread Starter
I just ate a honda.
monkeydude3602000's Avatar
User is: monkeydude3602000 is offline
Send a message via AIM to monkeydude3602000 Send a message via MSN to monkeydude3602000 Send a message via Yahoo to monkeydude3602000
I have a 93 S10... the only cool option it has is cruise and it dont even work. ARG! My question is where do I start? Or would it be better to take to a GM dealer? I cant seem to find a fuse for it. Is there even one or is it tied up with something else? I dont think its the switch because blinkers, windshield wiper, squirter, and bright switch all work fine.
'93 S10 357ci, pro comp aluminum heads, lunati voodoo cam, lunati 1.6 roller rockers, Edelbrock air gap, Holley 670 street avenger, headman headers, summit 2 chambers, mallory/msd ignition, in tank pump with holley bypass regulator, 4l60e with transgo hd3 full manual kit and 46 mod vacuum modulator, G80 with 4.11s, slammed with street tires... no traction whatsoever
'03 S10 crew cab, stock, Kelly safaris
>>>My Rides<<<
post #2 of 5 Old 01-31-2006, 09:31 PM
DA2Ricky's Avatar
User is: DA2Ricky is offline
Send a message via AIM to DA2Ricky Send a message via Yahoo to DA2Ricky
Re: Cruise control dont work...
Mine doesn't work either... and its not the fuse. I'm interested to find out what people have to say.
I have a 94 by the way.
DA2Ricky is offline
post #3 of 5 Old 01-31-2006, 09:32 PM
ZR2 member
Scott01's Avatar
User is: Scott01 is offline
Control box under the hood.Should be mounted to firewall.
Scott01 is offline
post #4 of 5 Old 02-17-2006, 07:38 PM
User is: Tazmania575 is offline
Heres a suggestion...(I have/had a 1989,1993 & 1994) Behind the distributor there is a vacuum line. It is connected to the intake manifold. Check this connection, and "TEE"s and the vacuum line running to the actuator, the actuator and the cable that runs back over to the throttle linkage. Once I lost the vacuum to the actuator and once I lost the connection to the linkage that "pulls" the throddle. Hope this helps
post #5 of 5 Old 02-27-2006, 11:40 PM
The2.2LKing's Avatar
User is: The2.2LKing is offline
Send a message via AIM to The2.2LKing
in my 98 s10... I have a second "doohicky" just like the wiper and light thing switch, but lower on the steering column, and it doesn't work either... it worked when I got it, but just suddenly stopped workin... I looked into it, found an install manual online... but it might as well have been in chinese... cause it was as confusing as crap... talkin all about vacuums and sht like that...
