LinkBack (3) | Thread Tools |
#101 |
Mechanical Mortician
Re: Broken Hazard Switch Repair How-to!
yes $335
#102 |
Got damn i'm glad i found this. You people are the sh*t.
#103 |
#104 |
S10 Junky
I am so glad I found this just now. I broke mine off and the damn hazzard lights won't shut off. (I had to change the bulb for the high beam indicator, Tired of getting the high beams from other driver's because I forget to turn the damn things off)
![]() I am so glad I'm not the only Dumbass that did this. I ordered the whole thing from the parts store. $245 I'm sure as hell not picking that thing up tomarrow. Off to the Dealer I go. ![]() YOU ARE AWESOME!!! |
#105 |
S10 Junky
Where did you find it on ebay? Yurns out I need the whole thing
#106 |
Insane Network Engineer
How come you need the whole thing? |
#107 |
S10 Junky
I tried to take a pic to show you guys but I can't get a good angle on it. One of the little copper pieces in the inside of the hole where the hazzard button goes is broke. I don't have brake lights or turn signals?
If someone has one with a broken hazzard button I'll take it. I got the repair kit yesterday. Mine is also black instead of red. |
#108 |
S10 Junky
Can you check for me if this is the same part # as a Silverado 95-98? GMPartsDirect says it is but the parts store says there 2 differant part #'s.
#109 |
S10 Junky
I found out htey are the same. Escalades, Full Size trucks, and Astro Vans from 95-98 are the same as the S10, Jimmy, Sonoma, And Blazer 95-97.
If anyone needs a Hazzard Switch I have Red and Black. 2 of each. I'll sell them for $10 w/ Shipping. |
#110 |
CHANGE YOUR EMAIL ADDRESS
PM sent. Just broke mine 10 minutes ago ![]() I just got my painless wiring harness in a few days ago and had all the signals and lights working and I broke it test fitting my custom dash. Thanks to the forum for saving me some cash! Last edited by draggin350sonoma : 01-18-2006 at 02:52 AM. |
#111 |
Deviant Kustomz Member
does anyone knows exactly how does the hazard switch work? what do I mean is that I broke mine and followed the steps on the forum on how to replace ..which worked great; however it always makes me wonder if the broken switch would have worked if I had super glued the red piece back on top of the switch ? no...if no why not? I looked at the broken switch vs the new switch and they look exactly the same as in where it broke, seems like some super heavy super glue would have done it
k1 |
#112 |
FloridaTruckScene.com
Mine is broken, but I dont got no screw driver or anything in it, its fine..
I cant see why the hazard switch would be screwin' up my brake lights.. Im going to replace it this weekend, thanks! |
#113 |
Just called the dealer the switch is $24
#114 |
The reason the hazard switch and to an overall extention, the multifunction switch can cause brake light issues is because it's all tied into the same circuits. Going with just the hazard switch to start is far better than spending 250 on the multifunction switch... It's at least worth a shot.
#115 |
Yeah I installed it today with no problem now I have to see if my brake light fails.. if it does its prolly my brake switch, i checked the fuse and the bulb and they are all fine..
anyone know how much a brake switch costs approx.? |
#116 |
Accept my thanks, too! Yesterday trying to reinstall the dash piece I broke the switch and found this fantastic fix! $16+ and a few minutes later, life is good Unlike some other post, the local Chevrolet shop didn't try to "upsell" me anything. They brought out the part and asked if that's what I needed and I was ready to roll.
Thanks again for the great pictures and inexpensive fix. |
#117 |
moderator at mys10.com
i had a problem on my wife's 97 blazer with the brake lights, both lower brake lights and the 4 ways didnt work either. but the 3rd brake light worked. i called a dealer w/ this part # and it turns out it was a recall for that problem on certain blazers jimmy's and envoys hope that helps someone too |
#118 |
What's in a name?....
Rlith! Thank you so damn much!
I broke the switch removing the bezel. I got as far as pulling the airbag, the column covers, etc and was ready to order a new turn signal assembly online, when I read this. Thanks again! Just ordered it from gmpartsdirect.....crumbs, didn't realize it would take a week! Blah....guess I better be careful with the braking, etc. ![]() Last edited by doc_rage : 02-08-2006 at 06:40 PM. |
#119 |
Location: Chillicothe/Athens, OH User is: OffLine ![]() |
pics no workie....anyone have this guide saved to their hd?
I NEED HELP!!! ![]() |
#120 |
#121 |
well i tried it, but the turn signal flasher won't shut off still with the new switch in, the hazards turn off fine though...
not sure what the hell to do, i'm really pissed off right now, cause i spent $21 only to end up breaking it again... |
#122 |
S10 Junky
I broke mine again too like a dumbass putting a new radio in yesterday.
Are you sure you have it in the whole way? Because you have to push it in pretty far. Let me know. I think I still have another used assembly in the garage. I used it for awhile but It doesn't have Cruise. I'll look if you think you need it. Last edited by firefighter_0029 : 03-01-2006 at 04:11 PM. |
#123 |
UNBANNED BITCHES!!
why/ HOW do you guys break these things?!?? i have remove my dash 20+ times at least and ive never broken mine........
#124 |
S10 Junky
You have a Stick Don't you? I've taken the one out in my S-10 and it's easy. But with an automatic you have the stick on the column in the way.
#125 |
Wow am I Glad I found this sticky. I was installing a radio and a friend of mine was helping me and he pulled the dash bezel and broke my switch. I couldnt get my flashers to turn off so I took a screwdriver and jammed the broke piece back in the whole and they finally stopped flashing but now I have no turn signals. I will definitely be ordering this part and hopefully I didnt mess it up too bad when I jammed the screwdriver in there. we will see.
#126 |
Inspired Soundwave
Location: Regina, Saskatchewan User is: OffLine ![]() |
added to how to section:
http://www.s10forum.com/how_to_broke..._switch_repair |
#127 |
will this switch work on a 2000 blazer?
#128 |
#129 |
ill i might as well pick one up.
#130 |
Banned
Wow. Wish I wouldve known about this before i dropped 2 hundo on a new multi-switch just yesterday....
#131 |
did mine and works FINE!
#132 |
Tuckin swirls bitches!
wow, old thread... but EXTREMELY helpfull.
I actually broke it pulling the whole dash out, so i at least have a better excuse ![]() |
#133 |
mine works but as a i drive it sounds like if its on but its not just the sound.
