#1
Insane Network Engineer
Broken Hazard Switch Repair How-to!
Yes people, someone has finally done the Broken Hazard Switch repair because we were stupid when we pulled the dash bezel How-to!!!
This applies to all 95 -97... 98+ you need to remove the upper cover Tools and Parts required: Parts: GM Hazard switch repair Kit part # 15174447 Tools: Needle Nose Pliers The hazard Switch kit will come with a small tube of dialectric grease. Smear this on the entire thing before installation. First look at your old hazard hole. You should see it broken similar to this. ![]() Reach in with your needle nose pliers and grasp the edge of the old switch housing and pull upwards and remove. ![]() You should now have the entire assembly out.. ![]() Now simply insert your new hazard switch in hole and push down firmly.. New Switch: ![]() And wala! You're done... Your final repair should look like this.. (though less blurry unless you're not wearing glasses then it will look just like this! ![]() Takes about 3 minutes. If you can't do this repair, you're a complete moron! ![]() Enjoy! Last edited by orangesonoma : 05-04-2009 at 06:59 PM. |
I like MINE with NO shine
Re: Broken Hazard Switch Repair How-to!
Your a complete moron for paying for the part and taking your time to do the labor - this is a factory recall part. It is replaced for FREE at yoru local Chevy dealer.
Nice how-to anyways... |
its a recall? i can just go to any chevy dealer around my house and tell them it broke and get it fixed on my truck? i never knew...
i didn't know either, so am i a moron ?
..................... ya know. i wonder how easy it would be to just take the switch out before breaking it ? then put it back in when the work is done. |
has committed suicide!
Nice How-to man :thumbup:
last pic is nice ![]() |
I'm probably drunk.
how the hell do all you people break this switch off?
removing the dash bezel is the only thing i could think of...but??? |
Yea... i figure im pretty damn lucky on this one.. i've probably had my bezel out a total of 15-20 times for a lot of various shit and i haven't broke that damn piece yet
Just wanted to say that this was the easiest repair i have ever done....Many people told me my switch could not be replaced without replacing the whole directional assembly.....thanx for the info...part cost me 12 bux instead of the $275 directional assembly...
Well glad I could help someone. That's what we're all here for ![]() Got pics? Last edited by rlith : 04-08-2004 at 09:16 PM. |
Where you guys did go to get the hazard switch needed for cheap?
Plan Havin MF
It's a dealer item only... Usually between 12 and 15 bux... The part number is listed at the beggining of the how-to. You DO NOT need the whole multifunction switch as demonstrated in the pics
does anyone know what years this part was recalled on? I have a 95... Thanks!!!
95 wasn't included in the recall, you'll need to spend the 12 bux...
I suck dick for loose change.
i must me a complete moron because ive got my
column cover off and still cant get it to just pull out, it aint just comin outta there |
out to lunch
You can order this part from GM Parts Direct, it's $9.25 plus shipping.
Here is the link http://www.gmpartsdirect.com/ enter only the part number 15174447 in the search box at the top left and that will bring up the part. No having to hassle with the "morons" at the parts dept at the dealerships. This is a legitimate GM OEM parts distributor. |
Is the switch black from gm parts direct....? cause the factory one is red?? that damn thing broke off and we ended up getting one from a 98+ s-10 at the junk yard and messed around with the connections to make it work the sprayer and wipers were like backwards....so we just replaced the whole hazard switch with the blinker stalk.. it was only $25 at the junk yard....100 at auto zone...but with this i think it would of saved us alotttttt of time.....
Yes, the replacement one is black...
look at my pics...![]() |
#24 |
I am EXTERMELY HAPPY I'm not the only one who did this. I broke my Hazard Switch about a year ago and REFUSE to pay $40-$80 bucks from the dealer for it. And Besides i didn't even know where to start wiith it. Thank You for posting this one.
Thank You,... |
#25 |
Seems a lot of people never knew about it... Glad I posted it...
#26 |
17" Rubber Slinger
Great how-to I'll have to buy one when i get home. I'm getto i just stuck my tire gauge in there and rolled like that for almost 6months or more
#27 |
LOL...Tire gauge!!!!!! Yeah, 12-15 bux isn't much for a fix...
#28 |
Mr Can't Keep An Avatar
This How To Needs To Have A Sticky So It At The Top!!! Great Info
#29 |
Thanks alot man. I went to the dealer and they said there was no way to do it but to replace the whole thing and i told them i had a part number and everything...finally i gave up and went to anopther dealer and didnt even tell them what was wrong i just asked for the part. It took me a long while to get around to but god damn it was so easy to replace. Well not at first. Did you know that the horn goes off if you dont discconet the battery lol. I learned the hard way so my horn was blaring for about 15 mintues while i found a wrench. It went in really really easy...like it just slid in.
It took me a sec to get the old Switch and the stalk or whatever it is that holds the switch. I ended up taking the whole bezel out and taking the steering colum apart just to realize i was pulling it out at the wrong angle... Thanks alot man |
#30 |
The f@$k you want foo?
Heh heh...I replaced the whole damn multi-function switch a couple of months ago. I found a new one on Ebay but it was still $100
. I did get a nice new clean turn/cruise lever out of it at least though. LOL! I'm just tryin to make myself feel better about the 100 bones, bear w/ me!I'd say this is worthy of a sticky-icky! Last edited by jakedubb : 05-21-2004 at 01:24 AM. |
#31 |
Before you installed it you should have taken it back to the other dealer and shoved it in his face! LOL |
#32 |
The switch was $18 at my dealer, but my blazer is now fixed.
Thanks to this thread I avoided a $300-$400 dealer visit. ![]() Bob |
#33 |
SK= Midwest's Elite
werd...everyone told me its like $300some odd dollars to replace the whole thing...which seemed funky to me
but ya...THANKS!!!...this will add to my projects along with the alt i fried the other day and the bumper cover that snapped !!!...oooh i love workin on my broke ass truck ![]() Last edited by SLAMnoma95 : 08-06-2004 at 07:23 PM. |
#34 |
SK= Midwest's Elite
btw...if the horn does go off, which i dunno if it does or not cuz i havent pulled it yet
you could just remove the horn fuse ...then pop it back in when done, way easier then disconnecting batt...plus you dont gotta reprogram all your shit on like a HU |
#35 |
former title junky mod
Actually you are a complete moron. It was never a recall, just a service bulliten. A service bulliten is the same as a recall except for the consumer pays for the part. I went thought this and tried to get the dealer to fix this. Where I work we break a few a month (I dont, but other employees do) |
#36 |
illusivedreams.org
Wow, this is VERY helpful/ Definately worthy of a sticky. Thanks for the info!
Mine broke over a year ago and I wrapped it and the steering column in electrical tape to keep it in place..LOL....although the electrical tape comes undone or loosens with heat (like a hot day). |
#37 |
95 S-10 2200
Yeah I've been rollin like that for quite a while now, all tapped up. I went to the dealer and the parts man told me to buy a new switch $140. This will save an azz load of money.
#38 |
I got one for free at a local junkyard!
#39 |
Still Mini Truckin' It
Forget the tire gauge, I jammed a screw in mine to stop it from leaving my turn signal on (now they don't work).
Thanks for the how-to, now I feel bad for buying a switch on evilBay for $100. Beats $350 from the stealer though, he was dying to sell me one, said he "had seven in stock". I wonder why? ![]() |
#40 |
What years is the hazard switch a recall? I got a 96,...and mine is broke.damn dash bezel,...
#41 |
It's not a recall, it's a tech builliten...
#42 |
CHANGE YOUR EMAIL ADDRESS
LOL, i did the same thing...every once and a while either signal will go off, or the hazards.... off to get the peice 2 day thanx a lot for this info-- |
#43 |
Since this isn't a sticky, I'm just bumping this in case anyone is currently having a problem..
#44 |
Never Finished
I've seen alot of people shove a little piece of cardboard infront of the switch and that seems to work, but now I'll have to tell my buddy about this. His broke a few months ago.
Alot of parts guys at dealerships get paid commission, so they'll try to sell you a $150 part over one that's just $15 anytime they think you don't know any better. They probably assume most people don't know that there's a cheaper fix than replacing the whole switch so they take advantage of it.....more money for them. |
#45 |
Did it in 30 seconds
Must be genius,..lol |
#46 |
#47 |
Bumping this because I got some emails asking where it was... This needs to be made a sticky
#48 |
Rev. Horton Heat Saves!
Got mine today @ Domingo Vara Chevrolet in San Antonio for $18.50 + Tax. Just go to the parts counter and ask for part # 15174447, I didn't have any problem with them trying to sell me something I didn't need. Took me about 2 min. to install. Now the stearing wheel on the other hand is a mofo!
#49 |
#50 |
I replaced the stock wheel with an APC steering wheel. It turns out that the installation kit I had was missing parts. (Not to mention that I HAD an airbag!) Anyway, it took me about 3 hours to get it to work.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f62/broken-hazard-switch-repair-how-to-99222/
| The Haven :: View topic - GM S10 95 - up Hazard switch replacement. | This thread | Refback | 09-08-2007 06:17 PM | |
| The Haven :: View topic - GM S10 95 - up Hazard switch replacement. | This thread | Refback | 08-16-2007 09:28 PM | |
| The Haven :: View topic - GM S10 95 - up Hazard switch replacement. | This thread | Refback | 06-18-2007 01:29 PM | |
