Both reverse lights blink when using the right turn signal - S-10 Forum
post #1 of 7 Old 10-24-2009, 10:33 PM Thread Starter
User is: Schlapppy is offline
Strange problem here.. but here's what I know.
2000 S-10
When my headlights are off:
Left and right turn signals work fine
When my headlights are ON:
Left turn signal works fine. Neither reverse light is lite.
The problem: Right turn signal triggers the reverse lights to blink. The right turn signal also blinks.
Suggestions? Plz help.
post #2 of 7 Old 10-24-2009, 10:59 PM
forum idiot
orangesonoma's Avatar
Re: Both reverse lights blink when using the right turn signal
bad ground to tail light harness..you can do one of two repairs...find the bad ground in the harness .. or run a new one to the frame from the black wire on the tail light socket...
i have done choice two plenty of times..
Brian
orangesonoma is offline
post #3 of 7 Old 10-25-2009, 01:47 AM Thread Starter
Dead on. That was it.
The side that caused the blinking to occur had the wire frayed. I cut the wire, found a solid ground wire and re-ran it. I'm in business again. Thanks!
post #4 of 7 Old 10-25-2009, 11:40 AM
forum idiot
glad you got it fixed!!!
Brian
post #5 of 7 Old 10-25-2009, 11:42 AM
Air ride & Audio
s10gmconversion's Avatar
User is: s10gmconversion is offline
my reverse lights come on when i hit the brakes and the left brake light dims. you think thats the same problem?
Cameron
WANTED for 98+...
any kaik billet accessories
post #6 of 7 Old 10-25-2009, 11:43 AM
forum idiot
yes...power is back feeding through the lights causing them others to turn on
Brian
post #7 of 7 Old 11-07-2010, 02:38 AM
Varides.com
Stehl's Avatar
User is: Stehl is offline
Send a message via AIM to Stehl
I had the same problem. I just used some sand paper and made a nice new ground on the frame and used an eyelet to ground each side. Haven't had any problems since.
The Virginia Rides Forum
http://varides.com
Stehl is offline
