Blower Motor only works on low - S-10 Forum
post #1 of 30 Old 08-02-2009, 03:56 PM Thread Starter
Navy Seabee
SD44's Avatar
User is: SD44 is offline
Couldn't find the previous thread I'd started about this. See my sig for my truck info.
Anyways, my blower/fan motor only blows on low. I can have the switch on high, turn the key on, get under the hood and unplug the motor...and when I plug it back up, the motor blows wide open like it should. Yet when I turn the key off, then back on again, it's back to only blowing on low.
Okay, so I replaced the blower motor; that didn't fix the problem, it still only blows on low. Now there is a rack of 3 relays on the firewall, and the middle one is the blower motor relay. With the key on, you can "thump" the relay with your finger and it'll start blowing wide open like it should; yet as before, if you kill the fire and turn it back on, it only blows on low. So I replaced the relay with a new one. Same problem; only blows on low, you can thump/bump it and it'll blow on high. So it's not the relay either.
What else could it be?
1995 regular cab S-10 2WD
4.3 TBI, 5 speed, 360,000 + miles!
SD44 is offline
post #2 of 30 Old 08-02-2009, 04:11 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: Blower Motor only works on low
Blower motor resistor is my next guess.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #3 of 30 Old 08-02-2009, 04:19 PM
Mattpyle's Avatar
User is: Mattpyle is offline
x2.
Mattpyle is offline
post #4 of 30 Old 08-02-2009, 04:23 PM
Rebel_US's Avatar
User is: Rebel_US is offline
Originally Posted by Mattpyle View Post
x2.
x3.
1986 S10 Regular cab w/2.8L -220 TBI - 4 speed manual transmission - 230K Original Miles and STILL going!
1997 S10 Xtend cab w/4.3L (X) Vortec -Automatic - 160K Miles (NEW 5/2011 - $ 750 bucks!)
http://easyautodiagnostics.com/index...articles_1.php
Rebel_US is offline
post #5 of 30 Old 08-02-2009, 04:28 PM Thread Starter
Navy Seabee
SD44's Avatar
Where is the resistor? It wasn't on the blower motor or housing.
SD44 is offline
post #6 of 30 Old 08-02-2009, 04:30 PM
jtcfanof3's Avatar
You can always remove it and test it for sure,I dont know the specs on your 95 but Im sure they can be found. Hell I found em for a 96 Econoline van I worked on last week,same thing!
LOL
post #7 of 30 Old 08-02-2009, 04:34 PM
jtcfanof3's Avatar
Its on the blower box,should be kinda flat.
Look for this outer portion:
See it in this pic?:
I know,its hard to see past the LS motor!
post #8 of 30 Old 08-02-2009, 04:39 PM Thread Starter
Navy Seabee
SD44's Avatar
SD44 is offline
post #9 of 30 Old 08-02-2009, 04:43 PM
jtcfanof3's Avatar
post #10 of 30 Old 08-02-2009, 04:57 PM Thread Starter
Navy Seabee
SD44's Avatar
Kool. When I go to the parts store, do I just tell them it's the blower motor resistor?
SD44 is offline
post #11 of 30 Old 08-02-2009, 06:08 PM
jtcfanof3's Avatar
Yeah,unless you check it and its good. Look up the ohm readings on it and see if it truly is bad. I would test it,I meen usually a resistor goes bad and the blower only works on high. Double check all your grounds and such.
post #12 of 30 Old 08-02-2009, 06:18 PM Thread Starter
Navy Seabee
SD44's Avatar
Don't want to buy anymore parts I don't need; how can I test the resistor? I went out there and swapped those relay around, since all 3 are the same. I can turn the key on, and tap the resistor on the blower box and it doesn't make it blow on high. I can tap the two outer relays, and nothing happens. But I can tap the middle relay and the blower kicks on high; no matter which relay I have put there. Wtf?
SD44 is offline
post #13 of 30 Old 08-02-2009, 07:01 PM
Blazin 4Dr
nAu HaVoC's Avatar
User is: nAu HaVoC is offline
Send a message via AIM to nAu HaVoC
Or could it be a bad wire or connection? Just an idea if its not the resistor...
post #14 of 30 Old 08-02-2009, 07:45 PM
Electrical Mod
deathphoenix99's Avatar
Doesn't sound like the typical resistor problem, usually low setting goes out or all but the high, not the reverse. So I second the ground being bad or even the motor not being the best, such as dirty contacts internally. Check the plug to as I have heard of the plug to the blower motor going bad and giving a poor connection.
post #15 of 30 Old 08-02-2009, 09:25 PM Thread Starter
Navy Seabee
SD44's Avatar
I have tested the resistor, it is fine. I have swapped all three relays around, they all do the same; so it's not a relay. As I said earlier, it has a brand new motor now. All the wires and connections look fine, and I checked them with a test light. I guess the only thing left is to check the switch in the dash.
So how do I remove the panel that's around the temp controls in the dash, without messing it up or breaking the tabs?
SD44 is offline
post #16 of 30 Old 08-02-2009, 09:56 PM
Electrical Mod
It could be the switch in the dash, but I still wonder if your ground is to blame. To get the dash apart...I was about to tell you, but realized they changed them so I may be wrong. To check the switch, when the blower motor isn't working, check the voltage at the blower fan, it should always have voltage, just different amounts depending on the setting.
post #17 of 30 Old 08-02-2009, 10:05 PM
jtcfanof3's Avatar
You tested the resistor? What did you come up with? Even if it reads it may be off causing the issuie. And again,check all your grounds and connections,lots of grounds come out of that harness.
post #18 of 30 Old 10-30-2009, 05:46 PM
User is: mich_tech_262 is offline
Shot in the dark here. My fan was blowing on settings 1, 2, and 3 but would completely cut out at 4. After testing the resister pack and swapping in a new user interface board, I found the solution to be a 30A fuse in the engine compartment fuse box labeled "HVAC". Replaced it and it works fine now.
post #19 of 30 Old 10-30-2009, 05:48 PM
Here's a couple links that may help from far2grumpy.
http://www.s10forum.com/forum/attach...sistor-loc.pdf
http://www.s10forum.com/forum/attach...-hvac-blwr.pdf
post #20 of 30 Old 11-26-2009, 02:58 AM
User is: Turbo302 is offline
Ever figure out the problem?
I have the same thing going on in a 1994 S10 Blazer. If you thump the relay (new one or old) with the blower switch on high, it will blow high. Once you switch off of high and try placing on high again, you have to tap the relay to get high blower speed
Turbo302 is offline
post #21 of 30 Old 11-26-2009, 11:16 AM Thread Starter
Navy Seabee
SD44's Avatar
I've been lazy. I'm convinced it's the switch in the dash now, just haven't made the effort to change it out. I took the relay loose from it's rack and let it sit on the intake. That way If I have the fan set on high-heat, it kicks on pretty quickly just from the relay vibrating on the intake . Yeah, it's a hillbilly fix, until i take the time to dig into the dash.
SD44 is offline
post #22 of 30 Old 12-01-2009, 08:14 PM
Future Fabricator
basketball_00011's Avatar
User is: basketball_00011 is offline
The only thing I can think of is it being your switch like you said. If you've successfuly tested everything you said, thats the only thing left it could be.
Time to go to junkyard.
I attached a wiring diagram for the Heater Circuit. Its blurry (sorry) but you can read it still. It should help you, but like I said i cant see it being anything else.
Good luck
Brandon
post #23 of 30 Old 12-02-2009, 12:21 AM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
i see what u did there
TelAmeriCorp
post #24 of 30 Old 12-02-2009, 12:46 PM
Po Po
walker01s10's Avatar
User is: walker01s10 is offline
Mine did the same thing and it was the relay on the firewall by the blower box. The plug had melted some causing the plug to warp if I messed with it I could get it to work. So I put a new plug in and it's been good ever since. Pull the relay and look at the plug.
post #25 of 30 Old 12-04-2009, 11:06 AM
User is: bowtieone is offline
I think that i posted instead of a quick reply , any way he goes.
i have a 2001 extreme blower only works on 3 & 4 . what do you think that problem is ?
Thanks, BOWTIEONE
post #26 of 30 Old 03-13-2014, 07:42 PM
User is: salmmus is offline
would it blow the blower, resistor, or panel switch to leave the heater on speed 4 while 4 doesn't work? This being so you can wiggle the wires to check for connectivity issues.
salmmus is offline
post #27 of 30 Old 03-13-2014, 07:46 PM
I have a 2000 Chevy S10 and i experienced the same problem as SD44 did with no speed 4. Replaced the blower and the resistor and still had the same problem with fan speed 1,2 and 3 working, but not speed 4. I discovered that the 30 amp fuse under the hood stopped speed 4 from working. Thank you mich_tech_262 for the info.
salmmus is offline
post #28 of 30 Old 06-12-2014, 03:44 PM
User is: mhagerla is offline
Update: my blower stopped suddenly a few weeks ago. The relay @ the firewall was replaced, but it still required tapping it to get the fan to kick on. Then the blower motor was replaced and it solved the issue completely. i put the original relay back in, but it would not work at all so it was definitely dead, however the motor was also tired.
mhagerla is offline
post #29 of 30 Old 10-21-2014, 05:25 PM
User is: Crohnsy is offline
I just want to say you guys are awesome. My issue started as fan speed 1 and 4 not working, I changed my resistor and ended up with 1,2,3 working and 4 dead. I came here, checked my hvac 30A fuse and sure enough replacing that did the trick! Now all fan speeds work.
Thanks to all the posters!
Crohnsy is offline
post #30 of 30 Old 07-28-2016, 10:15 PM
User is: 123rjc is offline
Thanks for the info. Sons blazer had no fan sped 4. Fuse was blown and replaced and works great.
123rjc is offline
