Blew my 40 amp Ignition fuse... - S-10 Forum
post #1 of 9 Old 10-28-2008, 11:25 PM Thread Starter
'01 Noma
shift220's Avatar
User is: shift220 is offline
The truck is a 2001 4.3L 2wd. I went and picked up some furniture, unloaded it and went to turn back on my truck and the starter did nothing. Today I found the 40 amp Ignition A fuse was blown...
Some background: The last couple weeks the starter has been having trouble turning over the engine. I thought it was the alternator giving out (the voltage sits below 14v once the engine is warm) and it couldn't keep up charging the battery.
Now i'm thinking I have a short somewhere that I need to hunt down so my question is, which wire in the ignition hardness does the "Ignition A" fuse power? More specifically in the harness under the dash.
Thanks
shift220 is offline
post #2 of 9 Old 10-28-2008, 11:27 PM
forum idiot
orangesonoma's Avatar
Re: Blew my 40 amp Ignition fuse...
do you have a remote start or alarm?
Brian
orangesonoma is offline
post #3 of 9 Old 10-29-2008, 12:02 AM Thread Starter
'01 Noma
shift220's Avatar
I have both yes. Anyway to test what's blowing it without wasting money on fuses?
shift220 is offline
post #4 of 9 Old 10-31-2008, 08:44 PM Thread Starter
'01 Noma
shift220's Avatar
Well I ripped out my alarm starter because I never used it anyway. The fuses are still blowing. I checked the fuse box and one side of the fuse shows +12v and the other side shows ground (An obvious short), so the question is, where could the ignition wire be shorting?
I need a wiring diagram
shift220 is offline
post #5 of 9 Old 11-04-2008, 03:27 AM
I break stuff.
Hiigara's Avatar
User is: Hiigara is offline
Haynes manuals have some decent wiring diagrams (definately not great but they'll pass)
Autozone's got some online as well, in their repair info section.
The trucks:
'98 2.2 ZQ8 - Flowmaster 40 Series, Kamikaze header. TD04HL-19T Remote Mount @ 6PSI
http://www.s10forum.com/forum/f30/pr...nturbo-503763/
'02 X-Cab LS 2.2, 220-amp home-rebuilt CS130D, 2xSony XM-2002GTR's, 2x Alpine Type-R 12".
Hiigara is offline
post #6 of 9 Old 11-04-2008, 11:12 PM Thread Starter
'01 Noma
shift220's Avatar
Well I found the problem. Turns out it was that purple wire going to the starter. I couldn't find where it was shorting but after I cut it, the fuse didn't blow anymore. So I re-routed it in a better location and it works again. And yea the wiring wasn't stock so technically it was my fault!
shift220 is offline
post #7 of 9 Old 03-30-2013, 11:30 PM
User is: culinarygraffiti is offline
Hey, I have this same problem. how far back did you cut the purple wiring? I can trace mine all the way till it goes into the main wire grouping then under the dash.
post #8 of 9 Old 04-04-2013, 03:01 PM
92REDS10's Avatar
User is: 92REDS10 is offline
You can get wiring diagrams at the top of this section.
92REDS10 is offline
post #9 of 9 Old 04-04-2013, 11:32 PM
So I read the diagram and on the top right where it has the starter listed it has the purple wire going from the starter to the crank fuse and the ignition switch. but just before the crank fuse it has a H1 on the wire. What does H1 mean? Also where is the junction box located? is it the bolt on the firewall with all the positive connections? my engine is the 4.3L auto by the way.
