Best HID Kit? - S-10 Forum
post #1 of 29 Old 11-05-2010, 05:15 PM Thread Starter
Landscaper
User is: agoetz2005 is offline
Best HID Kit?
I am going to be getting an 8,000K HID kit for my truck. So far I have Found these
http://www.hidkit.com/Chevy-S10-HID-Kits/
and these
http://www.carhidkits.com/xenon-hid-...d-kit-184.html
Anyone have any particular recommendations?
post #2 of 29 Old 11-07-2010, 10:07 PM
goin broke but n style
S15vortecpwr's Avatar
Re: Best HID Kit?
enjoy!!!!!!!!!!!!
http://www.s10forum.com/forum/f62/wa...-china-395439/
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #3 of 29 Old 11-07-2010, 10:22 PM
Lays Low's Avatar
User is: Lays Low is offline
Send a message via AIM to Lays Low
Re: Best HID Kit?
i buy from a guy on ebay, hasnt failed me yet. he also gets me the deep blue, green, and pink that people seem to keep asking me for. I use the deep blue myself tho. but they have 8000k like ur lookin for.
http://stores.ebay.com/Xenon-HID-Kingdom?_rdc=1
BRIAN
Lays Low is offline
post #4 of 29 Old 11-08-2010, 11:17 AM
BumblBXtreme
bumblebee22's Avatar
User is: bumblebee22 is offline
Send a message via Skype™ to bumblebee22
Re: Best HID Kit?
i want the deep blue for my xtreme! The only thing is i have halo projectors that have the low beam bulb as a h1 but the wiring is still for 9006. There is a conversion from the 9006 plug to the h1 bulb. Would i just get the h1 kit and get rid of the conversion? What does a H1 plug in look like? Is it just those tabs that you push on to the tabs on the bulbs? Any help would be great!
03 X-Cab Xtreme Black & Yellow, 20" Black Boss 304's, Flo Pro Exhaust, Halo Projectors 8000k Low and fogs, 12" Rockford Fosgate P3SD4 and P500r amp, Pioneer Deck, Led Underglow
http://www.s10forum.com/garage/index...DE=12&CID=3405
post #5 of 29 Old 11-08-2010, 07:07 PM
Lays Low's Avatar
Re: Best HID Kit?
BUMBLEBEE.....you would just get a h1 bulb when u order. the kits come with a standard plug that fits many vehicles. some vehicles that dont fit, they have another harness next to the plug that is just two male electrical clips that slip into ur plug and then you would electrical tape it up. had to do that on the nissan altimas.
http://cgi.ebay.com/ebaymotors/HID-S...Q5fAccessories
that comes with h1 20,000k deep blue bulbs, then they have a standard ballast that plugs into all the aftermarket hid bulbs. my s10 plugged right into that ballast so u shouldnt have any issues tho. So basically if you where to buy that you would specify that you want 20,000k deep blue h1 bulbs when you check out in the comments section of payment.
keep in mind i dont know this person and i dont sell these. this is just someone i have done business over ebay with many times and havent had an issue.
BRIAN
Lays Low is offline
post #6 of 29 Old 11-08-2010, 07:19 PM
Lays Low's Avatar
Re: Best HID Kit?
you may also need a relay kit if the lights dont turn on right away or flicker on start up or sometimes dont come on at all. my s10 didnt need it but others have needed it.
BRIAN
Lays Low is offline
post #7 of 29 Old 11-09-2010, 01:08 PM
BumblBXtreme
Re: Best HID Kit?
but if it has to go through the conversion from the 9006 plug to the h1 would that affect it cu those wires not be to the standard of the hid kit
post #8 of 29 Old 11-09-2010, 02:08 PM
User is: KerbyG is offline
Re: Best HID Kit?
Nope, it wont effect anything. I'm going to be retrofitting fxr projectors into my headlights, and they're d2s. I already got the d2s hid kit, and the stock 9006 plugs right into it, and the d2s plugs into te other side without a problem!
KerbyG is offline
post #9 of 29 Old 11-09-2010, 03:47 PM
awd equipped
stalephotograph's Avatar
User is: stalephotograph is offline
Re: Best HID Kit?
DDM Tuning is a good company to go through. They have lifetime warranty on their products.
Dewayne
1998.5 Audi A4 1.8T Quattro
post #10 of 29 Old 11-09-2010, 07:09 PM
Lays Low's Avatar
Re: Best HID Kit?
u wont have to cut wires. the plug socket is h1 but the electrical connections is a male and female connector that connects the the male and female connectors that come from the ballast that power the bulb. the plug that plugs into ur 9006 bulb will plug into the female plug that is the power wire for the ballast.
BRIAN
Lays Low is offline
post #11 of 29 Old 11-09-2010, 07:18 PM
Lays Low's Avatar
Re: Best HID Kit?
the red circles are the connections that go from the ballast to the light bulb.
the blue circle is the fitting that fits the factory plug that powers the ballast. the plug that comes out of your 9006 bulb should fit right into that plug.
BRIAN
Lays Low is offline
post #12 of 29 Old 11-09-2010, 08:49 PM
onebadsonoma's Avatar
User is: onebadsonoma is offline
Re: Best HID Kit?
i have had mine for 2 and a half years from Sharphid.com
post #13 of 29 Old 11-09-2010, 08:56 PM
Lays Low's Avatar
Re: Best HID Kit?
note that all kits arent all the same. this pic was just as a reference to how the ones that i put links up of are hooked up.
BRIAN
Lays Low is offline
post #14 of 29 Old 02-09-2011, 06:44 PM
User is: chasetherazor516 is offline
Re: Best HID Kit?
OK
im a total noob at this
can someone help me
i need some HIDS that fit some projector lights and i want some that are deep blue that work for high beams and low beams but that wont rape my wallet
please post links
post #15 of 29 Old 02-10-2011, 12:37 AM
zacharyh687's Avatar
User is: zacharyh687 is offline
Re: Best HID Kit?
www.ddmtuning.com
i ordered a set of 5000k 9006 from them with the relay harness and brackets for 60 bucks shipped
96 Chevy Blazer 4.3L HO 4L60E with 291,XXXmi and 14x,xxx on a reman 4.3.. Mods: 5000K 35W hid's, K&N drop in filter, Magnaflow high flow cat, MSD coil.
09 GMC Sierra 1500 X-Cab Short Bed 4.8L auto.
Mods. Magnaflow exhaust true duals.
5k hid. Undercover se tonneau cover. Afe dry flow air filter. Diablo sport predator.
future mods. Factory fog lights with hid. Billet front grille. And stereo system
post #16 of 29 Old 02-10-2011, 10:15 AM
Re: Best HID Kit?
awesome i would like more sights for comparison though just to see what is
brightest
last longest
best price
easy to instal
post #17 of 29 Old 02-11-2011, 12:55 AM
Re: Best HID Kit?
i know that ddmtuning has a life time warranty and they are $30 if you just buy the HID's and ballast + shipping so good price and good warranty and i have heard others rave about there products that is why i bought mine from them. i do not have them installed yet but i did put one bulb in one of my headlights and try on and they are bright as hell and i was comparing it to a silverstar.
post #18 of 29 Old 02-11-2011, 01:34 AM
Re: Best HID Kit?
www.VVME.com
www.futurevisionhid.com
post #19 of 29 Old 02-11-2011, 04:34 AM
User is: streetrunner is offline
Re: Best HID Kit?
for good quality the aftermarket xenon HID kits with complete customer service system, it is http://www.vvme.com
i cant say any other brands are crappy or shoddy stuff, but from my experience with vvme.com.. it is a better choice...
post #20 of 29 Old 02-11-2011, 10:33 AM
Re: Best HID Kit?
yea but i cant find a hi beam low beam combo on there
i would definately like to have both
post #21 of 29 Old 02-11-2011, 12:41 PM
Re: Best HID Kit?
what year truck are you wanting to put HID's in?
IF 95+ with the composite headlights your low beams will be 9006 and hi beams will be 9005
if you are running the sealed beam headlight conversion most of the housings that i have seen run a H4 bulb and they have them in the BI-XENON HID kits
post #22 of 29 Old 02-11-2011, 12:42 PM
Re: Best HID Kit?
VVME has all of the one that i listed
post #23 of 29 Old 05-31-2011, 11:10 PM
"It was all a Dream"
psycho-sid's Avatar
User is: psycho-sid is offline
Re: Best HID Kit?
Originally Posted by zacharyh687 View Post
www.ddmtuning.com
what all should i get for my jimmy? its an 01
post #24 of 29 Old 06-02-2011, 10:26 AM
Blazin' in Belize
dna59's Avatar
User is: dna59 is offline
Send a message via MSN to dna59
Re: Best HID Kit?
I used to sell and install HID kits. I've never been disappointed with DDM Tuning, VVME, or Xentec.
'00 Chevy Blazer 2DR
dna59 is offline
post #25 of 29 Old 06-02-2011, 03:59 PM
Dropped'01's Avatar
User is: Dropped'01 is offline
Re: Best HID Kit?
Yea i got Xentec for my headlights and foglights, no problems work great
'01 S10 2.2L 5 speed, 3"-4" drop, K&N FIPK, Flowmaster, 56mm TB, OBX header, STS Pulleys, Cavi Seats, envoy handles, 8k HID Headlights & Fog Lights, SS Mirrors & Gen III bumper cover, 18" 225's.
post #26 of 29 Old 06-04-2011, 10:16 AM
you gonna leauurn today
bigpokie's Avatar
User is: bigpokie is offline
Re: Best HID Kit?
ive had xentec, vvme, and ddm tuning. i say ddm all the way. i got them for the wife civic and i like them better than mine (vvme) . both great sets tho. i dont know if i would go xentec. i had trouble with mine and even more trouble with service or tring to find some. i choose ddm and also try to suggest them
BACK ON THE ROAD - 00 S10 , vicorty red , 2.2 , envoy swap , all shaved except the gate , Bagged , 3 linked , 18's
SOLD - 04 Dodge 1500 QC , 5.7 , bright white , bagged , Z'd , 2-linked , 22's
Originally Posted by TED NUGENT View Post
IF GUNS KILL PEOPLE, ALL MINE MUST BE DEFECTIVE !
THE ABOVE POST HAD NOT BEEN SPELL CHECKED
I am not a English major, nor claim to be.
bigpokie is offline
post #27 of 29 Old 06-04-2011, 10:47 PM
psycho-sid's Avatar
Re: Best HID Kit?
do i need anything more than just the plug and play kit?
post #28 of 29 Old 06-05-2011, 12:20 AM
SMURF
ridinlow's Avatar
User is: ridinlow is offline
Re: Best HID Kit?
DDM tuning. Lifetime warranty and easy plug n play install.
ridinlow is offline
post #29 of 29 Old 06-05-2011, 12:27 PM
psycho-sid's Avatar
Re: Best HID Kit?
no harnesses or nothing?
