ATC fuse - S-10 Forum
post #1 of 13 Old 07-18-2004, 11:40 PM Thread Starter
Old99Bravada's Avatar
User is: Old99Bravada is offline
ATC fuse
What's wired to the ATC fuse? Wife shut off her 99 Bravada, and when she went to go start it the next morning, it wouldn't start. I found this fuse blown, and when I replaced it, it still wouldn't start.
1999 White Olds Bravada 4.3 Vortec AWD
2000 Dodge Ram 1500 5.2
1997 Dodge Neon SOHC sedan.. yard decoration.
post #2 of 13 Old 07-19-2004, 12:12 AM
Tha_Boom's Avatar
User is: Tha_Boom is offline
Re: ATC fuse
ATC is the brand of fuse. It could be for anything check the fuse block or cover to see what it says that fuse location is for. or describe the location here so someone can help ya figure it out.
<==- 86 4.3 Blazer Sport -==>
<==- 89 4.3 Blazer Tahoe -==>
Whoomp! There It Is.
Originally Posted by orangesonoma
...i will love you forever...
Tha_Boom is offline
post #3 of 13 Old 07-19-2004, 12:36 AM Thread Starter
Re: ATC fuse
The fuse cover just says ATC at the location.. Looking from the driver's side fender, it's on the bottom right...
post #4 of 13 Old 07-19-2004, 12:42 AM
bitch
LaynLo's Avatar
User is: LaynLo is offline
Send a message via AIM to LaynLo
Re: ATC fuse
battery dead? alternator shot? fuse blow again after replacing? does it do anything at all?
Yea my trucks got a few mods
97 std cab S10 4.3 AKA The bodydrop
LaynLo is offline
post #5 of 13 Old 07-19-2004, 12:48 AM Thread Starter
Re: ATC fuse
Battery's ok.. everything works. replaced the fuse, but the engine won't try to turn over. Bought a code reader, and the pcm doesn't have any codes on it. Nothing happens when I turn the key.
post #6 of 13 Old 07-19-2004, 12:51 AM
bitch
LaynLo's Avatar
Re: ATC fuse
can you test the power wire goin to the starter while someone tries to start it and see if power is gettin to it? if power is goin to it you got a bad starter. or try this, go out and hit the starter casing with a hammer and try to start it.
LaynLo is offline
post #7 of 13 Old 07-19-2004, 12:54 AM Thread Starter
Re: ATC fuse
Wouldn't I still hear a click if it was a bad starter?
post #8 of 13 Old 07-19-2004, 01:00 AM
bitch
LaynLo's Avatar
Re: ATC fuse
maybe, if there is no clicking you could try replacing the starter relay, or tap on it also.
LaynLo is offline
post #9 of 13 Old 07-19-2004, 01:09 AM Thread Starter
Re: ATC fuse
yeah, I switched relays around and wiggled it... still nothing...
post #10 of 13 Old 07-19-2004, 01:12 AM
bitch
LaynLo's Avatar
Re: ATC fuse
in my mind then its one of two things, your key cylinder is bad or your starter is bad. i would definately run a multimeter on the starter before doin anything else.
LaynLo is offline
post #11 of 13 Old 07-19-2004, 01:16 AM Thread Starter
Re: ATC fuse
I'll check the starter tomorrow... It's stuck at my wife's grandmother's right now.
post #12 of 13 Old 07-19-2004, 01:19 AM
bitch
LaynLo's Avatar
Re: ATC fuse
i have a 90 blazer i had starter problems with. after driving it some everynow and then the starter would get heat soaked and would not do anything for like an hour.
LaynLo is offline
post #13 of 13 Old 07-19-2004, 01:27 AM Thread Starter
Re: ATC fuse
IT's been sitting for a couple of days now.. probably sell the thing when I get it running again.
