#51 |
Baby's Daddy
Re: anyone need wire diagrams
oh yeah they are both 4 cyl's
#52 |
Baby's Daddy
#53 |
SirLDragon
I have to chime in too. I need the engine control/ECM diagram for my '93 4.3L Ext cab automatic.
#54 |
Yes sir I do,
Trying to find something with the location of grounds for a 1995 s-10.Mine wont start,it turns over but just wont start.If you can help i would appricate it. thanks |
#55 |
west coast nobodies
YES PLEASE! 93 S10 4X4 4.3W CPI AUTO TRANS ELECTRONICALLY OPERATED TRANSFER CASE/FRONT AXLE TAHOE LT 4WHEEL ABS AM I FORGETTING ANYTHING?
ANY AND ALL SCHEMATICS YOU CAN HOOK ME UP WITH WOULD BE GREAT. I DO THIS CRAP FOR A LIVING, AND I DON'T LIKE TO GUESS AT IT. ALSO, IF POSSIBLE; VACUUM HOSE DIAGRAMS SPECIFICALLY THE ONES THAT ACTUATE THE 4X4 FEATURES. I NOTICED A CLUSTER OF T's, CONNECTORS,AND AT LEAST ONE CHECK VALVE JUST HANGIN THERE. RIGHT ABOUT WHERE THE TRANSFER CASE MEETS THE TRANSMISSION. ONE MORE THING.HOW DO I PUT THE ESC INTO BY-PASS MODE SO I CAN CHECK/SET THE INITIAL TIMING? SLIGHT PING THAT CLEARS ITSELF UP,BUT I'M NOT TAKING ANY CHANCES. THANKS! GP |
#56 |
bagged on dubs now!
#57 |
bagged on dubs now!
i need the column wirng diagram for a 99 with cruise.
and a column diagram for a 95 with cruise as well jordan_ciaramitaro@hotmail.com |
#58 |
bagged on dubs now!
thanks |
#59 |
I'm a huge ass
Awesome!
#60 |
2000 sonoma std. cab I4 5 speed
And it's not flex fuel. philipalan {at} gmail com is my address Thanks!!! |
#61 |
SILENCE! I KILL U!
same here everyone, I have shopkey 5 by snapon and it has wiring diagrams, repair procedures, illustrations and so on. Just email me at rockfan1815@yahoo.com with year, make, model, engine, trans and what your looking for and I will get it to you most likely the same day or next day.
#62 |
#63 |
hello !
in one old post you said you have all diagrams, do you have diagram for blazer s10 digital daschboard?some high voltage thins are burnd and my master said get a diagram. blazer s10, 4,3, 1993, 4 wd. ore may be you know where I can find it ? |
#64 |
SILENCE! I KILL U!
#65 |
SILENCE! I KILL U!
that is for aaa, its a bit hard to read, but its the best I can do.
97 s10 I will look for what you asked for after work, later on today. His was a bit shorter and I did that on my lunch break. |
#66 |
Finally got a radio
#67 |
#68 |
C-130 Comm/Nav Maintainer
Location: Jacksonville/Little Rock Air Force Base, Arkansas User is: OffLine ![]() |
hey i got a 98 blazer 4dr 2wd 4.3 w code, headlight wiring please
nate_aragon@yahoo.com |
#69 |
Black & Red
Location: All over the US, from New Orleans User is: OffLine ![]() |
#70 |
I have no connection to this company, but I bought one of their diagrams for my truck, and I highly recommend it.
www.ahdol.com They will give you all the diagrams for your truck for $12. They are quite complete, and all the wire colors and locations of pretty much everything are given. They'll email it to you within a day or so. It's a hell of a deal. If anyone wants to see mine just PM me or something. |
#71 |
hi, i need a complete wiring diagram for a 2000 4.3 auto
#72 |
Wow, you really opened yourself up to a lot of effort!!
![]() Is it possible to get dash and engine compartment diagrams for a '95 S10 Ext Cab? Need for a 4X4, 4.3L, 5 speed, non-composite headlights, TBI, ABS no A/C or other power options and manual 4X4 stick. Trying to track down a really weird problem and this would help immensely!! Thanks in advance, it's people like you that make forums priceless. ![]() Jeff |
#73 |
SILENCE! I KILL U!
do you still need, what is your email can only send by email as they are pdf
#74 |
cruising is not a crime
can you send me the diagram for exterior lighting (i'm having brake light problems) and for the fuel pump? for a 2000 s10, 2.2 cyl
thank you in advance! minority723@hotmail.com |
#75 |
Sold the Jimmy
Location: Saint Cloud, Florida User is: OffLine ![]() |
Not sure if you can help me or not but here is what I need for a wiring diagram
97 GMC Jimmy ....... it would be the body diagram that has the Drivers power seat with the rest of that circuit. Here is my issue ..... wire was toasted from (burned insulation off and had bare wires) from the fuse panel to the seat it has 3 orange wires (2 for the power seat - Lumbar and seat control) to one on the accessory relay, when I plug the third wire in the resetable fuse gets hot as hell so I know there still is a short somewhere on that circuit. If I cant get a diagram for this circuit then I will probably put a toner on the circuit to see if I can track it down. email is rockin_dodge@hotmail.com and I thank you in advanced if you can or cant help me with my request. |
#76 |
looking for wiring diagrams to go from a 1997 4.3L 5 spd to a 5.7L out of a fullsize manual trans truck. just lookign for engine stuff
nicholas.purfield@wgint.com |
#77 |
Son of a drag racer
If your still giving these out I could use the complete wiring diagrams for a 91 2.8 s10 ext cab and a 02 4.3 s10 ext cab.
Thanks. |
#78 |
SILENCE! I KILL U!
^ email address? also by complete do you just want the engine wiring and power distribution wiring or others.
i can get wiring diagrams for engine/computer wiring power distribution wiring stereo systems headlights exterior lights interior lights starting and charging circuits power accessories (door locks, alarm and keyless entry, power windows) air conditioning wiper and washer systems i can also get repair procedures as well i get all this for free through my local library card, yes libraries are good for something. lol Last edited by rockfan1815 : 12-04-2007 at 06:10 PM. |
#79 |
SILENCE! I KILL U!
i should also add that i need an email address in order to send you the wiring diagrams as they are in pdf format and can not be posted on the forum
blue dime i have the diagrams you asked for just post your email or email me at rockfan1815@yahoo.com Last edited by rockfan1815 : 12-04-2007 at 06:29 PM. |
#80 |
Son of a drag racer
Sorry I forgot to add my email
mpierce@bluestar-systems.com I'll take any wiring diagrams I can get. I'm trying to put most of the electronics from the 02 into my 91 along with the engine so I'll probably need all those in your list if its not a problem. Thanks alot! |
#81 |
SiK Intentions
Could you send me a complete wiring diagram for an 01 2 door Blazer Thanks
Blazerx001@aol.com |
#82 |
Broken Handed Superman
Hey man, i need the wiring diagram of a 98+ cluster as well as a 95-97 cluster... i want to start seeing if theres an easier way of doing the swap without having to piggyback off the original cluster(and yes all findings will obviously be posted on s10f)
mgp27@drexel.edu thanks man |
#83 |
2012
if i could get either a complete set, or just the starter/ignition/charging system diagrams i would appreciate it man!
i have an 03 4.3 auto email: vizualimpakt@hotmail.com |
#84 |
I have a 93 GMC Jimmy s15 4wd 4.3L CPI (engine code W) A diagram for the rear window/door hatch lock would be real helpful as well as one for the radio. Oh and if there is one that tells the locations of all the fuses in the fuse box that would be great too. Hope that's not too much. Thanks for the generousity. My email address is KLaFerriere@msn.com. Thanks again
