BLAZIN SADDLE
Ahl/drl ?
The AHL and DRL
I have a 4.3 V6 2002 The AHL/DHL what is it? What will de-activating them do for power? And where are they located? Last edited by Photo : 03-08-2002 at 07:43 PM. |
Shouldnt make a difference power wise...the DRL's are under the hood...the AHL you have to have a resistor for, and its that little black knobby thing that sticks out from your passenger side speaker grille.
Dildoans
they will not make a difference power wise....
*note: the following works on 99+ s-10/sonoma/blazer/jimmy* <center>DRL</center> <center>Daytime Running Lights</center> there are two ways to do this. either way, DO NOT MODIFY PINS 87A OR 30!! first, remove the cover off the fuse block in the engine bay. locate the relay for DRL, then do one of the following..... 1.) bend one of the prongs up and reinstall the relay. 2.) cut the other three prongs out and reinstall the relay. once relay is installed, be sure to double check your highbeams, make sure both work. those are contolled by pins 87a and 30. that is why it is critical not to modify those two pins. <center>AHL</center> <center>Automatic Head Lights</center> you will need a 2.2K Ohm 1/2 Watt resistor. these can be found at Radio Shack for about 50 cents for a pack of 5. remove passenger side speaker grill on dash. unplug wire from the light sensor (little ball sticking up from the grill). insert resister into plug, and use a zip tie to strap the plug down to the dash. reinstall grill. *note: the following works on 98 s-10/sonoma/blazer/jimmy* <center>DRL</center> <center>Daytime Running Lights</center> there are two ways to do this. either way, DO NOT MODIFY PINS 87A OR 30!! first, remove the cover off the fuse block in the engine bay. locate the relay for DRL, then do one of the following..... 1.) bend one of the prongs up and reinstall the relay. 2.) cut the other three prongs out and reinstall the relay. once relay is installed, be sure to double check your highbeams, make sure both work. those are contolled by pins 87a and 30. that is why it is critical not to modify those two pins. <center>AHL</center> <center>Automatic Head Lights</center> you will need a 680 Ohm 1/2 Watt resistor. these can be found at Radio Shack for about 50 cents for a pack of 5. remove passenger side speaker grill on dash. unplug wire from the light sensor (little ball sticking up from the grill). insert resister into plug, and use a zip tie to strap the plug down to the dash. reinstall grill. |
want my #... 911 beotch!!
thats great for the 99 up guys, but sh!t man, i have a 98, how do i get rid of the AHLs?????
BLAZIN SADDLE
THANKS I FEEL DUM
Dildoans
drag~N~spark
is it me or is the words all blurry in your sig? hmmm it must be me lmao
Dildoans
drag~N~spark
hey i cant help it if i ____ its some good shi*
i think i'll need more than 10min though. hehehe |
i got a six pack and a truck named trigger
is there any way to disconect the drl's on a 96 w/sealed beams without it affecting the fog lights,since they are on the same circuit?
for my 95 i took out the drl fuse.
A Constant Work in Progress
i dunno if this have any relevance or not....i just disabled the drl's on my '01 yesterday......all i did was remove the DRL fuse and cut the post that is numbered 86
i want to remove the drls and ahls on my 98 s-10 but still want full function of high beams and fog lights, can anyone help me
whass the diff between automatic and daytime lights ?
i pulled the fuse for the DRL in the fuse box on my 95 but i dont have factory fogs. i heard if u have the factory fogs it wont work cuz they run off the same circuit or something. my fogs are aftermarket on their own switch fused in-line not through the fuse box
lower than you
my buddy has an 00 xtreme and al he has to do is hit the dome overide switch 3 times right b4 he starts it with the keys in acc and the drl's are off (has to do it every time he starts it)
mines a 98 ls with fogs and i just puled the fuse it works fine no power or reliablity issue's every thing else works fine with the drl fuse gone. last i heard the drl's for certian trucks was on recall for some reason. |
I BURN THINGS
I have a 2000 LS and i pulled the fuse under the hood and cut the three prongs off (leaving 87a and 30) and my DRL's still work. High beams etc all work too. I removed the entire fuse (just pulled it) and everything still worked. How can they still work with NO fuse even in? The dome thing works, hit four times, but I want a perminent solution. I have installed silverstars and it looks lame with DRL's on. Please help.
bigboz's98zq8 i have a 98, i bent the prongs on the drl relay under the hood and put in the resistor in the dash for the AHLs. the factory fogs work and so the high beams no problems.
CHANGE YOUR EMAIL ADDRESS
what do i have to do for my 96 s-10? Taking out fuse 15 inside the door doesnt work....and it somehow fahqed up my turn signals in the process...anyone got any idea how this happened? All my lights work fine when i use the emergency flashers still, but no response on any (or in cluster) when i flip it for the signal.
This problem was a result of me overlooking the numbering setup of the fuses. I now know the numbers are actually above the fuse...not below it. I ended up pulling the wrong one. Haha. I expect to get a few laughs outta this one, but I'm still learning so its all good. I'm just glad i fixed this problem and my drl's in all of two minutes =-)
me got truck
I have a '95 w/factory fogs.Pulled the DRL fuse,and it didn't effect anything else.
O_G |
sloooow downnn!
I'm not sure which year S10 you have but to disable your daytime running lights you do not have to cut, bend, or splice any thing if you have a newer S10 made in the US. If it was made in Canada the tip I am about to give you may not work....
If you have the type of light switch with a dome light overide switch (push button) there is a tech mode built into the switch. start with the switch in the overide position and then push it in 4 times sequentially. You should here a "Bing" sound and then the DRL's will turn off. To turn them back on simply push the button 4 times again and you will here the same "bing" sound again and they will turn on. The reason that some Canadian made trucks will not do the tech mode is that the switches were contracted out overseas and no tech mode was included. It's also the law in Canada to have to drive with your head lights on in many of their provinces. Well I hope this helps out and I hope noone has cut any wiring they didn't need to. PS: For those who have the Canadian built S10's that do not have the tech mode you can try and depress your parking brake 1 click, just enough to disengage the DRL's activation switch but not enough to engage the brakes. |
#24 |
0 -> 60 in 4.6....minutes
'03-bent out prong 86 for DRLs, reinstalled, worked perfectly (with my luck i should probably add...SO FAR...). Not worried about the AHLs, if they ever bother me it's not that hard to hit the dome override 4x. I was wearing the crap out of that little button for the DRLs though.
#25 |
Chronic Tinkerer
My friend has a 98 blazer, I have a 98 s10. I have been trying the dome over ride thing for a few weeks now with no success. He figured I'm a gimp so came over to show me how to push the botton "the right way" but it didn't work for him either. However, on his truck it works great. From what we can tell, there isn't any difference between our two trucks, except for the fact that my headlights are always on. How do I tell if my truck was made in Canada or the US? Because it sounds like that might be the difference between the two trucks at this point.
Thanks |
#26 |
silenc3r
Yeah. I have a 2.2L that I think is made in Canada (i think this since when looking at engine parts inside I will occasionally see "made in canada") My DRL lights turned off by bending #86 pin on the relay but I think something got screwed up and now my HEADLIGHTS wont turn off. |
#27 |
Chronic Tinkerer
hmm... I didn't realize there was a difference between the two... I got the truck used, maybe the previous owner tinkered with that... When I pop the parking brake, the headlights come on (day, night, doesn't make a difference). The switch is in the 'off' position, but that doesn't matter. Basically, my light switch is useless. The lights are always on with the same intensity, no matter what position the switch is in. When I go under bridges or through tunnels, though, I hear a click, and the interior dashboard lights come on (from that sensor in the speaker, I'm assuming). Another thing I noticed, which may or may not be a problem, is that my brights don't seem all that bright at all. I actually prefer driving with just the headlights on. I checked the fuses and they are all still there, and the relay doesn't appear to be tampered with, so up until now, I just assumed this was because the previous owner installed those super white/blue lights. Anyway, thanks for the info. I'll keep looking.
#28 |
low n slow
ok, i looked in my owners manual and found the drl relay location under the hood. but when i pulled the relay out, it had numbers (1,2,3,4,5) no 87a and what not. and it was like half the size of the type of relays used in alarm installs. what's up with that? I don't know which posts to bend! can someone help me out?
#29 |
Anyone done this to there 03 of 04 sonoma?????
#30 |
I have a 2003 ZR2.
I can disable the DHL's and the auto-on's simply by pushing the dome over-ride switch in and out 4 times in succession quickly. In-Out-In-Out and then you will hear a "ping". The DHL/Auto is disable until either the engine is turned off or the button sequence above is repeated. |
#31 |
'69 RS/SS w/ 454 *RIP*
My relay is also numbered 1-5, am I stupid and overlooking something? Could someone post a picture of the relay and point out 87a and 30?
#32 |
EL COO COOI
Re: Ahl/drl ?
WHY WOULD YOU WANT TO DISABLE THESE FEATURES? Just curious because I like the idea of having the DRL and not hving to worry about manually turning the Headlights on. JUST WONDERING WHY YOU GUYS ARE DOIN IN!!!
#33 |
low n slow
Re: Ahl/drl ?
I removed the correct lead but my lights still function as they did before???? I have a 98 s10 and was wondering what else I might be able to try besides disabling the relay lead or trying the sequence over ride?
#34 |
I'm probably drunk.
Re: Ahl/drl ?
![]() i like not having to worry about turning my lights on at night and i like it that i wont ever forget to turn them off |
#35 |
Re: Ahl/drl ?
i pulled the #15 fuse on the 95 today. no mare dtrl
. everything works fine, except the factory fogs don't turn on by themselves. i need to turn the lights on for them to work. so i can/do turn on the running lights and the fogs :thumbsup: |
#36 |
No tailgate's here
Re: Ahl/drl ?
DHL makes the headlights be on all the time... then what does AHL do?
#37 |
Road Race/Auto X S10
Re: Ahl/drl ?
Ok I have the factory lower valance with fogs, and that little foglight switch inside the cab all from the factory. So I have to pull the dash cover and cut one of the orange wires correct?
#38 |
LayZ
Re: Ahl/drl ?
Ok, I did this and it works (AHL), the only thing is to make sure that you do it during the day because I did it at dusk and couldn't figure out why they were still coming on...
#39 |
It WAS a Blazer
Re: Ahl/drl ?
#40 |
It WAS a Blazer
Re: Ahl/drl ?
Is there anyway to make the AHL more sensitive? (not activate lights till it gets darker)? I plan on having the front window tinted, and I dont want my low beams on all the time. I went thru this w/ a Grand Prix and I had to mount the sensor right up against the glass. I might just relocate it alltogether.
#41 |
ne·far·i·ous - wicked
Re: Ahl/drl ?
#42 |
You vill luse
Re: Ahl/drl ?
When I pulled the #15 fuse in my '97 my gas gauge went all the way to the right and the truck wouldn't start. Slightly confused at this point.
#43 |
It WAS a Blazer
Re: Ahl/drl ?
#44 |
Hello there!
Re: Ahl/drl ?
96-97 Drl disable. Make sure the truck is OFF, The relay access in the glove box, take the cover off, pull the relay on the right hand side, turn the truck on and turn on the brights, if one bright comes on; you have the correct relay, turn the truck and brights off, cut pin 1 off the relay and insert it back into the socket. Your done, and you still have fog lamps and you didn't have to take the dash apart
#45 |
Fat Guys Rule!
Re: Ahl/drl ?
#46 |
Location: Lapeer / Midland, Michigan User is: OffLine |
Re: Ahl/drl ?
lol ummm the # 15 fuse is different for all vehicles.... don't just look for the # 15 fuse and pull it... according to my 2002 blazer the #15 fuse is the 4wd switch, Entine controls (VCM, PCM, Transmission) so pulling that out will cause some problems. i'm going to need to buy the resistor for my AHL's because i'm going to be throwing in some HID's and I don't want them controlled by the AHL... i'd rather turn them on and turn them off myself. |
#47 |
Re: Ahl/drl ?
#48 |
Re: Ahl/drl ?
Ok i want my night time lights on permantely. What should i do? Put a resistor in the light sensor so it alwasy thinks its night?
#49 |
Don't know jack
Re: Ahl/drl ?
#50 |
I Like Fire....HaHaHa
Re: Ahl/drl ?
does any one have a picture of what pins on the DRL relay in the fuse box of the endine bay are the appropriate pins to bend as to not accidently bend pins 87A or 30?
