LinkBack (7) | Thread Tools |
#1
I BURN THINGS
AHL and DRL How To's
How to disable your daytime running lights
98-present DRL Locate the under hood fuse box ![]() Remove the fuse box cover. Locate the DRL relay. Remove from the fuse box. It maybe very hard to pull out. ![]() Find pin #86 on the relay. Should be labled on the bottom, next to the pins. ![]() Bend #86 ![]() Reinstall the relay. Make sure the bent tab clears the fuse next to the relay. ![]() Finish by installing the cover on the fuse box. 94-97 If you don't have factory fog lights just pull fuse #15. If you have factory fog lights... Last edited by s10cyncrvr : 01-22-2007 at 01:37 PM. Reason: Updated Pictures |
I BURN THINGS
How to disable your automatic headlights
First you need a package of resistors. You can get them from any electronic store. They cost about $1.00 for a package of 5. 1998 uses 680 Ohm 1/2 watt resistor 1999+ uses 2.2K Ohm 1/2 watt resistor ![]() Remove the 2 screws holding the speaker grille on the right side of the dash. ![]() Lift the speaker grille to access the AHL sensor. Turn the sensor counter-clock wise to remove from the grille. Next unplug the sensor. ![]() Bend the resistor in a U-shape. I add a little tape to help stengthen it up. ![]() Insert the resistor in the AHL plug. ![]() Secure the resistor inside the plug either with elecrical tape or wire ties. Push the wire in the dash. Reinstall the senor in the grille (for safe keeping). Finish by reinstalling the speaker cover and 2 screws. ![]() Last edited by s10cyncrvr : 01-22-2007 at 01:41 PM. Reason: Updated Pictures |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f62/ahl-and-drl-how-tos-34645/
| DayTime running lights - CK5 Forums | This thread | Refback | 01-12-2008 08:41 AM | |
| Bypass Ambient light sensor ?? | This thread | Refback | 01-11-2008 03:52 AM | |
| Need to trick my headlights.. but how? - PbNation | This thread | Refback | 01-07-2008 09:42 PM | |
| Trying to trick my headlights - Paintball Forum - Paintball guns and gear forums | This thread | Refback | 01-07-2008 07:41 PM | |
| Bypass Ambient light sensor ?? | This thread | Refback | 12-20-2007 08:27 AM | |
| automatic headlights - Truck Forum | This thread | Refback | 12-19-2007 10:06 PM | |
| Bypass Ambient light sensor ?? | This thread | Refback | 05-28-2007 05:52 PM | |
